Old 03-07-2008, 07:41 PM   #1
balub
Member#: 173412
2000 Impreza OBS
Default At what temperature the radiator fan kicks-in?
I have this new scanguage hooked up to my 2000 Impreza OBS OBD2 port. I have been observing the water temperature readings on it and I came up with a few questions.
a. My radiator fan kicks in when it shows about 202 F. Does that seem high to you?
b. The temp gauge on the dash kind of behaves a bit strange. Perhaps it uses a different sensor and calibration. The needle goes past the first mark around 100F and then moves to the center when my scanguage shows 160F or so. Then it hardly moves as the scanguage temp goes all the over 200F. Can anyone explain this?
balub is offline   Reply With Quote
Old 03-07-2008, 08:07 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Both sound normal.
Old 03-07-2008, 08:10 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Sounds about right, the stock temp gauge doesn't move once the temps reach normal operating temps, 81*C/177*F to 96*C/204*F...
wrxdrvr is offline   Reply With Quote
Old 03-07-2008, 10:15 PM   #4
balub
Member#: 173412
2000 Impreza OBS
Thanks for the confirmation. Where are the sensors located in this car? The coolant temp sensor and the temp guage sensor. As I understand, these two are different.
Old 03-08-2008, 08:43 AM   #5
rkramer
Member#: 118209
2002 WRX Sedan
the gauge really isn't a gauge as others pointed out. it is a 3 position indicator. cold, normal, and hot.
radiator fans kicking on...... Baja820 Normally Aspirated Powertrain 8 03-09-2009 11:22 PM
Idle issue with the radiator fans cycle... BBBsti LTD Factory 2.5L Turbo Powertrain 0 03-21-2008 07:28 PM
How-To, Reverse run the radiator fans? makofoto Electrical & Lighting 4 05-21-2004 04:12 PM
How efficient are the radiator fans? Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-28-2001 03:07 AM
Message Board Statistics All times are GMT -4. The time now is 05:39 PM.
