Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 03-08-2008, 03:54 AM   #1
Member#: 123103
2003 WRX
Full 07 STI trans
Default Harbor Freight Compression Tester
Not sure if this is the right thread but hereitgoes!
I bought this and decided to do a compression test. I have done one once before with a different tester that worked fine. I bought this one from H-freight for like 5 bucks or something and it looked ok! I began to do the test and I worked fine. However the design of the tester is flawed. The adapter to screw into the plug socket comes loose of the actual hose and the gauge. This means that you can screw in the adapter to the plug hole in the head without the hose. The first two cylinders worked out fine. However on the 3rd cylinder the adapter got stuck in the head. Then came the problems. After about an hour my friend figured that we could hollow out an old spark plug and screw it into the adapter and thus break it free from the head. The design of this tester is flawed simply because the adapter comes loose, there is no mechanism to lock it in place. That is what caused it to become stuck. It turned a 1/2 hour job into a 2 hour job.
So just a warning to people if they buy this tester, be careful not to get the adapter suck into the head, otherwise... you have to pull the engine, or hollow out an old spark plug.
rexspeedmaster is offline   Reply With Quote
Old 03-08-2008, 12:34 PM   #2
Member#: 34683
2015 WRX Premium
Ice Silver
or buy help! brand spark antifoulers, which are designed to do the same thing. remove broken spark plugs.
haloseven is offline   Reply With Quote
Harbor Freight Cordless Impact Wrench STI4ME Car Part Reviews 15 10-20-2008 04:02 AM
Sale: Harbor Freight US General Alum. race jack, $85 ! Cosworth Motorsports 34 02-11-2004 10:41 AM
SWEEET deal at Harbor Freight for 48 hours crazyhorse South East Region Forum 7 02-04-2004 09:22 PM
Great Deal on Harbor Freight Racing Jack STI4ME Car Part Reviews 16 12-26-2003 04:49 PM
Need loaner tools, Pepboys/Harbor Freight=suck. HS WRB-rex Mid Atlantic Impreza Club -- MAIC 6 06-05-2003 09:14 PM
