Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 03-07-2008, 03:03 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default RCE deals....more like STEALS! RCE Wagons + Konis $799 shipped! Cusco, GTSpec, etc.!
There are some springs out there already for the 08, but frankly, you don't want them. You want these. You've been waiting for these and your car wants these too.
The STI JDM Pink springs for 08 WRX hatch are the first we've seen with rates and a drop that we think is good. Really good. Not super big drop, just 15mm. Solid bump in spring rate to 188 lbs/in front and 171 lbs/in rear.
Give us a call if you're interested, we have these here and as far as we know, there aren't many in the country yet.
NOW $399
2008 STI KW Clubsports
These are going to be very difficult to find for a couple of months....we have exclusive access to the only sets available for the next 4 months!
Racecomp Engineering is proud to announce KW Clubsport Coilovers for 2008 STi! One of the most anticipated suspension options for the new body style Impreza is available now!
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts....these are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008 STi.
These coilovers feature the same inox-line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3's that are due out in May.
KW will provide an option for pillowball mounts front and rear in the future, Right now, Cusco camber plates and rear pillowball mounts are immediately available, as well as Group N top mounts. Racecomp Engineering is also currently in the design phases for 2008 Impreza specific Lowering and Non-Lowering Camber Plates and rear Pillowball mounts.
Limited 1 year warranty.
$2299 shipped
Racecomp Engineering Regular Guy "Black" Springs
We really like these. Mild drop, big bump in spring rate, big change in handling for STi owners. Pretty good ride quality as well.
$329 shipped!!!
Price includes shorter replacement bumpstops. Sale for a limited time ONLY!
Due to increasing materials costs, shipping costs, and the weakening US dollar, Ohlins retail prices went up considerably with the start of 2008.
Retail is now set at $2250 for the Ohlins Fixed Perch Struts.
BUT Racecomp Engineering will continue to offer the Ohlins FP Struts at our usual price of $1949 shipped!
Ohlins Fixed Perch Struts with
RCE Black "Regular Guy" Springs or RCE Yellow Springs
$2229 shipped!
Front and Rear Group N Strut top mounts
$2579 shipped!
Front Whiteline MAX-C Camber Plates and Rear Group N Strut top mounts
$2769 shipped!
Whiteline 24mm adjustable front and 24mm adjustable rear swaybars
Kartboy front and rear endlinks
$3349 shipped!
CALL 410-579-1501
RaceComp Engineering is offline
Old 03-07-2008, 03:04 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Clearing out some parts here at RCE....need to make room for the 997 GT3, the 7 post shake rig, the shock dyno, the candy machine that makes magic candy out of thin air....
WRX OEM Clutch Kit
includes:
Clutch Cover
Disc
Flywheel
throwout bearing
$615
STi Arai Performance Struts and JDM Pink
2005+ STi fitment ONLY
does not clunk!
less then a year old
4 clicks of damping adjustment
http://www.rcephotos.com/photos/albu...0691.sized.jpg
$999
JDM STi Pink Springs
20mm drop front and rear
257/217 rates
$250
Call 410-579-1501
In 2007, RaceComp Engineering answered the call from many Impreza Wagon owners by designing and producing a performance lowering spring designed specifically for Wagons with upgraded struts.
The result is a performance lowering spring with rates perfect for users with Koni Inserts in Wagon strut bodies. Thus, the end user gets none of the usual camber loss from switching to different struts.
RCE Wagon Springs with Koni Inserts
$799 SHIPPED!!!
Yes, $799 shipped. Our regular price on the RCE Wagon Springs is $339 and Konis are usually around $700. So that's a savings of.....a lot.
Why? we just have a massive overstock of RCE Wagon Springs and need your help making room at the warehouse!
Old 03-07-2008, 03:04 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Front and rear Group N's
$1164 shipped!
Front Whiteline Camber Plates
Rear Group N's
$1344 shipped!
CALL 410-579-1501
This won't last long!
Old 03-07-2008, 03:05 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Stoptech 2 pc. Rotors for STi Front
$675 shipped
DBA 5000 2 pc. Front Rotors with DBA 4000 Rear Rotors
$1081 shipped for a front and rear set
DBA Slotted Street Rotors Front and Rear Set
$505 shipped
Old 03-07-2008, 03:05 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Stoptech BBK for STi
$1889 shipped!
