Old 02-12-2002, 01:06 AM   #1
Miracle Worker
Member#: 1390
2000 2.5 RS Sedona
Red (Chicken Katcher)
Question How can you tell if speakers are wired up backwards.
I was wondering if there is a easy way to tell if you have speakers wired up backwards (positive on negative) Can you tell with a voltmeter?
Miracle Worker is offline   Reply With Quote
Old 02-12-2002, 09:36 AM   #2
Johnysmoke
Member#: 14852
2013 Ford Flex
I think as long as they are all wired the same way you should be all set. Not entirely certain though...
Johnysmoke is offline   Reply With Quote
Old 02-12-2002, 10:14 AM   #3
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
ummm...no.
If they are all wired the same way, and they're all wrong, then it'll be easy to tell. You'll have pretty much no bass from the speakers. If you're still not sure after listening to them...reverse the polarity and try again...one way will sound much weaker and worse...and that is the wrong way
JGard is offline   Reply With Quote
Old 02-12-2002, 10:22 AM   #4
6Pack
Member#: 13901
2002 WRX Sedan
If you take a regular battery and put the postivie end to one connector of the speaker and the negative end to the other side of the speaker the cone will move either up or down (doesn't matter which way, as long as all 4 go the same way). So as long as you know the polarity from the HU the rest is easy, if you don't find the manual online.
6Pack is offline   Reply With Quote
Old 02-12-2002, 12:58 PM   #5
Cjchaps
Member#: 3181
07 Rav4
Just to help clarify, he means a regular 9-volt battery that you use in a walkman or something, not a regular car battery!
Cjchaps is offline   Reply With Quote
Old 02-12-2002, 02:28 PM   #6
6Pack
Member#: 13901
2002 WRX Sedan
Yes.
Old 02-12-2002, 03:24 PM   #7
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Default easy test
to test if you have speakers out of phase (hooked up wrong) just turn the radio up, and turn the bass up also. then adjust the balance from left to center to right. if the bass is louder when just one speaker (either left or right) than when both are playing you have one of the two out of phase. pick a speaker and switch the polarity.
cnstman
cnstman is offline   Reply With Quote
Old 02-12-2002, 11:02 PM   #8
Seraphiem
Member#: 6328
2002 Impreza 2.5 RS
'04 MazdaSpeed Miata
On smaller speakers use a AA.
Leave the 9 volt for the bigger woofers.
Seraphiem is offline   Reply With Quote
Old 02-13-2002, 10:08 PM   #9
ldivinag
Member#: 13533
04 sti
black???
or a competent car audio place should have a phase indicator tools... without having to rip the door panels off or anything...
ldivinag is offline   Reply With Quote
Old 02-13-2002, 11:37 PM   #10
RawCode
Member#: 3115
2002 Impreza 2.5RS
Buy an IASCA auido test CD... it has an in phase outta phase test... give that a try...
RawCode
RawCode is offline   Reply With Quote
Old 02-14-2002, 12:48 AM   #11
Miracle Worker
Member#: 1390
2000 2.5 RS Sedona
those last two ideas agre good. Now I don't have to pull off my door.
Old 02-14-2002, 01:04 AM   #12
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
if ALL the speakers are wired backwards, it might never sound its best, but if one is wired out of phase, the image will be like surround sound... sound will kind of come from everywhere and you'll have no centerpoint. Also, the bass will be really thin.
nhluhr is offline   Reply With Quote
How can you tell if tophats are group n fkarkvan Brakes, Steering & Suspension 4 03-27-2010 10:16 PM
How can you tell if your injectors are deatschworks? Samurai_jim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-05-2008 11:18 AM
How can you tell if they are "real" group n hardend strut tops?. trail*of*dead Brakes, Steering & Suspension 12 10-29-2004 01:23 PM
how can you tell if struts are blown? drifterx Brakes, Steering & Suspension 8 07-18-2003 12:25 PM
how can you tell if you have a blown strut? FatCatTurbo Brakes, Steering & Suspension 4 01-24-2002 05:54 PM
