Old 03-06-2008, 12:46 PM   #1
horf
Member#: 35971
2002 WRX wagon
Default Timing belt too long?
So my 02 WRX wagon started to make some valve slapping noise. It's got 84000 miles and the original timing belt. Since I was replacing the radiator I decided to replace the timing belt too. I got a Power Enterprises belt from Mach V. Everything was going fine. Got all 4 cams lined up, belt on, etc. After all was said and done, the belt is loose. It seems like it's too long, but just a little.
I checked with Mach V and it is the correct belt. Did I stretch the belt when I put it in? Seems unlikely. The idler and tensioner seem to be in the right place and working fine, but is there a malfunction I'm missing? Is there something else I missed? I've gone thru all the DIY/FAQs and I think I did everything. Is there a trick?
Thanks for the help.
p.s. Driving my wife's minivan SUCKS!!!
horf is offline   Reply With Quote
Old 03-06-2008, 01:44 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
isn't there a pin you need to pull on the tensioner to let it actually do its thing?
Old 03-06-2008, 02:37 PM   #3
horf
Member#: 35971
2002 WRX wagon
Yep, you stick a 2mm allen wrench into the piston to hold it in place while you assemble all the other parts. I pulled that out. The tensioner is doing it's thing, but th belt is still loose.
How tight should it really be? None of the wheels without teeth should be able to turn without the belt moving, right?
Old 03-06-2008, 02:54 PM   #4
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
Try putting the old belt back on or try compairing the belts. I just did mine on my 04, I used a factory belt though, had no problems.
hcsi99 is offline   Reply With Quote
Old 03-06-2008, 05:34 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
rotate the crank around.. it'll adjust
sidewayz is offline   Reply With Quote
Old 03-06-2008, 07:34 PM   #6
1320Fastback
Member#: 131461
1998 Outback
White/Grey
+1
My book says to rotate counter clockwise 90 deg, then go 2 full revolutions clockwise.
1320Fastback is offline   Reply With Quote
Old 03-06-2008, 10:56 PM   #7
eb1888
Member#: 115226
2005 wrx wagon
The PE blue belt is kevlar and doesn't come marked. What I like to do is rotate the old belt until the timimg marks line up. Mark the belt with white-out or something else. Then remove the belt and transfer the marks to the PE. If you can't do that, buy or borrow one from your parts manager for the transfer. When I installed mine, the belt did not stretch like a new regular belt. At first I thought the tensioner was bad, but it checked out. The belt is just better. Less stretch, more exact tming.
eb1888 is offline   Reply With Quote
Old 03-07-2008, 08:26 PM   #8
horf
Member#: 35971
2002 WRX wagon
OK, I'm a dumbass. I forgot to put that metal sleeve into the tensioner assembly before I put the bolt in. Good thing I didn't break anything.
After you rotate the motor, the tension evens out.
Sorry about the drama.
Old 03-07-2008, 09:05 PM   #9
viaburn26
Member#: 167272
2004 STi
your somewhat correct .
the pe belt v1 doesn't have the marks while the v2 does ...
viaburn26 is offline   Reply With Quote
STi FUEL LINES TIMING BELT AND COVERS AND ENGINE WIRING HARNESS. OTHER ITEMS TOO! silvershadow Engine/Power/Exhaust 0 07-13-2009 12:53 PM
Timing belt to long! xmoshx Service & Maintenance 1 12-02-2008 08:04 PM
Replacing timing belt, need to do pump too? ursmother Service & Maintenance 11 05-12-2008 10:03 AM
How long for timing belt service? tommy2hotty Service & Maintenance 7 03-01-2006 07:36 PM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
