#1 |
Member#: 140629
SCIC
Vehicle:06 STI |
ok so my tuner told me that my car is unsafe right with the mods that i have on now but its 400 for a tune and dont have that kind of cash right now, my question is can i just get my ecu flash with like a stage 2 map( that will be much cheaper... i think?) and run the car like that untill i have cash to do a dyno or real tune....? thanks
#2 |
Member#: 122595
NWIC
Vehicle:2005 LGT Wagon ABP |
You should list ALL your mods.
#3 |
Member#: 140629
SCIC
Vehicle:06 STI |
#4 |
Member#: 161822
W. Canada
Vehicle:2008 WRX Dark Grey Metallic |
Why would you buy all that and not save the cash for a tune? Silly.
#5 | |
Member#: 122595
NWIC
Why do you need the fuel pump? I don't see injectors or FPR listed. My recommendation is to install the DP and bosal exhaust and flash a conservative stage 2 opensource tune. Do some logs to check for overboosting. Then install the HKS BOV and make sure it isn't causing idle problems or surging problems. Then when you have money for a tune, install the intake at the tuner's shop. |
#6 |
Member#: 140629
SCIC
Vehicle:06 STI |
#7 | |
Member#: 140629
SCIC
Vehicle:06 STI |
any one in socal know were some one can do a opensource tune..? |
#8 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
I have the perrin SRI and it is very very close to stock maf scaling.
#9 |
Member#: 140629
SCIC
Vehicle:06 STI |
#10 |
Member#: 122595
NWIC
I don't know about the STi, but the Perrin SRI for the LGT is definitely different than stock.
Just to be sure, I would check your AFR Learning A, B, C, and D right now with the stock intake. Then after you put on your Perrin SRI, drive on the freeway at high speed in top gear with constant throttle. Drive around like grandma for two or three days then check AFR Learning A, B, C, and D. If the Perrin SRI is the same as stock, then those values will be the same. If they are the same, that's still no guarantee. Frankly, I would be very surprised if ANY short ram has the same response as stock. In the ones that I have seen, there's usually some funny bump someplace in the scale. |
#11 | |
Member#: 162042
Vehicle:2005 WRX sedan OBP |
Good luck. --- Giun :: http://subiefreaks.com |
#12 |
Member#: 166126
South East
Vehicle:03 WRX WRB |
ev8siv3 from http://www.xpttuning.com/osecuroms/index.php lives out there you should talk to him he does good tuning. |
#13 |
Member#: 129504
SCIC
Vehicle:2004 impreza stage 2 OS-Tuning |
hey manny i do open source tuning
#14 |
Member#: 330
how would any of those mods make the car unsafe to drive?
#15 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
They can potentially cause the car to run leaner than intended. That's a good way to kill an engine.
#16 |
Member#: 330
sorry, but how much of a change in the calculation of the airflow could the intake make. it could not be that far off..5% at most...and why would these changes need a $400 dollar tune. couldn't you just scale the fuel up or down based on the difference of width between the sri and the oem maf. i.e. SRI diameter / 65 mm (OEM diameter) = % to scale overall fuel table. if it is over 100% he would be running lean, if under 100% he would be running rich.
#17 |
Member#: 71092
Man, you need to edjamakate yourself...
Intakes can require BIG changes. Hell, one spot on mine had to be re-scaled by 22%, and it's stock diameter and no bends! (in other words, most intakes are worse). If you were to ignore all resonance, turbulence, and centrifugal effects, the change in MAF scaling is still not as simple as the percent change in diameter. Give it up, it's not that easy. With a MAF system, any intake at the very least needs substantial logging and almost certainly needs a tune to be called safe. |
#18 |
Member#: 330
pm'ed you (williaty)
#19 |
Member#: 71092
/me blinks
/me looks at inbox again no.... you didn't |
#20 |
Member#: 71092
OK, it finally arrived.
Anyway, to the OP, if you don't want to spend the money to get it protuned, look into opensource tuning. A couple of weeks reading some books, some questions on a tuning forum, and you'd be able to modify an off-the-shelf stage map to run well with your car. A couple more months of studying and you'll be tuning yourself from scratch! |
#21 | |
Member#: 158043
RMIC
Vehicle:old Something new SWP |
| Thread Tools | |
| Display Modes | |
| Busted Block - What are my options for upgrade/replacement? | whtlegacy | Factory 2.0L Turbo Powertrain | 8 | 02-24-2009 12:18 AM |
| What are my options for a hood scoop? | FIK | Interior & Exterior Modification | 2 | 02-26-2007 02:03 PM |
| What are my options for the sideskirt thing? | affinity1 | Newbies & FAQs | 4 | 04-03-2006 09:49 PM |
| What are my options for a ballast replacement | vennt | Electrical & Lighting | 1 | 10-01-2004 09:07 AM |
| using stock wheel, so what are my options for brake kits | wrxruIes | Brakes, Steering & Suspension | 3 | 10-30-2003 06:11 PM |
