#1 |
Member#: 21370
Vehicle:01 Impreza RS 2.5 Blew-ridge Pearl |
I am ready to drive this car off a cliff.
We have an 01 2.5RS, the engine started to have a bad misfire. I replaced plugs and wires, no improvement. Took it to a dealer, they found a cracked y-pipe, also showed codes for misfires on 2,3,4 cyls, cat sysytem efficiency below threshold (p0420), evap emission control system malfunction (p0440), and evap system vent control low imput. We replaced the y-pipe and cats, now runs even worse. If revs go below 4000, the engine just about dies. While we were waiting for cats to come in, the shop put a straight pipe in, and the car ran fine. They installed the cats today and its bad again. Does anyone have any ideas why this would happen? Mike
#2 |
Member#: 117980
NESIC
Vehicle:2005 sti wr blue |
maybe o2 sensor or bad coil
#3 |
Member#: 21370
Is there any way to test the coils? and if they were bad, would they still work at high rpm's?
Mike |
#4 |
Member#: 168129
SCIC
Vehicle:2013 WRX WRBP |
Do you have a digital multimeter? you can use that to check the resistance of the coils but I dont know what the spec is............and no the higher the rpm the more load is put on the ignition system...
#5 |
Member#: 173384
Try spraying some water on the coil,if it sparks it is no good.
Does it run bad all the time? Could have jumped time if it runs rough all the time. May have to do a leakdown test just to make sure cylinders are ok. |
#6 |
Member#: 21370
It runs strong over 4000 rpm's, but wants to die below, while you are driving. It will idle about 10-15 seconds smoothly, the drop to below 500 rpms and shake. If you give it the gas it will pick up revs immediately, but then repeat the low idling and shaking. It is very frustrating.
Mike |
#7 | |
Member#: 64646
Vehicle:1995 Legacy wagon Green |
You could also check the idle air control valve (IACV or IAV, depending on who you talk to). However, a vacuum leak is the first thing I'd look for and it's easy/cheap to fix. --Bob |
#8 | |
Member#: 21370
#9 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
on an 01 RS...hmm....there is a vacuum hose to the pressure regulator and cruise control on the passenger side pointing towards the rear. there is the brake booster on the driver side, also pointing to the rear. you can also try looking at the manifold gaskets for the intake, TB, MAP....ummm. IACV too. maybe check the bolt tightness on some things. also check the hose for the gas tank pressure relief, it's right behind the alternator/PS pump. may have a purple electrical connector.
| Thread Tools | |
| Display Modes | |
| Aaargh! Help me Neek! Help me Tom Cruise! | banman | Off-Topic | 16 | 09-08-2006 01:50 AM |
| Help Me, Help Me, Help Me! | againstdan | Newbies & FAQs | 9 | 11-11-2005 10:26 PM |
| I need to get a sound clip from ATHF... help me Obi W... I mean help me OT! | Asinine | Off-Topic | 7 | 03-03-2005 12:33 PM |
| Help Me! Help Me Please! | wrxxxappeal | Factory 2.0L Turbo Powertrain | 8 | 05-10-2003 11:14 AM |
| Help me/Help YOu/Help ME | MichiganRS | General Forum Archive | 7 | 12-15-2000 08:54 AM |