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200 F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is available now.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade, high temperature hose far better then other options on the market. There is no need to upgrade. Stainless steel hose clamps are also included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation.
Special intro price of $339 for the new Carbon Kool Brake Kit!!!
Current applications are 2004-2007 STi.
2008 WRX and 2008 STi applications coming soon!
410-579-1501
Old 03-07-2008, 03:06 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
__________________________________________
Racecomp Engineering Tarmac Coilovers
Racecomp Engineering Tarmac II Coilovers for Subaru Impreza
Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. Racecomp Engineering chose KW Suspension to co-brand the Tarmac 2 coilovers due to their remarkable racing heritage, consistent and impressive build quality, and phenomenal presence and support in the United States.
Racecomp is happy to announce the option of having the RCE Tarmac 2 coilovers fully assembled with either Group N strut top mounts or RCE Camber Plates and Rear Pillowball mounts.
Available for:
2002 - 2007 Subaru Impreza STI, WRX sedan, WRX Wagon, and 2.5RS
1993 - 2001 Subaru Impreza Coupe, Sedan, and Wagon
$1939 shipped
With Group N strut top mounts front and rear - $2349 shipped
With RCE Camber Plates and RCE Rear Pillowball Mounts - $2799
shipped
Racecomp Engineering Tarmac I Coilovers for Subaru Legacy
Following the successful release of our coilovers for Subaru Impreza, Racecomp Engineering decided to extend their coilover line to include 2005+ Subaru Legacy. Featuring the same stainless steel technology, limited lifetime warranty, and KW quality as the Tarmac II’s, these coilovers were designed with linear spring rates and valving that mates perfectly for the Subaru Legacy street/track driver.
Available for:
2005 - 2008 Subaru Legacy GT, Spec B, and 2.5i Sedan and Wagon
$1399 shipped!
__________________
Call us for an appointment for installation
www.racecompengineering.com ---
www.GTWORX.com
Cobb - SwiftWhiteline - Cusco - Alpinestars - Prodrive
Ohlins - Moton - KW - Bilstein - STi - Pagid - Ferodo - Piloti
6360 Unit J South Hanover Rd.
Elkridge, Maryland 21075
410-579-1501 Phone
443-370-9000 Mobile
Old 03-07-2008, 03:06 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Camber Plates and Pillowballs
Racecomp Engineering Lowering Camber Plates
These front camber plates were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs as they lower any car by 3/8" WITHOUT sacrificing suspension travel.
Available for:
2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS
$439 shipped
Racecomp Engineering Non-Lowering Camber Plates
These front camber platers were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs. These do not lower or raise the car, and DO NOT sacrifice suspension travel.
Available for:
$439 shipped
Racecomp Engineering Rear Pillowball Mounts for Impreza
Made with the highest quality available aircraft grade 7075 T651 aluminum and using a new extra heavy duty spherical bearing, these pillowball mounts will be up to the task of both heavy track and street duty. These solid mounts provide quicker reactions, more feedback, and a more direct feel from your suspension. Our Rear Pillowball Mounts were developed specifically to provide a solution for Racecomp Engineering Tarmac II coilover users looking for the maximum possible performance out of their coilover system.
Available for:
2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS. Fits coilovers only.
$389 shipped
Old 03-07-2008, 03:06 PM   #8
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
GTSpec Braces
$165 shipped -
GTSPEC FRONT Type D Strut Brace
call for carbon and ti versions!!!
$155 shipped - GTSPEC REAR Type F Strut Brace
$155 shipped - GTSPEC REAR Type F Strut Brace for WAGON
$215 shipped - GTSPEC Fender Reinforcement Braces
$155 shipped - GTSPEC 4 Point Front Ladder Bar
$205 shipped -
GTSPEC Front Lower Tie Brace
$655 shipped -
GTSPEC Subframe Reinforcement Brace (3 piece set)
$185 shipped -
GTSPEC Rear T Brace (2 piece set)
CALL 410-579-1501 to order!!!
