Old 05-14-2001, 06:05 PM   #1
25psi
Member#: 3086
2001 2.5 RS
Post I FINALLY found my squicking noise.
4 month and like 7 mechanics and I finally tracked down that friggin noise by myself ( With borrowed stetoscope).
To refresh once memory - Squicking/Rattling noise coming from what seems shifter assembly or somewhere in the motor. Loud and annoying but sometimes barely niticable. Always there upon start or shut down.
Sounds like fun? Well, it was not! I was in HEARING pain for 4 month till today.
Want to know what it was and how I fixed it?
I'll give each of you 3 tries to get it right.
I'll log on later and will let you know what it was for real. Have fun.
Eugene
25psi is offline   Reply With Quote
Old 05-14-2001, 06:08 PM   #2
Keith
Member#: 191
2012 J train
Brown
Post
loose bolt
Keith is offline   Reply With Quote
Old 05-14-2001, 06:10 PM   #3
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Post
Rock stuck in the exhaust shielding.
david2z4 is offline   Reply With Quote
Old 05-14-2001, 06:12 PM   #4
Snowman
Member#: 3070
2009 Outback XT
Post
If each one of use gets 3 guesses then this will be the longest thread in internet history at 19800 posts. If I ever get this squeaking noise, I will find it before you post your answer.
Thanks, you've been a ton of help to 6600 people.
Snowman
Bad spellers of the world, UNTIE!!!
EDIT: Forgot my three guesses.
1. Operator head space and timing.
2. Durablater valve shunt.
3. You might be low on radio wave grease.
[This message has been edited by Snowman (edited May 14, 2001).]
Snowman is offline   Reply With Quote
Old 05-14-2001, 06:16 PM   #5
Loki
Member#: 4543
2003 WRX
Lightbulb
Loose heat shield
Loose aftermarket shift knob
Sunglasses in the dash compartment (been there, done that)
My 3 guesses.
~Loki
Loki is offline   Reply With Quote
Old 05-14-2001, 06:21 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
<FONT face="Comic Sans MS">I bet is was a bracket rubbing against the firewall
Brian
AIM: captaindamorgan ICQ: 84483950
http://ravensblade.cjb.net
NASIOC: Now with 20% more caffeine!</FONT f>
Old 05-14-2001, 06:24 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Muffler bearings?
Old 05-14-2001, 06:58 PM   #8
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
1) loose nut in the passenger seat. (This one is mine, still haven't found it.
2) Broken engine mount (one side only).
3) Broken bolt in shift linkage.
Revision is offline   Reply With Quote
Old 05-14-2001, 06:58 PM   #9
25psi
Member#: 3086
2001 2.5 RS
Post
Wicewa$$es Snowman and NU. Haha, very funny.
Brian, dude! Do not spoil whole fun if I told you!
Anyhow, since that Mr.Big Mouth yeaped it away already here it is.
There is a tiny Alumnium Tin bracket on the top of transmission casing below/infront of firewall. So, it was S shape bent. One side of an S was sitting on VIBRATING trany case (STi Mounts) and other end was effectively sckreeching against firewall.
Well, now you know! Go impress your friends.
Eugene
PS: Air box must be out to see that friggin bracket.
Old 05-14-2001, 07:41 PM   #10
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I had the same exact problem. My dealer found the problem in less than 5 minutes. There were wires and some metals touching the transmission housing, so those made squeaking and rattling sound in my car. That sound drove me nuts for 3 months!
tmat3 is offline   Reply With Quote
Old 05-14-2001, 07:56 PM   #11
25psi
Member#: 3086
2001 2.5 RS
Post
WOW Good dealer man! AS good as me.
Who is your dealer and where?
Eugene
Old 05-14-2001, 08:11 PM   #12
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Goldstein Subaru in Albany. Although I live in NYC (like you), I got my car in Albany.
Old 05-14-2001, 10:55 PM   #13
rosss
Member#: 1841
1999 Impreza RS
Post
I had a funny rattle in the back end of my car. Finally found it by taking out the back seat. Conveniently I also found the wrench I'd lost when I was installing my harness
Sean
rosss is offline   Reply With Quote
Old 05-15-2001, 01:06 AM   #14
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Smile
My cat's breath smells like cat food.
TaiChih is offline   Reply With Quote
FINALLY found my forester xt JasonLI25T Newbies & FAQs 27 08-11-2008 05:26 PM
So i finally found my boost leak! speedemon9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-26-2007 11:41 PM
finally found my digital camera steve Vancouver Impreza Club Forum -- VIC 15 04-12-2005 05:21 PM
I think I finally found my new breffas food beachbum Off-Topic 15 12-28-2004 01:19 PM
OMG! I finally found my Dial 7 CD! chkltcow Off-Topic 0 08-07-2003 08:45 PM
