Old 03-07-2008, 06:58 PM   #1
turboz523
Member#: 172383
2000 Outback
Default Hybrid 2.5 wrx with n/a 2.5 block
Ok so I've been doing alot of reading on here and trying to get some ideas of which way to go with my wrx. I like the idea of having more torque and power down low associated with a larger block, but the STI shortblocks cost double, triple, or more than what you can pickup a phase 2 n/a 2.5 shortblock for. Now, besides the fact that the sti block is a semi-closed deck vs. the open deck of the n/a 2.5, is there anything else that I need to know, or reason why it wouldn't be good to push to around 350whp using sti rods and a good set of forged pistons? With some porting of the wrx heads and a nicely matched turbo for quick spooling and not too high of boost, seems like it would be a fairly economical build for a fun daily driver.
turboz523 is offline   Reply With Quote
Old 03-07-2008, 10:15 PM   #2
ghostdriver
Member#: 137795
1998 Impreza L
i think if you get the compression right with those pistons you should be good to go with that plan.
ghostdriver is offline   Reply With Quote
Old 03-07-2008, 10:59 PM   #3
scubywagon
Member#: 65967
2004 WRX WGN 2.5
Java Black Pearl
with the money you're going to spend on building that na block, you could buy an sti block and save yourself the headache and time of going the na block route. besides, the sti block is designed with boost in mind and the na block is not.....good luck with whatever way you decide to go
scubywagon is offline   Reply With Quote
Old 03-08-2008, 01:00 AM   #4
poormansporsche
Member#: 79798
On rs25 there are a couple people doing this. Brydon in particular is doing this right now. Should make a good deal of power. Skully did this also and made something like 500whp IIRC.
cheers
poorman
poormansporsche is offline   Reply With Quote
Old 03-08-2008, 09:25 AM   #5
turboz523
Member#: 172383
2000 Outback
I've priced the differences of building an n/a block vs. an sti block and there's no comparison. The sti is way more money, I can't even find an sti block thats damaged and needs a rebuild for what I can find an n/a block in good condition for. And as far as parts, I wouldn't really wanna pay the money for a complete running sti block since I'm gonna swap out the pistons anyway. Just seems like the 2.5n/a for a fairly mild build is the way to go. I'll definitely check out the rs25 list to see what they've done.
Old 03-08-2008, 06:34 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If your goals are for less than 400 hp, The N/A block will be fine, but like any turbo'd motor, make sure the tune is good. Besides, open deck blocks run cooler than closed deck blocks.
~Josh~
Feeler: HELP 2.0 WRX Tons of mods Needs Short Block subbiedo04 Private Vehicle 'For Sale' Classifieds 19 04-19-2008 12:37 AM
any owners with 2.5L wrx with Streetlite Flywheels Mooneyes13 Transmission (AT/MT) & Driveline 2 01-04-2008 12:03 PM
2.0 WRX (2004 4EAT) to 2.5 WRX (2006 4EAT) - worth it? fuzzymemory Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-18-2007 10:44 AM
02 WRX with cobb stage 2.5 minx1225 AccessPort 10 10-09-2006 12:40 AM
Tein S-Tech springs on a WRX - with photos about 1.5" drop ImprezaRS dot com Brakes, Steering & Suspension 13 04-18-2001 07:03 AM
