Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 03-11-2008, 03:20 PM   #1
dg_performance
Member#: 166392
1996 240sx
Default New clutch slips at 5lbs?
Just got a new clutch installed in my ej20 wrx.
It is a 6 puck rated for 320hp give or take.
It is really grabby and engauges hard from a dead stop in first gear as i would think it would be.
My problem is that it starts to slip at 5psi already and i am not getting on it just easy cruisin with a little roll on of the throttle.
Is this normal for break in time.... i only have 50 miles on it?
thanks.
dg_performance is offline   Reply With Quote
Old 03-11-2008, 03:37 PM   #2
dg_performance
Member#: 166392
1996 240sx
forgot to mention this is an older 95 with cable clutch so it is not hydrolic!
Old 03-11-2008, 04:14 PM   #3
kimball
Member#: 144465
2004 STi
black
There is no break-in for a clutch,and slippage will eventually glaze the disc and ruin it. You could have an adjustment problem like no free play,or preservative grease might not have been cleaned from the pressure plate or flywheel,or other possibilities. Don't allow slippage until this is sorted out.
kimball is offline   Reply With Quote
Old 03-11-2008, 04:21 PM   #4
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
Way to spread mis-information. There IS A BREAK-IN for clutches, it is typically 200-300 miles which generally calls for no launching and limited throttle, though no launching is generally enough.
Also OP can you link to which clutch? Most 6 pucks are rated for 400+TQ.
sluflyer06 is offline   Reply With Quote
Old 03-11-2008, 05:43 PM   #5
kimball
Member#: 144465
2004 STi
black
I don't know much about racing clutches, but I have installed several hundred street clutches. A clutch that is designed for the engine's torque output should not slip when new.
Old 03-11-2008, 06:23 PM   #6
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^ the break in period in not so it doesn't slip. It is so the disc wears into (mates) both the flywheel and pressure plate, thus seating fully. Not riding on a high spot on the disc... should there be one.
flstffxe is offline   Reply With Quote
Old 03-11-2008, 06:42 PM   #7
Chino Bling
Member#: 129743
2009 335i
Jet Black
it's the same concept as new brake pads and rotors
Chino Bling is offline   Reply With Quote
Old 03-11-2008, 06:49 PM   #8
jays05
Member#: 78165
05 STI 35r + e85
No break-in is needed with puck clutches AFAIK.
jays05 is offline   Reply With Quote
Old 03-11-2008, 09:50 PM   #9
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
you can't neccesarily make a blanket statement like that. Break-in procedures whether there is one or not really depends on the clutch material, which can be different on any given clutch type given it be full face/segmented/pucked
Old 03-12-2008, 11:41 PM   #10
dg_performance
Member#: 166392
1996 240sx
The shop told me to see what happens after 400mi and go from there so i am not gonna get all worried till i have some miles on it and give the break in period a chance to work?
Clutch slipping at 32K miles? wrxetta Transmission (AT/MT) & Driveline 21 12-07-2005 07:34 PM
clutch slip at only 90k? crxgator Transmission (AT/MT) & Driveline 15 06-01-2005 12:27 AM
Clutch slipping at 18k miles? thebusiness999 Transmission (AT/MT) & Driveline 1 04-23-2002 12:16 AM
what hp/tq does the stock clutch slip at? Eric SS Transmission (AT/MT) & Driveline 3 02-04-2002 06:26 PM
Clutch slipping at 19k miles? Angelo General Forum Archive 1 01-22-2001 09:50 PM
