Old 03-08-2008, 08:15 PM   #1
GochYou
Member#: 169479
2002 Hybrid WRX
Pro-Tune SpeedIndustry
Lightbulb Installing a Wideband o2 , by Innovate ?
I have recently purchased a kit from Innovate motorsports, The kit includes Innovate LC-1 & Tactrix OpenPort Tune & Reflash bundle. I was wondering if anyone has used a similar set up, or have installed a wideband themselves, and if I can get any pointers from you guys.
GochYou is offline   Reply With Quote
Old 03-08-2008, 08:38 PM   #2
GochYou
Member#: 169479
2002 Hybrid WRX
anyone with some helpful tips?
Old 03-08-2008, 11:02 PM   #3
subyduby
Member#: 107889
04 wrx 16g'd
email Rich at Precision Tuning. He is the master of it all and I recently had mine installed there.
subyduby is offline   Reply With Quote
Old 03-08-2008, 11:35 PM   #4
WeldingHank
Member#: 98645
2002 WRX Wagon
check out the openecu forum in the engine managment section.
WeldingHank is offline   Reply With Quote
Old 03-09-2008, 02:41 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
theres been a bunch of debate in the forum over o2 sensor placement, some say as close to the turbo as possible on the downpipe side, others , 6 inches away.but consensus that i've come across even on other forums say no more than 15 inches away from the turbo to get a good reading. id say call all the wb 02 manufacturers and get a group consensus.
fastnoypi is offline   Reply With Quote
Old 03-10-2008, 06:18 PM   #6
GochYou
Member#: 169479
2002 Hybrid WRX
Exclamation Wideband o2 install
So When installing this o2 sensor I believe I have to calibrate it to read fresh air before installing it into the exhaust system? Also I was just going to install the wideband into the factory spot, is this not the best decision? And if not how would you properly install it?
Old 03-10-2008, 08:48 PM   #7
subyduby
Member#: 107889
04 wrx 16g'd
I have my sensor installed in the bung of the DP. Yes it does need to be calibrated, but i am not exactly sure as to how.
Old 03-11-2008, 06:29 AM   #8
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Rexnet DIY HERE
wrxsti.l is offline   Reply With Quote
Old 03-11-2008, 09:31 PM   #9
GochYou
Member#: 169479
2002 Hybrid WRX
Ok so I have the kit ready to install and I am going over the instructions and I am confused on if the wideband is installed instead of the OEM sensor, or if I keep the OEM sensor as is and install the wideband as well?
Old 03-12-2008, 08:46 AM   #10
billy77
Member#: 151334
2004 wrx
WRB 2.5SB STAGE 2
I Have A Megan Dp With A Bung On It, So I Put My Wideband There. Still Have The Factory One In
billy77 is offline   Reply With Quote
Old 03-12-2008, 12:05 PM   #11
GochYou
Member#: 169479
2002 Hybrid WRX
So leaving the OEM sensor on the car will not affect the WBO2 at all, how is the WBO2 supposed to calibrate the EFI computer or the main ECU to run the air/ fuel the way i want it to?
Old 03-12-2008, 12:08 PM   #12
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Do your self a favor and run a dedicated ground wire to the engine to avoid all the calibration problems.
2gnt2wrx is offline   Reply With Quote
Old 03-12-2008, 12:10 PM   #13
GochYou
Member#: 169479
2002 Hybrid WRX
Basically all the WBO2 sensor gives me the ability to read and calibrate the air/fuel ratio, and by keeping the OEM sensor in the car and connected to the EFI it runs off the OEM sensor? So in this scenario if my car is running rich, and i want to lean it out, using the LC-1 can help me change the cars reading to do so?
FS: Innovate Wideband O2 KD-16 LC-1 Kit BigBoosting Private 'For Sale' Classifieds 3 04-19-2006 09:19 AM
FS: NEW Innovate Motorsports LC-1 Wideband o2 sensor kit dexterous Private 'For Sale' Classifieds 5 04-06-2006 10:06 PM
FS: wideband o2 kit: innovate lm-1 new in box LotusDriftx Mid Atlantic Impreza Club -- MAIC 7 06-13-2005 12:11 PM
FS wideband o2 kit; innovate lm-1 New in box LotusDriftx Private 'For Sale' Classifieds 4 06-13-2005 09:28 AM
Innovate motorsports LM-1 wideband o2 SmoknWRX Private 'For Sale' Classifieds 1 01-30-2005 02:35 AM
