Old 03-07-2008, 10:08 PM   #1
BUCA
Member#: 103985
2006 Impreza Wagon
Default Has anybody swap 2.5rs engine into Forrester?
I've searched and cannot find anything about swapping a 2.5rs motor into a SOHC forrester ( I have a 2000 forrester 5 speed )
Has it been done?
Please help....
BUCA is offline   Reply With Quote
Old 03-07-2008, 11:08 PM   #2
ghostdriver
Member#: 137795
1998 Impreza L
i havent done it but i imagine it would be very simple. they are just different versions of the same motor.
why are you asking about the swap? do you want dohc or are you just looking for a replacement?
ghostdriver is offline   Reply With Quote
Old 03-08-2008, 08:08 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
direct replacement if it's same year motor (more involved if it's DOHC, plus no point of swapping that due to overheating problems)
Hyper is offline   Reply With Quote
Old 03-08-2008, 08:43 AM   #4
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
yeah, for all but 1 year (98, btw) 2.5RS, its the same motor as the 2000 Forester for the most part. Same power, no reason to swap unless you blew your forester motor, and then yes, its pretty much a direct drop in and plug in your forester harness to the new motor.
My son's mother has an '00 RS with an 03 2.5L driveline in it. Very drop in.
neko is offline   Reply With Quote
Old 03-09-2008, 09:42 PM   #5
BUCA
Member#: 103985
2006 Impreza Wagon
I'm asking because I purchased a used forrester with a blown motor, I was just trying to find out if it was possible or worth it...
If it is a direct drop in wouldn't the ECU cause a code or not work?
Since it is the same power as an 2.5rs DOHC then I'll just go and replace the SOHC engine
Thanks for the information and help
Old 03-10-2008, 10:56 AM   #6
brandon
Member#: 1183
09 Legacy, 76 Mini
64 Lotus Elan, 70 Elan +2
BUCA,
I did this for my parent's 99' Forester a little over a year ago. Yours is a Phase 2 SOHC engine, which I'm sure you already knew. Any other SOHC Phase 2 engine from any subaru would bolt right in. So that could be Forester, Legacy, Impreza, Baja. I believe there was a change in 2005 which makes things a little more difficult, but 99 through (and including) 2004 works just fine. That gives you quite a bit to choose from, especially given the number of people swapping STi motors into thier cars.
I used a very low mileage 2004 2.5RS engine for the swap, and there were just a few things on the intake side that needed to be swithed over. They were very obvious, and with both engines sitting next to each other on the floor, easy to do. The 2004 runs a slightly higher compression ratio, but the existing computer hasn't had any trouble with it at all.
Try to find the newest motor you can, as Subaru was making incremental internal improvements all the time. The later motors are a lot less prone to head gasket problems (likely what you curently have), and are a heck of a lot less noisy.
brandon is offline   Reply With Quote
Old 03-10-2008, 02:39 PM   #7
BUCA
Member#: 103985
2006 Impreza Wagon
That is correct.
Looks like I'll be looking for a 2.5rs
I appreciate your time and knowledge, you guys are great.
Old 03-13-2008, 06:30 PM   #8
Yeiran
Member#: 113892
01 Impreza 2.5RS
Silverthorn Metallic
http://www.subaruforester.org/vbulle...ad.php?t=30320
look there. I'm almost* done. Just won't fire up! anyone have any ideas?
Yeiran is offline   Reply With Quote
Issues with swapping a 1999 2.5RS longblock into a 2002 Forester ??? Towona Normally Aspirated Powertrain 13 02-11-2010 09:29 PM
Odd swap: 2.5RS engine EJ251 into my93 L wagon EJ18 / EJ20k poormansporsche Subaru Conversions 5 04-29-2009 11:34 AM
will a 99 2.5rs engine bolt into a 99 legacy outback? IllNastyImpreza Subaru Conversions 18 06-27-2007 11:26 PM
Mechanic needed for ej20t-2.5rs engine swap in Central Florida 2.5rs98 Subaru Conversions 0 04-01-2007 01:07 AM
2.2 to 2.5rs engine swap soupedscooby Normally Aspirated Powertrain 3 10-01-2002 09:41 PM
