Old 03-12-2008, 01:42 PM   #1
gtfaded
Member#: 142322
2002 wrx
wrb
Default AC leak question
when searching for an a/c leak using the uv detector, what kind of light would you use just a plain "black light"?
gtfaded is offline   Reply With Quote
Old 03-12-2008, 04:57 PM   #2
ranson
Member#: 169938
an ultra violet light with those yellow glasses that make every thing bright. i think the black light is a little different.
ranson is offline   Reply With Quote
Old 03-12-2008, 06:19 PM   #3
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
Is there dye in there yet? You will not be able to see R134 with out dye being installed and ran through the ac system first. If you have done this you should be able to see it with just a black light. The glasses will just make it a lot brighter.
hcsi99 is offline   Reply With Quote
Old 03-15-2008, 01:37 PM   #4
gtfaded
Member#: 142322
2002 wrx
wrb
i have the can w/ the dye in it but i havnt put it in yet, the leak is so bad it wont hold freon for more than a few hours.
Old 03-16-2008, 12:18 PM   #5
gtfaded
Member#: 142322
2002 wrx
wrb
i found a uv leak detector, man that was easier than i thought. the glasses helped alot didnt take anytime to find the leak. now i gotta get some o-rings and i'll be chillin.
Old 03-17-2008, 01:06 PM   #6
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
Glad to hear
AC Leak Problem gigabytexbc Newbies & FAQs 9 07-15-2010 01:03 PM
Ac leaking... O rings? pheonix991 Service & Maintenance 6 06-23-2008 03:17 AM
Found my AC leak, help on how to fix it!!!! Ryandc Service & Maintenance 5 09-25-2006 09:41 AM
AC leak .. at firewall? mordy_2v Service & Maintenance 0 08-08-2005 10:29 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
