Old 03-06-2008, 06:00 PM   #1
SC2000
Member#: 162421
Default Just changed tranny fluid- harder to downshift now?
My car currently has about 30,900 miles on it and I replaced the trans fluid with non synthetic Valvoline 75W-90. I drove it around and thought everything was great, but it didn't seem to shift any easier or differently than before I changed the fluid. But after driving for a couple days now, I've noticed that when I come to a stop, it's harder to downshift into 2nd gear. Before I wouldn't really get into 1st gear until I almost came to a stop. It's the same now, but it seems as though 2nd gear is just as difficult to down-shift into. Also, the upshifts are fine. I can go from 1st-2nd-3rd-etc.. just fine. Only downshifting I noticed it got more difficult.
Thinking of changing the fluid out again and going with Motul 300 (synthetic).
SC2000 is offline   Reply With Quote
Old 03-06-2008, 06:50 PM   #2
RingU
Member#: 137243
2004 2.5L WRX JPB
1999 Civic EX White
I think its recommended to use the tranny fluid from subie dealers.
RingU is offline   Reply With Quote
Old 03-06-2008, 07:24 PM   #3
mikeythejew
Member#: 141672
Everyone thinks synthetic oils are more slippery. If that was true, you wouldn't want it in your transmission.
If any gear oil, dino or synthetic, says it's approved to use in limited slip diffs, the fluid will be slippery which will cause harder shifting/grinding in a synchronized transmission.
I can shift into 1st rolling at 20mph using a specific GL-5 75W90 gear oil that I've talked about before. A few have tried it out and like the stuff, one reporting it in a reply somewhere on this site.
mikeythejew is offline   Reply With Quote
Old 03-06-2008, 07:51 PM   #4
SC2000
Member#: 162421
which fluid are you referring to?
I've read that the dino Valvoline 75W-90 Gear Oil was the stuff to get. Not sure what to try now.
Old 03-06-2008, 08:55 PM   #5
BillJC
Member#: 31002
Redline lightweight shockproof.
BillJC is offline   Reply With Quote
Old 03-07-2008, 12:54 AM   #6
SC2000
Member#: 162421
nevermind...did a search with your user name. seems like you like the supertech semi syn gear oil...i'lll check out my local wal-mart and see if they got anything in stock. i can't stand driving this thing on local roads...pita going into 1st AND 2nd.
Old 03-07-2008, 12:57 AM   #7
SC2000
Member#: 162421
If only they didn't sell it in a 20 Liter bucket and not cost me $150, I'd consider it. They should sell these by the liter...someone contact SOA.
Old 03-07-2008, 04:43 PM   #8
sigurd
Member#: 128721
2002 impreza WRX
psm
Thats odd. Lots of people very happy with the valvoline dino.
My car has had it in for about 15k now and it still shifts like it did when I put it in.
sigurd is offline   Reply With Quote
Old 03-07-2008, 08:29 PM   #9
horf
Member#: 35971
2002 WRX wagon
Use the redline shockproof lightweight. A bit expensive but works great.
horf is offline   Reply With Quote
Old 03-07-2008, 10:15 PM   #10
mikeythejew
Member#: 141672
http://www.wd-wpp.com/specsheet/75w90.pdf This fluid is sold at walmart @ $4.12 a quart as SuperTech semi synthetic 75W90 in grayish bottles. Our tranny doesn't have a clutch type LSD to need a friction modifier, thats why the link says it's for top off only. I have used this fluid over 20k and it works. The viscosity index is high which means this fluid has a very good oil base.
It's the diamond in the rough.
Old 03-07-2008, 10:22 PM   #11
mikeythejew
Member#: 141672
The supertech bottle says it provides excellent protection for copper and other yellow metals or something.
Old 03-08-2008, 12:59 AM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm surprised as well that you're having downshifting issues as, after exhaustive testing of most of the other blends out there, I've settled on the Valvoline dino because of the shift performance.
