Old 03-06-2008, 08:36 AM   #1
imprezaowner27
Member#: 131299
2006 Impreza
Default Will this work?
i know this has been covered before, but the search is never specific enough because people start arguing about other things
i want to get Ebay borla replicas, i know the 2006 2.5i wont bolt right up
what about a 2004 WRX turboback exhaust (obviously i wont have a turbo/downpipe) but will i just botl up the midpipe to the headers? will that fit?
imprezaowner27 is offline   Reply With Quote
Old 03-06-2008, 09:22 AM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
With modification it will. You will need UEL headers, MY05 or older cat section and if you want a turbo back exhaust it will have to be modified to bolt up.
Gr3en is offline   Reply With Quote
Old 03-06-2008, 09:50 AM   #3
imprezaowner27
Member#: 131299
2006 Impreza
yeah im getting the UEL borlas so in theory it should fit correct?
Old 03-06-2008, 10:09 AM   #4
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
you need to check the diameter of the mid pipe then find a after market exhast that is the same size diameter so that is will fit example a 2.5 mid needs a 2.5 exhast for it to bolt. esiest way is to just go look at exhast sizes and then convert the mm to inches to see if it fits or not there are a ton of free websites that will do the mat for it just plug it into google and see
Hedbergsuby07 is offline   Reply With Quote
Old 03-06-2008, 10:34 AM   #5
imprezaowner27
Member#: 131299
2006 Impreza
ok so ill have ebay UEL headers+
I have a full 2004 WRX turboback
and ill just get an aftermarket catback bolted or welded on...
Im going to switch the exhaust completely off the car so i can build it up in my living room before i install it, so it should be a problem, might as well try to get that boxer rumble
Old 03-06-2008, 11:17 AM   #6
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
You will need either a stock cat or a hi-flow, unless the muffler shop can just make you a test pipe and have no cats but then your exhaust will be stupid loud.
Old 03-06-2008, 12:10 PM   #7
imprezaowner27
Member#: 131299
2006 Impreza
They said a custom welded high flow cat will cost me 60$
and i love stupid loud
Old 03-06-2008, 01:47 PM   #8
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Your all set then.
Old 03-06-2008, 08:09 PM   #9
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
cant beat $60 for a custom HFC welded and all set to go! I paid $200+ for mine
Will this work, or what will?? mathroch UTEC 1 10-01-2006 08:32 PM
This setup may be crazy but will this work?!? disque71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-22-2005 08:52 AM
HELP! Will this work or not? Dre2932 Interior & Exterior Modification 3 04-12-2001 12:21 AM
Will this work? T-REX Car Audio, Video & Security 2 03-24-2001 07:57 PM
Will This Work? TaiChih Mid Atlantic Impreza Club -- MAIC 4 03-12-2001 05:50 AM
