Old 03-06-2008, 08:53 PM   #1
Inder
Member#: 137838
2000 Legacy GT Sedan
Timberline Green
Default AVO on a 2.5 Legacy GT
Can someone confirm with confidence that after you install this kit, and using the p6 ecu that's pre-programmed that you will be able to just daily drive and enjoy and everything will work great, like it's advertised?
It sounds too good to be true
(2000 legacy gt ej25 sohc phase ii)
Inder is offline   Reply With Quote
Old 03-06-2008, 08:59 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
PP6 you mean? It's not an ecu, it's a piggyback. make sure it has the 5th injector and the latest software to control it. Problem with the PP6 and FI is that it can't control all 4 injectors well enough to evenly distribute fuel, some of the early ones had lean conditions running in one or two cylinders. (correct me if I'm wrong here, it's been a while since I read up on the specifics)
AVO kits use LINK standalone EM usually though. That has it's own set of problems, mainly concerning the trigger wheel for timing or something (again, it's been a while since I read up on what the LINK needs), it's not the same for the Phase II as the Phase I engine with which the original LINK EM was designed to work with on the AVO turbo kit.
Basically if you ever want to turbo kit your Phase II, spend the $$ on the engine management. This is where half-assing it can lead to problems, and lot of sob stories about how turbo kits in general are unreliable.
Go to the Aftermarket turbo forum for more info on any of these. This is the wrong forum for it.
rougeben83 is offline   Reply With Quote
Old 03-06-2008, 09:19 PM   #3
Inder
Member#: 137838
Timberline Green
Ok cool, thanks for the info
Old 03-07-2008, 05:40 AM   #4
PA-Outback2000
Member#: 161832
2000 Outback Limited
it seems relevant to mention xcceleration.com here. they sell the complete AVO turbo conversion kit. i have asked them tons of questions and once they tune it, it is ready to go. depending how the car reacts tells which parts need to be added, tweaked, or switched. i am most likely going to use this kit when i convert my car.
PA-Outback2000 is offline   Reply With Quote
Want to replace my 2.0 in my Bugeye and put in a 2.5 Legacy GT driveline... B-Kerr Subaru Conversions 6 03-14-2009 05:14 PM
WRX fronts and old Turbo Legacy rears VS. 2.5 Legacy GT Front and Rears keirnna Brakes, Steering & Suspension 7 03-27-2005 12:34 AM
Mods for a 2.5 Legacy GT? ajlepisto Newbies & FAQs 6 08-30-2004 12:00 PM
2.5 Legacy GT Engine Swap Lots of help needed please! funkadellic69 General Community 3 11-08-2002 02:12 PM
2.5 Legacy GT - Impreza L Engine swap Help Please! funkadellic69 Legacy Forum 2 11-06-2002 02:05 AM