Old 03-08-2008, 08:24 AM   #13
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I ran Motul Gear 300 for quite a while - shifted just fine (standard resistance to getting into 1st while above 5-10mph without rev matching, but everything else was smooth)
Old 03-08-2008, 12:13 PM   #14
Arctic Penguin
Member#: 119532
2006 WRX
i have found that both of my cars hated the valvoline 75w90
Arctic Penguin is offline   Reply With Quote
Old 03-08-2008, 12:22 PM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The dino or the synth? All of them hate the synth, most of them like the dino.
Old 03-08-2008, 12:44 PM   #16
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
My car did not like the Valvoline 75w-90 dino at all. So weird the varying experiences on these forums.
Mind is offline   Reply With Quote
Old 03-08-2008, 01:21 PM   #17
SC2000
Member#: 162421
what did you end up using?
Old 03-08-2008, 01:52 PM   #18
Mind
Member#: 109216
08 STI DGM
Amsoil 75w90 SVG... tranny isn't liking that too much either. I don't mind notchiness that much (kind of like it), but the shifter is very scratchy going in/out of gears.
Old 03-08-2008, 05:01 PM   #19
prometheum
Member#: 92003
04 bicycle!
draim some fluid and add a quart of royal purple synchromax or penzoil synchromesh in there
prometheum is offline   Reply With Quote
Old 03-08-2008, 05:07 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
While that will work very well, people need to know both of those fluids dissolve the synchros over time.
Old 03-09-2008, 12:13 AM   #21
Arctic Penguin
Member#: 119532
2006 WRX
i would like to see proof of this statement
or you should delete it
Old 03-09-2008, 12:47 AM   #22
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, first of all, you can look at the fact that the data sheets for both of those products contain chemicals known to be corrosive to "yellow" metals. Then you can go ahead and look at the fact that neither of those lubes can be GL-5 certified due to the amount of un-encapsulated Sulfur in them (which is corrosive to brass). Then you can talk to a couple of the big name Subie tranny shops (or just read their posts on here about this topic) where they report that the majority of the transmissions they rebuild where Synchromesh/max had been run have severe pitting of the synchros.
If you don't want to believe me or them, that's your choice. However, people have the right to make an informed decision. They can either believe me, disbelieve me, or become interested enough to go find data one way or the other themselves.
Deal with it.
Old 03-09-2008, 06:27 AM   #23
prometheum
Member#: 92003
04 bicycle!
hypoid gear oils, (gear oils designed specifically for differentials) have substances in them that are corrosive to metal alloys containing copper in them like synchros
Old 03-09-2008, 06:28 AM   #24
prometheum
Member#: 92003
04 bicycle!
Deal with it.
i do believe you are mistaking, read my last post
Old 03-09-2008, 10:15 AM   #25
Arctic Penguin
Member#: 119532
2006 WRX
Deal with it.
so that means that the gm and chrysler transmissions that these fluids are used in contain no yellow metals at all??
and your point is an assumption
this is not proof in any way
lets see some real proof of this hypothesis or it is just that
no proof = hypothesis
not fact
lets see PROOF
post it
and having the differential and trans gears sharing the same lubricant does pose interesting lubrication issues that would seem to contradict themselves
so what is the answer??
it isnt in hypothesizing and posting hearsay or conjecture or wives tales
Changed tranny fluid, now 4th gear grinds shamrock 05 Transmission (AT/MT) & Driveline 12 10-29-2008 07:49 PM
changed tranny fluid, now there's a whine? Pungistik Service & Maintenance 6 06-02-2006 05:37 PM
changed tranny fluid, now strange vibration criscross79 Transmission (AT/MT) & Driveline 2 03-19-2006 07:44 PM
Just changed tranny and diff fluid.....WOW!!! YourMother'sLover Texas Impreza Club Forum -- TXIC 18 08-30-2005 11:37 AM
Just changed tranny and rear diff. fluid, finding. JDM nut STi Forum Archive 2 09-06-2003 03:03 AM
