Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 03-12-2008, 07:48 AM   #1
Member#: 151979
Default 2.2phse 1 to 2.2 phase 2 swap
Like it says trying to do an upgrade on my '96 OBS (OK the truth is it"s a rebuild 96 body-99 motor & 5spd) Is an ecu change needed to do this swap or is it plug and play? If ecu change is needed is there an adapter to mate one ecu to another harness? Would RomRaider open source software be able to flash the '96 ecu to work as(or with) a '99?
I'm So Confused!!
kdub420 is offline   Reply With Quote
Interesting car - Factory phase two 2.5 with DOHC heads and phase 2 4eat SUS! ciper Normally Aspirated Powertrain 13 11-17-2009 07:22 PM
anyone running phase 1 ej25 heads on phase 2 ej25 block ??? IllNastyImpreza Built Motor Discussion 7 05-04-2008 11:48 PM
1998 phase 1 EJ25 into 2000 phase 2 EJ22 OBS. s'ko Subaru Conversions 0 04-14-2008 12:20 PM
2.5 phase 1 to phase 2 swap limeylight Subaru Conversions 12 12-29-2004 06:31 PM
phase 1 DOHC heads or phase 2 DOHC heads.. whats better to use? YaZahX Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-05-2003 06:16 PM
