Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 03-05-2008, 09:41 PM   #1
PERRIN_JOHNL
Member#: 125283
Default PERRIN BugEye Project $15k - sway bars
Now that I'm in charge of Project $15K, Lets Get Rockin'!
Lets Start with the Rear Sway Bar. When we picked up Project $15k from the last owner it already had a Brand-X 22mm Rear Sway bar with three holes of adjustability. PERRIN Performance does make a bar of this size but for the sake of the BUDGET I will keep the bar. Keeping the bar did not mean there was no work to be done...........
One, the OEM endlinks where having a hard time with this larger than stock bar, notice the rubber bushing being pulled/pushed out! And it's just flexy plastic.
Two, the OEM bar mounts are a little weak for a bar this large so we replaced both. When doing this we found the sway bar bushings to be a "little" worn (or VERY worn see the cracks!) So we replaced those also.
Comparing the old Vs. New bushings (guess what one is the new one)
On a car with about 110k miles you have to use a little penetrating lube from time to time.
New PERRIN endlinks installed. (See, they do work with other brands of aftermarket swaybars! any one that says otherwise is full of POO )
PERRIN Swaybar Mount installed with new bushings on Brand-X bar.
TO BE CONTINUED.........
PERRIN_JOHNL is offline   Reply With Quote
Old 03-05-2008, 09:42 PM   #2
PERRIN_JOHNL
Member#: 125283
With the larger rear bar installed to help reduce under-steer, I felt I needed to do something with the front. I'm sticking with the OEM front bar but added the stiffer PERRIN endlinks and have the Energy Suspension OEM style bushings on order.
OEM endlink. NOTICE THE SHINNY NEW CONTROL ARM (THANKS KEN!)
PERRIN endlink on shinny NEW control arm!
Old 03-06-2008, 12:31 PM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
Looking good, nice job!
PERRIN is offline   Reply With Quote
Old 03-06-2008, 04:56 PM   #4
wrxracer519
Member#: 149890
09 Forester
Green
looks nice, cant wait for more updates
wrxracer519 is offline   Reply With Quote
Old 03-09-2008, 01:30 PM   #5
PERRIN_Ken
Member#: 165212
Blaze Yellow
nice job
Whats next??
K
PERRIN_Ken is offline   Reply With Quote
Old 03-10-2008, 09:30 PM   #6
Sharky NRK
Member#: 29549
2003 WRX
any reason you put the front endlinks on - the stock fronts on sedans are as good or better than alot of aftermarket links? Not being negative - I have really enjoyed this project and will continue to watch put in the less than 15k budget setup replacing parts that don't need to be replaced doesn't really make sense
Sharky NRK is offline   Reply With Quote
Old 03-11-2008, 01:11 AM   #7
PERRIN_JOHNL
Member#: 125283
You might be somewhat right when using the stock front sway bar but it DOES flex some. My reasoning is i wanted some bling and my goal is to "freshen" up ALL suspension mounting pionts as it is "cheeper" than adding power. But dont worry, power is on the way
john
Old 03-12-2008, 07:41 AM   #8
Sharky NRK
Member#: 29549
2003 WRX
ok I was just curious - I have been using stock links with 22mm solid bar with no issues - but nothing wrong with freshening I suppose. I look forward to the rest of the build
Old 03-12-2008, 02:41 PM   #9
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Brand-X bar = cusco
And it you really want to spice things up, set it on the 3rd hole for more stiffness.
chrisarella is offline   Reply With Quote
Old 03-13-2008, 06:50 PM   #10
Member#: 174464
looks good!
9eed4speed911@gmail. is offline   Reply With Quote
Old 03-29-2008, 04:20 PM   #11
Rice Devil
Member#: 51164
Jap Jp mag 09
Ti mag 09 (cover)
Just out of interest, the front drop links for the bugeye are the more like the OE ones that are like joints can your solid ones just replace these or am i all wrong?
I'm looking into going all Perrin instead of whiteline on front and rear (already whitelined up!)