RCE
Old 03-07-2008, 03:06 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Cusco Braces
$154 shipped - Cusco Front Type-OS Strut Tower Bar
$154 shipped - Cusco Rear Type-OS Strut Tower Bar
$155 shipped - Cusco Lower Bar Version II
$129 shipped - Cusco Rear Subframe Brace
Old 03-07-2008, 03:07 PM   #10
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Whiteline Suspension
Whiteline Adjustable Swaybars
27mm Front Adjustable Sway Bar - $209 shipped
27mm Rear Adjustable Sway Bar - $209 shipped
24mm Front Adjustable Sway Bar - $189shipped
24mm Rear Adjustable Sway Bar - $189 shipped
$309 shipped - Whiteline Max-C Camber Plates
$319 shipped for motorsports/coilover version
$191 shipped - Whiteline Anti-Lift Kit
$205 shipped for motorsports version
$184 shipped - Whiteline Roll Center Kit
Swift Springs
$279 shipped - Swift WRX Springs
Cusco
$259 shipped - Cusco Motor and Tranny Mounts
GTSpec
$184 shipped - GTSPEC Rear Differential Mount
Old 03-07-2008, 03:36 PM   #11
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Old 03-07-2008, 03:38 PM   #12
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Old 03-07-2008, 03:38 PM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Old 03-07-2008, 03:42 PM   #14
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
space
Old 03-07-2008, 11:24 PM   #15
Durmiente
Member Sales Rating: (2)
Member#: 75771
2002 WRX Wagon
#87 STX
Just ordered a set of wagon shocks/springs/tophats, thanks again for these awesome products and deals! Looking forward to getting my suspension up and running again...
Durmiente is offline
Old 03-08-2008, 05:06 PM   #16
kaliformula
Member Sales Rating: (1)
Member#: 110314
2006 WRX Wagon
LR Defender 90
can i just get a price on the koni inserts shipped to 90703
kaliformula is offline
Old 03-08-2008, 06:07 PM   #17
brainrally
Member#: 3683
2007 Impreza WRX
Shagginwagon
I sent a PM. I have a 2007 Impreza WRX wagon. I wish to purchase the Whiteline 24mm adjustable anti-roll bar and a set of whiteline front endlinks to go with it. My ZIP is 62234.
Brian Schuetz
brainrally is offline
Old 03-09-2008, 11:49 AM   #18
nottofast
Member Sales Rating: (58)
Member#: 89663
1962 Fuji 350
cerelean blue
$129 shipped - Cusco Rear Subframe Brace.................... will this work with a perrin rear sway bar on a 2004 sti?
nottofast is offline
Old 03-10-2008, 03:41 PM   #19
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default Whiteline
Brian Schuetz
Someone already PMed you back right?
Old 03-10-2008, 03:42 PM   #20
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
It should work. Never done it myself, but can't see why it wouldn't.
- Andrew
Old 03-10-2008, 04:45 PM   #21
Superorb
Member Sales Rating: (29)
Member#: 135252
2002 WRX Wagon
86% Operational :(
Any springs for the wagon that don't result in saggy butt? Can you Yellows be used with AGX struts or are the rates too high?
Superorb is offline
Old 03-11-2008, 03:20 PM   #22
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
I wouldn't recommend AGX struts with Yellows. I would however highly recommend our Wagon specific RCE springs + Koni's. Look here:
http://forums.nasioc.com/forums/show...73&postcount=2
- Andrew
Old 03-12-2008, 01:47 AM   #23
jose21
Member Sales Rating: (8)
Member#: 78197
2003 WRX
Ordered a set of the Cusco motor/tranny mounts yesterday.
Jose
jose21 is offline
Old 03-12-2008, 11:32 AM   #24
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Jose
thanks, and of course I took your info down wrong. Call us when you get a chance.
Myles
Old 03-13-2008, 09:51 PM   #25
jdmesk
Member#: 174478
2005 wrx wagon
are the rce springs and koni inserts still on sale?
jdmesk is offline
Closed Thread
Awesome Summer Deals @ IAG Performance! - Whiteline/RCE/Cobb/Kartboy/Tein/ETC IAG Performance Suspension/Brakes/Handling 55 10-09-2009 03:41 PM
Mid-A only deals? RCE suspension parts direct from RCE? Really cheap installs? SWEET! RaceComp Engineering MAIC Vendor Classifieds 34 08-06-2007 07:21 PM
FS: 2006 Impreza 2.5i Sport Wagon - Only 799 Miles - $12900 obo ProdriveRex NWIC Private Classifieds 0 02-26-2007 08:25 PM
Cusco, GTSpec, Kartboy and more! RallySport Direct Suspension/Brakes/Handling 3 07-05-2005 04:52 PM
