Old 03-07-2008, 07:57 PM   #1
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Default can I losen the clutch pedal?
I still feel depressing the clutch pedal is quite hard. Is there any suggestion how we can lower the amount of effort required to depress the pedal?
Jerry Xu is offline   Reply With Quote
Old 03-07-2008, 08:05 PM   #2
piker28
Member#: 22664
ha irony here is id love to make mine stiffy
but id recommend hitting up the gym its the best way to get used to it
piker28 is offline   Reply With Quote
Old 03-07-2008, 08:07 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
not adjustable. Start doing squats.
flstffxe is offline   Reply With Quote
Old 03-07-2008, 08:14 PM   #4
Jerry Xu
Member#: 36629
07 2.5i
Have you tried a Elise clutch pedal? Sooo nice and low effort.
Old 03-07-2008, 10:00 PM   #5
piker28
Member#: 22664
have you ever tried a auto corolla ah man no clutch pedal youd never have to worry ha
comparin an elise to a subaru crackin me up
Old 03-07-2008, 10:22 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i bet there is a way to change the clutch pedal effort... might be in the hydraulics or clutch itself though. doubt its going to be a built in adjustment. try asking in the drivetrain forum, but be ready for some harassment since the impreza clutch is quite soft, one of the softest i have driven. And i have had some pretty lame cars. goodluck.
Old 03-07-2008, 10:30 PM   #7
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
The clutch is too hard!? wow, damn. You need to exercise sir.
I drove my buddy's 350z, compared to mine. . . . well after that experience, my clutch felt like a feather.
J-Chow is offline   Reply With Quote
Old 03-07-2008, 10:30 PM   #8
bobko
Member#: 64646
1995 Legacy wagon
Green
That's my understanding, too. The clutch effort is based on the stiffness of the spring on the clutch itself, as well as the length of the arm that's used to activate the clutch. You can also get some force multiplication from the hydraulics, but none of these things will be adjustable. A different clutch may have a different spring stiffness, but that's about the best you can hope for.
--Bob
bobko is offline   Reply With Quote
Old 03-07-2008, 11:58 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Subaru's tend to have a stiffer clutch when compared to other econo-type/daily driver cars. Stiffness is also based on the clamping pressure of the pressure plate...you get a higher clamping pressure plate, you get a stiffer clutch pedal...however I don't think there's a lighter pp to begin with.
rougeben83 is offline   Reply With Quote
Old 03-07-2008, 11:59 PM   #10
ZeppelinPie792
Member#: 160287
2007 Impreza 2.5i SE
Newport Pearl Blue
It's electronic in the 2.5i, and is much easier to press down than standard clutch pedals.
Like others have said, you need to grow some muscles if you think it is hard you girly man
ZeppelinPie792 is offline   Reply With Quote
Old 03-08-2008, 10:04 AM   #11
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i didnt know the 2.5i had an electronically actuated clutch. there is a hydraulic cyl on the trans case, so it must be hydraulic from there to the clutch, but you are saying that the clutch cylinder is electronically actuated?
Old 03-08-2008, 10:44 AM   #12
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
I have no idea. I just know that my clutch is "electronic"
Old 03-08-2008, 11:37 AM   #13
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Well, that's not right. There are two sensors on the clutch pedal. One at the top for the cruise control, and the other at the bottom for the starter interlock.
Counterfit is offline   Reply With Quote
Heard a Loud Crack and then the Clutch Pedal Flew to the Floor :( greenc51 Transmission (AT/MT) & Driveline 16 09-17-2009 01:32 AM
Can I buy a clutch pedal assist spring OR chapstien Transmission (AT/MT) & Driveline 2 02-19-2008 08:17 AM
Is It Possible to Lighten the Clutch Pedal? stewgod Transmission (AT/MT) & Driveline 13 09-29-2004 02:06 PM
Whats a good aftermarket clutch that isn't too stiff on the clutch pedal edkwon Transmission (AT/MT) & Driveline 6 09-09-2002 11:15 PM
