Old 03-09-2008, 09:01 PM   #1
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Default Normal noise at startup?
Just did TGV deletes and turbo inlet hose along with some PnP work,... got the car back together and when you turn the key in the ON position you can hear a pumping or whirring noise from the front passenger side fuel rail area. The TGV motors or any of that are on the car. We were very careful in hooking everything back up properly including all vacuum, electrical and fuel hookups. There are no leaks. The car wont start but I think that may be due to an incorrect AP map.
Any thoughts?
jmlaser is offline   Reply With Quote
Old 03-09-2008, 11:53 PM   #2
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
Well, I see you live in Ohio....and in the news that it is pretty cold there right now. One of the main issues with the TGV deletes is cold starting. I hope this is your problem.
Just my .02 cents.
camshaft06 is offline   Reply With Quote
Old 03-10-2008, 02:04 AM   #3
jmlaser
Member#: 125529
02 WRX 18G EJ205
no start was a crank sensor not being plugged in issue
noise must be normal, the car starts now!
Old 03-10-2008, 03:04 AM   #4
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
good deal.
Marlons101 is offline   Reply With Quote
Noise at startup globalsystems Normally Aspirated Powertrain 2 07-23-2008 12:50 PM
Normal noise at startup? jmlaser Newbies & FAQs 0 03-09-2008 08:39 PM
Stange Noise at Startup kaitak98 Newbies & FAQs 2 09-07-2004 02:27 PM
('93-'01) Weird water pouring noise at startup! 97 Impreza Outback Sport itsmywifescar Impreza Forum 4 10-24-2002 02:54 AM
Tranny noise at startup when cold, clutch pedal out... Cosworth Transmission (AT/MT) & Driveline 4 01-09-2002 02:20 PM
