Old 02-12-2002, 11:30 PM   #1
ResQDawg3
Member#: 14117
2005 Nissan Murano
Pewter
Default I want more HP...
As the thread obviously states, I want more HP and I would like to do it as safe as possible, so low boost and no Nitrous. Any suggestions? Thinking maybe TurboXS stage 3, when it's ready, or should I wait for Shiv's stage 1 to come out? I am aiming for 250whp, what is the best way that I can do this without blowing my engine, tranny, or clutch? Suggestions from the gallery? Anything is welcome....Thanks in advance.... Ski
ResQDawg3 is offline   Reply With Quote
Old 02-12-2002, 11:51 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Shiv's stage1 or Stage0 will be your best bet for running a low-boost setup.
nhluhr is offline   Reply With Quote
Old 02-13-2002, 03:10 AM   #3
jmott
Member#: 6713
2007 Prius
brown
Default Re: I want more HP...
do you want it as safe as possible?
or do you want 250whp?
pick one
Id guess that currently the APS stage2 is the 'safest' way to get about that much power, with its huge front mount intercooler. Though some would suggest bigger injectors along with that setup.
but thats still gonna put a bit of a strain on your tranny/clutch
jmott is offline   Reply With Quote
Old 02-13-2002, 12:16 PM   #4
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Nothing is free, every mod has some potential tradeoff. Here are the mods I'v done so far.
New up-pipe, cost about $300. Drops engine EGTs, adds 8-10 horses, and allows the turbo to spool up slightly sooner.
Lightweight pulleys, costs about $170. Add 5-8 HP, considered relatively safe by almost everyone.
Port the throttle body. This is free if you have a Dremel and an oxide grinding stone. Gives about 5-10 HP from my experience. Most of the power is in the upper RPM range though.
Let's see, that got you from ~180 WHP to ~205 WHP... Those are the mods I've done. If I were to suggest anything past this point it would just be speculation and internet tuning
Corn-Picker is offline   Reply With Quote
Old 02-13-2002, 12:42 PM   #5
cronic
Member#: 9749
get a vf30 ported and polished, new fuel pump, new injectors, and go to txs and get a custom tune.. Go to there site and look at the dyno plots..
cronic is offline   Reply With Quote
More HP for a 2.5I Abill10 Normally Aspirated Powertrain 49 06-08-2010 10:04 PM
I want more HP without turning heads... binx159 Newbies & FAQs 48 02-11-2009 03:42 PM
Want a little more HP WRXpiprezza Engine Management & Tuning 9 05-16-2006 10:17 PM
I want more HP!!! Bakergtt Normally Aspirated with bolt-on Forced Induction Powertrain 13 03-24-2006 05:30 PM
WANT MORE HP AND GAS MILEAGE??? BrysImpreza Normally Aspirated Powertrain 7 02-26-2001 08:09 PM
