Old 03-09-2008, 01:27 PM   #1
Davenow
Member#: 23676
Default Dropped the cash for coatings on my new pistons. Convince me it wasnt a waste of $$
Ok so I know that a lot of people recommend it.
A lot of people recommend a lot of crap that doesnt do anything, or does very little.
That said, I know there has to be a reason they recommend it.
So, does it REALLY make that much of a difference? What exactly does it accomplish?
Does the coating on the dome REALLY make the piston hold up better?
Does the coating on the dome REALLY make more power like some coaters claim?
Does the side coating REALLY make the piston slide easier?
Does the side coating actually make more power like some coaters claim?
Here are some pics of one of my new sexy pistons BTW. CPs coated by CP.
Old 03-09-2008, 02:40 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Yes, it acts as a heat barrier and can protect it from short term damage caused by ping/detonation.
Not really, it can however help to cover up signs of a bad tune, detonation. With a proper tune you should be able to achieve the same #s on the dyno with or with out the coating.
Yes, it adds a solid layer that acts as a sacrificial lubricant. It also fills in minor imperfections in the surface of the pistons making the even smoother.
No, it does not "make" more power. It can however help to reduce friction, reducing friction frees up power lost to internal drag. In turn this does show up as higher # when you get to the dyno. Are you making more power, no. you are just not wasting it in the engine its self.
The gains seen from the coating are minimal. However the protection they offer should some thing go wrong, say un-metered air entering your intake that could cause a lean condition that can potentially have damaging effects is a benefit. It can give you enough time to locate the issue before destroying a piston.
flstffxe is offline   Reply With Quote
Old 03-09-2008, 02:41 PM   #3
xerox445@yahoo.com
Member#: 111556
2006 STI
They look sweet....lol
If you don't bust any ringlands if the car is detonating, it wont melt through the piston.
You should have a tighter piston to wall clearance with the side coating, with less friction.
xerox445@yahoo.com is offline   Reply With Quote
Old 03-09-2008, 02:49 PM   #4
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
They claim it makes it hold up to detonation better as well.
Does it? I would think that the thicker top ringland and the special shape to the second ringland would do way more.
Defiant Autospeed is offline   Reply With Quote
Old 03-09-2008, 03:37 PM   #5
wrxhard
Member#: 108091
I read an article in engine masters challenge about how all of the top competitors used a ceramic dome coating on the pistons. An interview with one of the builders said he used the coating because he built his motor to be able to take detonation. He literally set it up to detonate under certain load conditions so it could make the most power at others. This is a naturally aspirated v8, so it doesn't DIRECTLY corelate, but an IC engine is an IC engine ya know and strength is strength, so alittle bit does... maybe???
wrxhard is offline   Reply With Quote
Old 03-11-2008, 12:37 AM   #6
charliew
Member#: 125304
Coated pistons have been used a long time. Even harley coated the skirts in their motors more than 12 years ago, mainly to slow piston wear and make them quieter. If the tractors of motorcycles thought coatings were important and spent the money on it you can bet it helps. Coating the tops also helps keep the heat in the combustion chamber and out of the piston. This was a reason subie used squirters, to keep the piston temps. managable. Are you also going to coat the combustion chambers to also contain the heat? There is no reason to allow any motor to detonate as there is never going to be a coated piston built to withstand detonation. Thats what engine management systems are for. Coatings lower oil temps. and allow more timing by controling heat better.
Charliew
charliew is offline   Reply With Quote
Old 03-11-2008, 12:53 AM   #7
flycaster
Member#: 60142
2011 WRX
Grey
Heh, what needs a "coating" is that poor guys head. Jeeze, tell him to put a hat on.
flycaster is offline   Reply With Quote
Old 03-11-2008, 01:53 AM   #8
Chi_San
Member#: 53558
2002 WRX Wagon
Aww, it's just a little sunburn.
Ceramic is tough stuff, and it's great at reducing friction. A ceramic RX-7 motor typically holds up better than a non ceramic motor.
Another option I can think of when building my motor.
Chi_San is offline   Reply With Quote
Old 03-12-2008, 10:55 PM   #9
Davenow
Member#: 23676
Im going to call swaintech about coating the combustion chambers, it depends how much $$$$ they want. I am hitting the wall on this build financially.
Old 03-14-2008, 01:25 PM   #10
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
how much does CP charge for their coating service?
cnstman is offline   Reply With Quote
Old 03-14-2008, 03:54 PM   #11
manxaru
Member#: 123021
I'm having my coatings done at Polydyn - http://www.polydyn.com
I believe they charge $22 for piston crowns, $38 for complete pistons and $33 per combustion chamber, including the bottom of the valves.
Since the turbo shows on my car, I'm also having the exhaust housing done, which keeps it looking good and holds in a little more heat.
manxaru is offline   Reply With Quote
Old 03-14-2008, 04:36 PM   #12
sama lama
Member#: 136231
95 LX Impreza
blue
It should reduce friction on pistons an cylinder walls and short skirt pistons create more friction. It should reduce oil temps especially on long high boost events.
sama lama is offline   Reply With Quote
