Old 03-06-2008, 10:28 AM   #1
Dobbs
Member#: 28291
2015 WRX
Default Devs: Mind explaining the OL/CL Delay table values?
I have been experimenting with some different OL/CL values to (hopefully) smooth out tip-in and the OL/CL transition that occurs between shifts as well as at take off. I have tried stock values, %10 of stock values, european values, and zeroed values all without too much luck. The lurching / bucking at low speed is pretty annoying and i'd like to get rid of as much of it as possible without sacrificing gas mileage and spool time.
The euro values certainly felt the best. I have heard that zeroing the OL/CL is a bad idea since it effects LTFT (not as much time spent in CL) which has the potential to skew A/F Learning D (which obviously has some fairly dire consequences if taken to the extreme).
But onto my theory. I have a zeitronix that samples at ~72samples/second (i have observed ~50, but anyway...). It appears that the "1" values in the table (i.e. A1, B1, C1, D1) correlates to the dwell time before enrichment occurs at tip in. From the logs, i can see that there is a minor lean spike at tip in which is roughly the same as the value for A1,B1,C1,D1 in milliseconds. For example, if 100 is in A1, there appears to be a dwell time of 100ms until enrichment is applied.
So in short: what the #@!()*& do the values in the table represent!? My best guess is that the different categories, A, B, C, and D correspond to the 4 different A/F Learning Flow ranges. For a stock 02, this is 0-5.6, 5.6-10, 10-50, and 50+g/s. That leaves 4 values within each category, which i would presume are the dwell time and enrichment time for either the OL to CL transition, or CL to OL transition.
Am I way off?
Dobbs is offline   Reply With Quote
Old 03-06-2008, 10:43 AM   #2
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
bucket7788 is offline   Reply With Quote
Old 03-06-2008, 11:38 AM   #3
Dobbs
Member#: 28291
2015 WRX
lol you have no idea how long i've been looking for that... never thought to look in that forum... thanks a ton.
Old 03-07-2008, 02:59 PM   #4
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Nice thanks bucket7788
gaby is offline   Reply With Quote
Does COBB for the 07 deals with the OL/CL delay issue? BBBsti LTD AccessPort 4 09-07-2007 08:54 PM
The OL/CL Delay and STX yobtah Motorsports 1 01-01-2007 10:45 AM
OL/CL delay and P0328? Parsons Engine Management & Tuning 3 08-08-2006 10:52 PM
Please help with the OL/CL delay problem accelguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-09-2006 04:26 AM
prevent ol/cl delay? dypeterc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 09-26-2005 01:37 PM
