Notices
Old 03-06-2008, 06:58 PM   #1
Subieformance_Guy
Member#: 108716
2004 2.1L, PT 6069
[email protected] Subarus-R-Us
Post Still getting 448 code
Aliright I fixed the connector next to the canister in the back and replaced the valve back there and Im still getting this damn code. I followed the factory service manual for this code and did all the steps. Im getting continutiy to the ecm back to the wire and It's getting the recommended voltage. Ive reset the ecu with a handheld scanner, a modis, and by pulling the terminal and the light comes back on within miles. Ive also searched this forum and it seems like Im one of the few thats ever gotten this light and the few that ive found didnt help in ideas of fixing it. Im to the point where I dont know wat to do now cause its got to be instpected and it wont pass. So any ideas would be greatly appreciated
Subieformance_Guy is offline   Reply With Quote
Old 03-07-2008, 12:10 AM   #2
SubeTek
Member#: 1714
1999 RS-T COUPE
have you checked the solenoid to see if it is actually working? you can do this by connecting the green connectors under the dash, then turn the key on & and try blowing thru the solenoid. it should hold then release pressure, if not, the solenoid is bad. if the solenoid works, your best bet may be to take to your local dealer. hope this helps.
SubeTek is offline   Reply With Quote
Still getting P0302 code grinch77 Newbies & FAQs 9 03-08-2009 07:44 PM
Seamen Demon, gets his head cutoff but still gets a hand on it... (CW's Reaper) Kostamojen Off-Topic 18 05-01-2008 10:59 PM
just installed AP v1. and still have CEL code black04sti AccessPort 19 02-17-2007 07:31 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
anyone with club spec get cel code 171 Brewmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-07-2002 10:56 PM
