Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 02-12-2002, 10:38 AM   #1
LehighWRX
Member#: 14078
Default H&R Coilovers
I just found out the H&R have a coilover set for WRX. I bet they are cheaper than DMS or M2 because they are only height adjustable. Anyone have experience with them?
LehighWRX is offline   Reply With Quote
Old 02-12-2002, 12:21 PM   #2
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default h&r c.o.
they are not cheaper. they are listing for $2350. i just got off the phone w/ the engineer at h&r yesterday. they sound like a very well sorted out system that's made for street and track sessions and autox events. their drop range is as follows:
F/R: 1.2-2.5 / 1.0-2.0
they feel that their dampeners do not need adjusters since they hit the optimum dampening rates for the springs that are on the system. the spring rates are spec'd for neutral handling (not a lot or next to nill understeer). this theory of non-adjustable dampeners is not a bad thing. the eibach/bilstein kit that was offered for the previous gen impreza (nonwrx) was breath taking.
hope this helps
duckboy
duckboy is offline   Reply With Quote
Old 02-12-2002, 12:30 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
couple of questions...
the H&R coilovers... do they let you choose your own spring rates?
what are the spring rates?
what sizes are offered in this coilover kit?
the bilstein/eibach's were 30mm yes?
the DMS golds are 40mm... both provide a different type of ride...
i havent seen this set up yet...
just trying to learn a bit more about it.
Jamie
www.subiegal.com
www.subiegalracing.com
Old 02-12-2002, 01:28 PM   #4
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
Default a little tech info on the H&R coilovers
The dampers are pre-set and valved to match the car to produce a neutral balance while still being comfortable on the street.
spring rates
450 front
400 rear.
Lowering
1.2" - 2.5" front
1.0" - 2.0" rear
cost
$1622.00
Luke
877-522-8473 ext. 362
Old 02-12-2002, 01:31 PM   #5
LehighWRX
Member#: 14078
the 2350 is the suggested retail price H&R has for it coilovers but tuners will most likely sell it for much cheaper. For example, Audi S4 coilovers suggested retail price is $1,980.00 but tuners are selling it for as low as $1250.
Thanks Luke for the added info. I will be ordering my set as soon as my custom wheels are in!!
Old 02-12-2002, 03:39 PM   #6
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default male slider dia.
subiegal
to answer your question regarding the male slider dia., per the H&R engineer i talked to, the male slider is 50mm dia.
i don't think you want to change the springs on these units since there are NO provisions to adjust the dampening (compression or rebound).
sounds like a pure tarmac set-up.
duckboy
Old 02-12-2002, 03:45 PM   #7
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
450 front, 400 rear?? I have no idea how they ride, but those are some prodigious spring rates. Should be flat as a pancake. It makes sense not to have adjustability with spring rates like that. The softer settings would turn the car into a pogo stick.
Kevin
gtguy is offline   Reply With Quote
Old 02-12-2002, 07:00 PM   #8
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
Yeah...450/400 seem like REALLY high spring rates. That set-up must REALLY stiffen the car up. Sounds like almost TOO stiff.
Old 02-12-2002, 10:21 PM   #9
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
whoa!!!
those spring rates will kill ya kidneys!
and no dampening adjustability?
well thanks for the info! very interesting indeed!
may be good for a track car...
but no-way-n-ell- i'd put those on a street car...
OUCH!
jamie
www.subiegal.com
Old 02-12-2002, 10:25 PM   #10
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default rates
yeah, i think 2 kidney belts are included in the kit as well as surgeon general warning stickers to post on your windows
duckboy
Old 02-13-2002, 05:56 AM   #11
GDA
Member#: 4324
02 GDA
Platinum
450 and 400?
That sounds about right, all J-spec coilovers are around that range. My zeals are 448 f 336 r, although the rear seems a bit stiff. Im sure H&R valved them suitably enough for daily driving. If its done correctly then the ride wont be as bad as you think.
Cusco Zero-1's which are not dampening adjustable with 448 336 rates are just fine not that stiff (honestly), i mean unless your used to dms spring rates.
Looks like a nice setup, someone should get a review on here asap!
EJ20WRX
GDA is offline   Reply With Quote
Old 02-13-2002, 06:29 AM   #12
SKC
Member#: 15250
I have spring sets in the following F/R rates for my DMS 50mm (GTP valving) : 650/550, 340/275, and 250/175. I have found that I like the 340/275s for fast tarmac work.
The light set are just too soft although they would make for a very fast "civilised" ride.
The 650/550 set are extremely stiiff, although the suspension is still stichion free with outstanding small bump compliance given the rates. They only ever get used for track work.
