Old 03-08-2008, 03:55 PM   #1
geoff_paulsen
Member#: 109318
Default What maintenance is due @ 150k?
I own a 2002 wrx with 150,000 k's. I have owned the car since 100,000k's.
What maintenance is due at this time?
geoff_paulsen is offline   Reply With Quote
Old 03-08-2008, 04:16 PM   #2
gtfaded
Member#: 142322
2002 wrx
wrb
probably anything you have the money for, do you know what the last maintenance was?
gtfaded is offline   Reply With Quote
Old 03-08-2008, 04:50 PM   #3
geoff_paulsen
Member#: 109318
I do all my own maintenance and repairs.
-diff fluids changed within last 10k
-fuel filter within last 5k
-spark plugs at 110k
-coolant at 110k
-trans fluid 10k
-brake fluid 10k
Old 03-08-2008, 08:56 PM   #4
jetskibucky
Member#: 136694
07 STI LimitD #242
SPW Stage 2+
I hope the timing belt has been changed sometime in the past. If not, that car is a ticking time bomb.
jetskibucky is offline   Reply With Quote
Old 03-08-2008, 09:06 PM   #5
mikeythejew
Member#: 141672
-coolant at 110k
-trans fluid 10k
-brake fluid 10k
Sounds as if you already know what your doing.
mikeythejew is offline   Reply With Quote
Old 03-08-2008, 09:07 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Note he is in Canada and his mileage is in kilometers NOT miles, so 150K kilos = 90K miles. The car is not overdue for a timing belt.
Old 03-08-2008, 09:08 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if it hasn't been done, as said above, definitely do the timing belt (and tensioner, and the water pump) - since you have to remove them anyway, might as well replace all the other belts, too. Other than that, give the car a good look over - check CV joint boots, ball joint boots, brake lines, any rubber lines under the hood which might have hardened up (esp. around the turbo), maybe replace the pcv valve, clean the throttle body, etc.
Old 03-08-2008, 11:24 PM   #8
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Look in your manual. There is a bunch of stuff that should be done every 50,000 km (30,000 miles). It sounds like a lot of it has been done recently though. I would do the air filter and maybe the coolant.
Mike Wevrick is offline   Reply With Quote
Old 03-08-2008, 11:35 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
front wheel bearings
Old 03-09-2008, 01:53 AM   #10
dbrunner
Member#: 122171
New turbo
Maybe not, but thats what I'm going through right now with my 113k mile WRX. That little TD04 has treated me well.
dbrunner is offline   Reply With Quote
Old 03-10-2008, 11:14 PM   #11
geoff_paulsen
Member#: 109318
Is there any lifter servicing? I seem to have some chatter on morning starts.
Old 03-11-2008, 12:42 AM   #12
mr2fastn2fine
Member#: 174100
Yes most of the time, the timing belt is the most important to change.
mr2fastn2fine is offline   Reply With Quote
Old 03-11-2008, 09:01 PM   #13
geoff_paulsen
Member#: 109318
HUH? that dont make sense.
