Old 03-07-2008, 12:52 PM   #1
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Default Legacy OEM air intake section on an Impreza?
Does the stock Legacy air inlet section (big plastic wedge on the photo) fit on the Imprezas? Could be the easiest step to give a bit of fresh air to an OEM intake without making it any louder...
Taken from a legacy forum...http://www.sl-i.net/FORUM/viewtopic.php?t=852&start=0
Old 03-09-2008, 12:49 PM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Bump? Noone thought of doing this?
Old 03-09-2008, 01:11 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
I have thought about it but that is about it. In theory you are taking in fresh cold air rather then warm air from the engine bay.
flstffxe is offline   Reply With Quote
Old 03-09-2008, 01:18 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i thought about this also, but with the WRX trumpet not the legacy one... the only thing is on the 05-07 impreza's at least, there is a rubber seal on the underside of the hoods leading edge which makes me think it would choke this type of intake design without removing/modifying the rubber seal. if it didnt choke it, it would not give it the outside air that the legacy and wrx's are getting, at least.
Old 03-09-2008, 03:52 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
The underside of the hood on my legacy has a small plastic lip to divert air into the hood scoop
rougeben83 is offline   Reply With Quote
Old 03-09-2008, 04:49 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I think the wrx's may have that also. depends which year and which model impreza the OP'er is asking about I guess.
Old 03-09-2008, 05:03 PM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Well I have a 2003. From what i've seen though, the WRX "funnel" goes into the fender for whatever pipe/snorkus is there...whereas on the NA, there is no intake section in the fender - exactly as in the Legacys...
Old 03-09-2008, 05:51 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
my NA (07 2.5i) has a snorkus in the fender, thats why i was looking at the WRX trumpet but thats not the issue really, its if there is any cold air available @ the trumpet mouth or if there is a seal between the hood and grille that would be closing the trumpet off to the outside air.
legacy outback fog light grille on an impreza? Bluefoton Electrical & Lighting 0 01-04-2008 06:51 PM
7 spoke legacy rims on an Impreza? FlyingFishSandwich Tire & Wheel 4 09-21-2005 05:45 PM
Legacy springs on an Impreza cardin555 Brakes, Steering & Suspension 0 03-26-2003 03:49 PM
Legacy B4 Twin-Turbo on an Impreza? wrx_sti_ver4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-17-2002 02:04 AM
Legacy bumper on an impreza? RageHardIntoTheBendies Interior & Exterior Modification 8 12-19-2000 10:46 AM
