Old 03-12-2008, 01:11 AM   #1
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
Default 2002 WRX Wagon Tuned by 555 Motorsports
I Just got done dialing in a 2002 WRX Wagon with a VF22 on it. The car feels really good, I just added the aftermarket header and that made a huge difference up top where the car used to fall off, the only down fall is the car lost a little bit at spool up, about 150-200 RPM over the stock header, which might actually be attributed to what sounded like an exhaust leak before the turbo I heard on the 2nd pull
Here is the mod list:
-VF22 (22PSI tapering to 17PSI at redline)
-Witchhunter modded injectors (800cc)
-TurboXS Up-pipe
-TurboXS DP & CBE
-Un-equal length aftermarket header.
-STOCK WRX TMIC
-STOCK AIRBOX!!!
The car is also currently running a 2007 STi 6 Speed
Definitely quite a bit of restriction with the stock intake and TMIC, but still really good #'s i'd say. The car still has more room to improve when we get the new intake on it as well as the STi TMIC or other aftermarket top mount, then we will see what more we can push out of the car.
Enjoy
RUN #1
RUN # 2
Benchmark Tuning is offline   Reply With Quote
Old 03-12-2008, 01:26 AM   #2
socalLGT
Member#: 89752
08 STI
Road dyno software? Looks like you started running downhill at the end of run 1
socalLGT is offline   Reply With Quote
Old 03-12-2008, 01:29 AM   #3
Benchmark Tuning
Member#: 154444
Used the ECUEdit Road dyno software. The 1st run the car wanted to pull a little timing uptop, so I made some changes and was much happier with the 2nd run
Old 03-12-2008, 01:50 AM   #4
brocksdad
Member#: 107352
Not Respectable
That's pretty good power, considering the mods. Good work!
brocksdad is offline   Reply With Quote
Old 03-21-2008, 06:06 AM   #5
Benchmark Tuning
Member#: 154444
update: the car will be getting a cold air intake, and a few other goodies, i'll try to make a little bit more power
07 WRX 18g'd Tuned by 555 Motorsports 07HaWkEyE Proven Power Bragging 31 04-23-2010 12:30 AM
May 22-24 - Iowa Tuning Day 555 Motorsports Benchmark Tuning MWSOC Vendor Classifieds 43 05-26-2009 12:27 AM
06 Wrx VF39 - Mustang Dyno - 555 Motorsports Tuned Mooneyes13 Proven Power Bragging 54 04-11-2009 10:24 AM
2004 Stage 2 4EAT WRX Retuned by 555 Motorsports JawKnee Proven Power Bragging 6 03-02-2009 05:25 PM
