Old 03-08-2008, 09:55 PM   #1
JoD
Member#: 106688
2006 Legacy GT Wagon
Roxie's got moxie.
Default Oh noes! Check engine light and more... HELP!
Recently 13" of snow fell in the area. The only problems I encountered was getting into/out of my garage. I have a 2006 Legacy GT wagon (automatic)
Tonight on the way back into my garage, I hit a stubborn patch of snow, and tried to power through it by backing up, and then going forward a few times. On the last try, all of a sudden, every light on the dash lit up, and there was an awful, awful smell coming from the car. Apparently, I made it mad.
After getting the car in the garage, shutting it off, and letting it calm down, I turned it back on. The check engine light is on, and the cruise control light is flashing. (I haven't used the cruise in awhile). Can anyone give me an idea what might be wrong?
Thanks,
Jody
JoD is offline   Reply With Quote
Old 03-08-2008, 10:09 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
going to have to get the codes pulled.
the cruise light will come on anytime the CEL does. Any kind of failure with engine control system it disables the cruise control.
It could be many things.
Old 03-14-2008, 04:08 PM   #3
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
Yeah, it's generally a bad idea to plow something that doesn't want to be plowed, and then force it Unless you're in college. Then it just takes a few drinks.
So did you figure out what was wrong?
Asinine is offline   Reply With Quote
Old 03-17-2008, 03:52 PM   #4
anechoic
Member#: 28601
2007 Outback
gold opal something
I know both of my Legacies (1995, 2000) would make a horrible smell from the vicous coupler if I had to drive in deep snow. But those were both manual, your automatic has a different mechanism. I suppose ATF would probably smell pretty bad if you overheated the tranny.
If the snow was deep, could it have knocked an oxygen sensor loose?
But yeah, get the codes pulled. Hopefully that will at least provide some clues. Unfortunately, some of them are the automotive equivalent of "PC Load Letter".
anechoic is offline   Reply With Quote
HELP!!!!!Check engine light and cruise light on joe198219 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 01-17-2006 07:07 PM
Cruise Control and Check Engine Light.. i need help!! PhatAsiankid03 Electrical & Lighting 9 04-02-2004 03:07 PM
help check engine light and abs light??? greentre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-15-2002 05:11 AM
Check Engine Light, and no help from the dealership RChampion Normally Aspirated Powertrain 8 08-19-2002 11:43 AM
Uh Oh my check engine light is on Tainted South West Impreza Club Forum -- SWIC 21 07-27-2001 12:18 PM
