Old 03-07-2008, 04:15 AM   #1
sonycrr
Member#: 128161
2006 wrx limited
wrb
Default question about cel
question about cel
got a cel while driving home tonight.
steady cel and blinking cruise light
when i got home, i reset the ecu
would the dealer still be able to check the code even though i reset the ecu?
2 mods, boost gauge, spt intake
car seems to be driving fine.
thanks
sonycrr is offline   Reply With Quote
Old 03-07-2008, 06:46 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No. You shouldn't have done that reset, by so doing you erased the code from ECU memory. However since that doesn't actually fix anything the code will probably come back, so if the light comes on again DON'T do another reset.
Technical question about CEL Turbo NV Mid Atlantic Impreza Club -- MAIC 5 12-19-2003 06:00 PM
question about CEL and codes Se3n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-05-2003 07:38 PM
Question about CEL WuWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-12-2003 04:59 AM
questions about cel fix on exhaust? up pipe DP!!! ChristophWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-13-2003 10:12 AM
question about CELs andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-14-2001 11:29 AM
