Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 03-11-2008, 05:27 PM   #1
4pOwnag3
Member#: 53200
2004 S60R
Gray
Question used treadmill - warning signs
So I went on craigslist to search for a used treadmill and found a couple close to home. Emailed the sellers and they told me to come take a look. So, what should I look out for when getting a used treadmill? Are there any signs of imminent failure?
4pOwnag3 is offline   Reply With Quote
Old 03-11-2008, 05:27 PM   #2
SkirtBoy
Member#: 11056
2009 MB CLK 350 CPO
Black on Tan
This is just plane silly.
SkirtBoy is offline   Reply With Quote
Old 03-11-2008, 05:29 PM   #3
boxered
Member#: 61884
Skidmarks on teh tread.
boxered is offline   Reply With Quote
Old 03-11-2008, 05:29 PM   #4
MistaOctamopus
Member#: 53561
2004 WRX
Look for blood stained landing gear.
MistaOctamopus is offline   Reply With Quote
Old 03-11-2008, 05:29 PM   #5
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
I can't see this thread taking off.
Longshot is offline   Reply With Quote
Old 03-11-2008, 05:29 PM   #6
4pOwnag3
Member#: 53200
2004 S60R
Gray
seriously? do they not break? are there no warning signs?
Old 03-11-2008, 05:30 PM   #7
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
Qcanfixit is offline   Reply With Quote
Old 03-11-2008, 05:31 PM   #8
tludwins539
Member#: 149764
2007 2.5i
1. Turn on full speed
2. Jump on once up to full speed.
3. Sue
4. ..........
5. Profit
tludwins539 is offline   Reply With Quote
Old 03-11-2008, 05:35 PM   #9
Sideshowbob
Member#: 50304
97 TJ, 04 Matrix
XR70R, 03 Gas Gas 250
My experience with used treadmills was buy new.
Everyone thinks they are worth WAAAAY more than they are.
Sideshowbob is offline   Reply With Quote
Old 03-11-2008, 05:38 PM   #10
uzer_errors
Member#: 79740
2013 BRZ Limited
Make sure it can run at every speed and incline.
The treadmill in our basement will work at no incline up to a certain speed, but because of something that went bad it will die if it's raised or at too fast of a speed. Something to do with the internal power supply IIRC.
uzer_errors is offline   Reply With Quote
Old 03-11-2008, 05:39 PM   #11
4pOwnag3
Member#: 53200
2004 S60R
Gray
excellent, i found one that 3 yrs old and they want 300$ for it.
Old 03-11-2008, 05:40 PM   #12
Sideshowbob
Member#: 50304
97 TJ, 04 Matrix
Brand?
Old 03-11-2008, 05:42 PM   #13
4pOwnag3
Member#: 53200
2004 S60R
Gray
Pro-form . . .
Old 03-11-2008, 05:44 PM   #14
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
Check Sears to see what a similar model goes for new.
beethoven is offline   Reply With Quote
Old 03-11-2008, 05:46 PM   #15
Sideshowbob
Member#: 50304
97 TJ, 04 Matrix
Usually the discount isn't worth the wear, or the gas money you end up spending driving around these days.
Old 03-11-2008, 05:49 PM   #16
4pOwnag3
Member#: 53200
2004 S60R
Gray
no model number, looks older than 3 years tho. about 15 miles from my house.
updated email:
used pro form treadmill / weight bench combo. $150 picked up
Old 03-11-2008, 05:52 PM   #17
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Seller weighs 600 lbs.
Mike Wevrick is offline   Reply With Quote
Old 03-11-2008, 06:00 PM   #18
RyantheWalker
Member#: 76528
If the plane is still there, it's an unpossible treadmill and you need to return to our dimension immediately.
RyantheWalker is offline   Reply With Quote
Old 03-11-2008, 06:12 PM   #19
jcl
Member#: 132215
06 Mitsubishi Evo
Wicked White
Make sure planes can take off and land from it. You want the best.
Seriously:
Check underneat the reel thing and make sure theres not alot of dust/grease in there. They are a pain to clean and if there is a build up they will stink.
Make sure all the electronics work and as said before that the incline and speeds all function.
jcl is offline   Reply With Quote
Old 03-11-2008, 08:25 PM   #20
gramicci101
Member#: 64763
The cake is a lie.
Seriously. Even if they never used it, they probably stood on it a couple times, and treadmills have weight limits.
gramicci101 is offline   Reply With Quote
Old 03-11-2008, 08:27 PM   #21
Asinine
Sufficiently Sharky
Member#: 55173
with paddles.
I was about to say, if the seller is overweight, ask them if they have proof that it works.
Asinine is online now   Reply With Quote
Old 03-11-2008, 08:32 PM   #22
Checkered24
Member#: 153974
2007 WRX Ltd
Urban Grey
Any treadmill I have ever owned seemed to lose it's incline function first, followed by electronics.
I would go for one with a heavier duty motor in them. The cheaper ones, with the cheaper motors, tend not to last as long. Especially if used for jogging/running since they are better suited for walking.
Other than that... just look for one without much apparent wear. Low belt wear, handle wear, etc, all functions working, etc. Good luck!
Checkered24 is offline   Reply With Quote
Old 03-11-2008, 08:33 PM   #23
racer98
Member#: 86793
use it as an SRT4 dyno, no sence in spinning 2wheels for powa when one wheel will only put the power down.
racer98 is offline   Reply With Quote
Old 03-11-2008, 08:36 PM   #24
zombiefeedingtime
Member#: 109380
That's because they bought it new, paid a fortune for it, used it 3 times, and want to recoup their losses
zombiefeedingtime is offline   Reply With Quote
WTB: used treadmill.... KIRKOY MWSOC Private Classifieds 0 02-10-2008 06:45 PM
warning sign whataboutno Interior & Exterior Modification 13 07-14-2003 04:25 PM
how do I get the warning signs off of the visors???` custom_impreza Interior & Exterior Modification 3 05-17-2001 08:59 AM
Warning signs of wheel bearing failure? cakagan Technical Forum Archive 10 09-13-2000 11:53 AM
