Old 03-05-2008, 02:46 PM   #1
TheKingofParts
Vendor
Member#: 151228
2003 WRX
Default Cobb AP cable = Tactrix Cable?
May be a silly question... but could a Cobb V.2 AP cable be used for OpenSource - just like a Tactrix cable?
Thanks in advance...
TheKingofParts is offline   Reply With Quote
Old 03-05-2008, 03:04 PM   #2
Parker @ COBB
Member#: 165591
I don't think that would work. (Never used "Opensource")
Parker @ COBB is offline   Reply With Quote
Old 03-05-2008, 03:51 PM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
No. It won't work.
The Cobb cables can't flash an ecu without the control unit.
The APV1 cable works fine with opensource loggers as long as you have a USB->Serial converter that works properly.
The APV2 cable works only with Cobb's modified ecuexplorer opensource logger because there isn't a USB driver for it.
mickeyd2005 is offline   Reply With Quote
Old 03-06-2008, 03:15 PM   #4
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Originally Posted by mickeyd2005 View Post
No. It won't work.
So a APV1 cable works for flashing but not the V2? Also can I load my Map from my V1 AP to my lap top and send it to Opensource Enginuity and flash that map to my ECU using the Opensource instead of my Cobb AP?
spoolinsti05 is offline   Reply With Quote
Old 03-06-2008, 03:51 PM   #5
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
The Cobb cable's can't flash an ecu without the control unit.
The sentences after that were in regard to logging.
Old 03-06-2008, 03:52 PM   #6
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
The cobb AP cable needs different drivers that the tactrix and since no one has written and OS AP driver, it's a no go
The only thing you can do with the Ap cable is log...but that even requires a little hack
Sausage is offline   Reply With Quote
Old 03-07-2008, 01:23 AM   #7
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Can I put a cobb tuned map onto opensouce and flash that map tot he ecu?
Old 03-14-2008, 10:12 AM   #8
alottaboost
Member#: 158029
2005 STi
nope. that would be stealing
alottaboost is offline   Reply With Quote
Old 03-14-2008, 03:02 PM   #9
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Agreed. Stealing bad.
You could STUDY the map, though, create a similar one in open source, then tweak it for your car.
Or, go the easy route, and ask someone for a baseline map, then tweak from there.
Careful with that anti-lag, though! It can easily go from "FTW!" to "WTF!?" in a few short seconds.
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 03-14-2008, 06:06 PM   #10
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
sotc
I understand it's stealing but can I study the Cobb maps of the website with RomRaider? Like will they open in RomRaider?
I guess I could just go try....
jordanretro1223 is offline   Reply With Quote
wtt: v.2 cobb ap for tactrix cable jdmrex2416 Engine/Power/Exhaust 1 12-17-2009 06:24 PM
Cobb Ap V1 obd cable LC02WRX Engine/Power/Exhaust 0 11-23-2008 03:33 PM
Cobb Ap v1 obd cable 02-03 LC02WRX Private 'Wanted' Classifieds 0 11-23-2008 03:30 PM
tactrix cable vs Cobb AP DCsubieSTI Newbies & FAQs 22 06-19-2007 09:10 PM
Need Your Help!!! Need to borrow a Cobb AP tactrix cable for 1/2 hour Sausage Tri-State Area Forum 6 04-05-2007 01:34 PM
