Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 03-08-2008, 12:33 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default Timing belt cover randomly BROKE and ate my T BELT !
so I was on the way home from work yesterday, and I smelled a burning plastic smell....
it was getting worse and worse.
So I pulled over and did a quick run-a-round the car to look for burning or smoke or whatnot... and It had stopped.
So I drove home without anymore burning...
when I got home I popped the hood to find out my Timing belt cover had RANDOMLY broken and fallen on my Timing belt !
not only did I have to rip the cover off, but my T-Belt is now slightly worn in the middle where it was rubbing the cover !
What do you guys think ? I can barely feel the difference in thickness when I rub my fingernail over the belt...
but it botheres me that this would happen...
not only this, but my Powersteering just crapped the bed again too
IllNastyImpreza is offline   Reply With Quote
Old 03-08-2008, 03:22 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I'd replace the belt (it's an interference engine - not worth the risk)
Old 03-08-2008, 03:29 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
it was my 98 Legacy L
IIRC the pre hydraulic lash adjuster EJ22 engines are non interference...
but what about the 98 ???
Old 03-08-2008, 05:09 PM   #4
subtoy
Member#: 173384
The 2.2 is a non valve bender
The 98 RS is a valve bender
subtoy is offline   Reply With Quote
Old 03-09-2008, 09:32 AM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
thats funny
Old 03-09-2008, 11:39 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i do not believe the cover randomly broke.
covers do not randomly break
something was rubbing up against it or prying against it to have this occur
replace the cover
replace the belt
do cam/crank seals while you're in there
and look for anything out of alignment/place.
Jamie
Old 03-09-2008, 11:57 AM   #7
flstffxe
Member#: 155358
2008 Forester
Steel Silver
I agree with Jamie, those cover typically don't fall apart on their own.
It may even be a small oil leak that was slowly deteriorating the cover to the point to where it became brittle. Like she said replace both the belt and the cover, both are cheap. Time spent now may save you time down the road, or on the side of it.
flstffxe is offline   Reply With Quote
Old 03-09-2008, 11:58 AM   #8
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
^ i have no idea what would have possibly gotten in there and caused it to break...
the engine side of the cover broke and caused the far side of the cover to drag on the belt... it had a decent sized hole in it like It had been hit with something and then torn off....
verry odd.
I will add the above maintenance to my list...
My power steering came back on again for the 2nd time
I've got a quite a maintenance list now
Old 03-09-2008, 12:30 PM   #9
scooterforever
Member#: 55011
[Raises hand]
I have actually had my timing cover break on me. Drove the car home one evening, everything as fine, and the next morning at start there is a nastly rubbing sound. I drive a hundred feet, then circle back and park the car at home. I flatbedded it to my tuner.
The timing belt plastic cover had cracked, and a piece was coming in direct contact with the belt. We fixed the crack, and determined given the short distance I drove on it that the belt was fine.
I agree, timing covers just don't break on their own... but mine did. This was with my new block, so it could have been an issue waiting from when the cover was put back on with the new engine. My personal theory is that overnight with the temperature drop (it was starting to get cold) the metal changed just enough that it induced a lurking stress crack in the cover to finally break.
But... yeah... it happened to me.
scooterforever is offline   Reply With Quote
Old 03-09-2008, 04:02 PM   #10
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
^ yeah that day the temperature had gone from about 25 at night to almost 60 during the day... that might have been part of it...
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
timing belt broke wonder how my vavles are. pics.. robo1040 Mid Atlantic Impreza Club -- MAIC 66 03-06-2010 06:04 PM
Timing belt cover bolt broke aboes81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-20-2009 02:25 PM
AC belt ate my timing cover mowgli29 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-02-2009 09:31 AM
WTB: Belt covers for block. Last friday, my belts cut a hole in my coolant line.... psyber_0ptix Mid Atlantic Impreza Club -- MAIC 5 12-20-2004 05:46 PM
