Old 03-07-2008, 03:55 PM   #1
moestock
Member#: 121398
2006 2.5i
SRR
Default Can I stiffen up the gas pedal?
The gas pedal in my 2.5i is really light, makes me miss the pedal in my Jeep TJ. Especially when going to and from work with the steel tips on, I can't feel the pedal at all, which leads to over/under reving. My question.. is there any easy way to put a little more resistance on my gas pedal? Would it mess up the electronic throttle control at all? Thanks for any help.
moestock is offline   Reply With Quote
Old 03-07-2008, 04:48 PM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
No. The reason for that is the DBW. It stinks but we have to deal with it.
Gr3en is offline   Reply With Quote
Old 03-07-2008, 06:08 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
I had the same complaint too. You do get used to it after a while, yes I wear steel toes all the time too. I haven't looked to hard at the gas pedal DBW unit but when I did look at it there is no external return spring to replace or adjust. Not sure if you could disassemble it and do some thing about it, thats for some one else to try.
flstffxe is offline   Reply With Quote
Old 03-07-2008, 06:09 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i havnt looked at the hinge on the accel pedal but i bet there is a spring inside of the hinge area and stiffening that spring would do what you are looking for. much easier said than done, im sure. worth taking a look, though.
haha flstffxe beat me by a minute!
"Shouldn't the gas pedal be on the other side?" DoinkMobb Off-Topic 20 03-29-2010 11:39 AM
can i turn up the boost with race gas but no tune? ryanpietro Engine Management & Tuning 2 08-16-2006 05:07 PM
How do I stiffen up the chassis? lildragn11 Brakes, Steering & Suspension 8 03-16-2004 11:40 AM
Whats the exhaust popping sound when you release the gas pedal? samwY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-07-2004 01:49 PM
Ways to stiffen up the steering?? GregUnd Texas Impreza Club Forum -- TXIC 28 01-23-2003 03:16 PM