Generally most folks who ride in the car with the 340/275s comment on the stiffness. I have ahd folks ask if the tyres are made out of wood! Given the side wall contruction of Dunlop D01Js and the fact that they are run at 39/35psi on the street it can be forgiven I guess.
Considering the low interal pressure of the DMS 50s and the resultant super low stichion, I would think that for 98% of people would find the 450/400 combo WAY too stiff.
I would recommend 275/225 as being ideal for most sport driving.
Cheers,
Stephen
SKC is offline   Reply With Quote
Old 02-13-2002, 09:39 AM   #13
LehighWRX
Member#: 14078
Talking
I will post a review as soon as I get my hands on a set
Old 02-13-2002, 04:57 PM   #14
hansking
Member#: 11533
02 wrx
blue
Default i've had h&r on several cars
and their ride is very supple. they manage to get the spring and damping rates well matched so that the ride quality is very acceptable. had this option been available sooner, i would have chosen the h&rs again as i have been very pleased with both the units and roland's support at h&r.
i wouldn't worry about the spring rates if those numbers were correct as a correctly matched set can ride better than a soft spring/hard damping setup.
i've got the m2 dms golds now and they are stiffer but seem to be working out so far. i've got some spring rate changes to make to see if the car can work better on the tarmac and that should be happening in the next month or so.
hansking is offline   Reply With Quote
Old 02-13-2002, 07:36 PM   #15
Joe LI
Member#: 4794
02 WRX
Default I would not hesitate with H&R's
They make excellent products. Had H&R coilovers on my 996 C2 Cab. Awesome product, very little tradeoff in ride considering the handling improvement, turning a GT car into a real sports car. Unfortunately, they are like $5k for a 996 C4 (same setup as a 996TT, with a few extras through Gemballa), so I'm left stock now on my C4, except for GT3 sway bars.
I have the Cusco Zero-1's on my Rex and they are quite bouncy, though I have started getting used to them finally. But if the H&R's were available at the time I would definitely put my faith in them. Can't mess with German engineers.
Joe LI is offline   Reply With Quote
Old 02-13-2002, 08:03 PM   #16
Mykl
Member#: 14311
2010 GTI
I'm somewhat intrigued.
Although I constantly go back and forth about whether or not I should go fully adjustable.
Mykl is offline   Reply With Quote
Old 02-13-2002, 09:19 PM   #17
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default h&r co's
good point Joe Li. my friend had H&R co's on civic si some time ago and the car rode quite well. i don't know what rates they had on that system, but, if i didn't know the rates that H&R is prescribing for these co's, then, i'd probably purchase them. but them rates are mighty high. i guess their shocks have some pretty high internal rebound valving settings to cope with those springs.
duckboy
Old 02-13-2002, 09:54 PM   #18
PharmCo
Member#: 11443
Midnight Black
Hey Luke, do they include top hats? If not were these desinged to use the stock mounts or do they require 3rd party mounts? I know the stockers are a bit soft. Thanks!
~PC
PharmCo is offline   Reply With Quote
Old 02-14-2002, 09:12 AM   #19
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
I just opened a set up in the warehouse and they are straight bolt on and go. A very good looking product to say the least.
If you are wondering the springs are red in color and the body is sort of gold in color.
only a few sets left in-stock at this time
Luke
Old 02-14-2002, 11:15 AM   #20
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Ummm.....that didn't answer the question. Do H&R's normally come with top hats?
Zahnster is offline   Reply With Quote
Old 02-14-2002, 11:36 AM   #21
LehighWRX
Member#: 14078
nope, at least on Audis and VWs so I am assuming no top hats for those. I will probably get the STI top hats when I get these.
Old 02-14-2002, 01:19 PM   #22
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Regarding H&R coilovers and their high spring rates, European car periodically does articles on them. June 2000 has a really good article about H&R coilovers, very in depth.
Here's a pretty decent one: http://www.europeancarweb.com/tech/0401tech1.shtml
The one on the Passat in June 2000 is even better though it looks like the above borrowed some of the INFO from the Passat article.
There is also a small bit in a newer issue on them. Mid-Late 2001.
Anyone w/ H&R Coilovers, please post a review 2QUICK4U Brakes, Steering & Suspension 1 04-05-2011 03:52 PM
Any WRX owner install H&R coilovers yet? 2QUICK4U Brakes, Steering & Suspension 1 04-02-2002 02:35 PM
H&R Coilovers CRAZY KEN Legacy Forum 0 04-01-2002 06:47 PM
getting H&R coilovers tommorow! bluperlrex Brakes, Steering & Suspension 6 03-07-2002 03:23 AM
h&r coilovers bluperlrex Bay Area Impreza Club Forum -- BAIC 0 02-14-2002 02:09 AM