Thanks
RR
Rice Devil is offline   Reply With Quote
Old 03-29-2008, 04:41 PM   #12
PERRIN_JOHNL
Member#: 125283
Thanks
RR
Hello Rice Devil,
Yes the front drop links are just a bolt in item, remove OEM units and install PERRIN units. I'm happy to here you are going to use PERRIN parts, let me know if I can help you with that
JL
Old 03-29-2008, 11:42 PM   #13
MUscooby
Member#: 86019
2002 WRX Stg 1
World Rally Blue
not to be off topic, but those pics are a great example of the difference between a Sway bar swap done in the immaculately clean garage of a TV car show VS the real nitty-gritty of actually doing it. great shots, very informative stuff
MUscooby is offline   Reply With Quote
Old 07-28-2009, 10:10 PM   #14
rexluthor
Member#: 218364
2004 WRX
Thanks for this. Very helpful!
rexluthor is offline   Reply With Quote
Old 07-28-2009, 10:10 PM   #15
rexluthor
Member#: 218364
2004 WRX
Old 08-30-2009, 10:14 PM   #16
osborne519
Member#: 193618
02 impreza wrx wag
psm
whats next?
osborne519 is offline   Reply With Quote
Old 08-31-2009, 12:57 AM   #17
PERRIN
NASIOC Manufacturer
Member#: 6776
Originally Posted by osborne519 View Post
whats next?
On this project? Nothing. Car is gone.
What is around the corner is a fresh PERRIN 2010 STI and 2010 WRX H/B shootoff! What does what better at what price? Is the challenge.
Stay tuned!
Old 01-31-2010, 02:25 AM   #18
opiumized
Member#: 222735
I just got front and rear Perrin sway bars for my 09 WRX sedan. I need to link pins now. People suggested Kartboy to be before because they aren't too expensive, but still very good. The dfference b/w kartboy and Perrin is like 100$ over the cost of kartboy (considering rear and front). Is Kartboy the way to go or should i just stick w/ perrin? I'm going to be getting a lot more Perrin stuff over the next 12 months, but will there really be any difference in the link pins? i'd rather spend more and do it right
opiumized is offline   Reply With Quote
Old 01-31-2010, 01:57 PM   #19
luismiguel
Member#: 170678
Chapter/Region: PRSIC
07 WRX Limited
Satin White Pearl
Nice job!
luismiguel is offline   Reply With Quote
Old 02-01-2010, 10:33 AM   #20
PERRIN
NASIOC Manufacturer
Member#: 6776
Thanks for asking! While we are obviously biased, the PERRIN Endlinks are very much worth the investment! Correct in length, direct response to the bar and matched to other PERRIN products. Also, in some cases we do have cosmetic blems that can be had for less than retail to help $$$. So check back to our site often, or e-mail or pm. Always happy to help!
PERRIN Performance
Old 02-18-2010, 12:52 PM   #21
Sk8er
Member#: 129045
2004 Subaru WRX Sti
why get rid of the 02 wrx?
Sk8er is offline   Reply With Quote
Old 08-14-2010, 10:55 PM   #22
hazer00
Member#: 254794
Nice write up!
hazer00 is offline   Reply With Quote
Old 10-09-2010, 07:56 PM   #23
mARCSBuG
Member#: 259559
Daww, I just made a coffee with the prime intention of getting into this thread
mARCSBuG is offline   Reply With Quote
FS: BRAND NEW APS CAI, Walbro fuel pump, Perrin pulley, Cusco rear sway bar phlegmon Private 'For Sale' Classifieds 3 01-07-2006 12:34 AM
PA: wanted Perrin front and rear sway bars Blizwinter Private 'Wanted' Classifieds 1 09-04-2005 11:04 PM
Perrin or Cobb rear sway bar on 04 WRX?? Visco212 Brakes, Steering & Suspension 9 08-06-2005 04:23 AM
SoCal: Perrin 20mm-22mm Rear Sway Bar & Bushings only wal.lin Private 'For Sale' Classifieds 18 07-02-2005 05:08 PM
Perrin Front and Rear Sway Bars pr0nstar Private 'For Sale' Classifieds 11 06-20-2004 01:20 AM
