Old 03-12-2008, 03:38 PM   #1
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
Default P0171
UTEC stg3
P0171 CEL on all the time
Removed catless turboback, installed factory turboback, switched to stock map and passed emissions. No CEL for days while driving like this.
CEL comes back 3-4 starts after reinstalling catless turboback and going back to staged map.
Does this mean it's all my tune? I'm w/in a couple tenths of the target AFR map in the cells I hit while daily driving...
Psipwrd is offline   Reply With Quote
Old 03-13-2008, 09:59 PM   #2
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
Do I have to start with "ok i did a search" or "I read the FAQ" before i get a response?
Old 03-13-2008, 10:59 PM   #3
2xhighpsi
Member#: 158089
2004 STi RomRaided
Are you on the stock turbo inlet, or an aftermarket? I got this CEL for weeks after I did my Perrin inlet install; it was leaking where it clamps to the compressor, creating a huge vacuum leak, thus taking in more air: creating this CEL for running too lean.
2xhighpsi is offline   Reply With Quote
Old 03-17-2008, 10:47 AM   #4
neuhate9999
Member#: 85796
2005 WRX
neuhate9999 is offline   Reply With Quote
Old 03-19-2008, 02:22 PM   #5
Rodwrx23
Member#: 170948
Definitely take the suggestions in that link. I was trouble shooting my P0171 code for about a month and finally got rid of it.
I cleaned my MAF, cleaned and re-oiled my air filter, cleaned IACV and replaced gasket, swapped rear O2 sensor b/c I had a P0137 as well, and also added fuel to my UTEC maps to be on the safer side, and also fixed a broken ground and cleaned a couple of ground spots (added a grounding kit as well).
It's been a little over 45 days and that pesky little bastard of CEL hasn't come back.
Rodwrx23 is offline   Reply With Quote
MIL trouble code P0171 ? OBD2 Reader. paul nieto Engine Management & Tuning 1 04-22-2003 06:52 PM
Cel P0171 I Love Turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-10-2003 10:51 PM
Help! CEL P0171 Rando Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2003 12:22 AM
System Too Lean Revisted: P0171 CEL Hank3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-11-2002 01:05 AM
P0171 Lean Code -- Need help ASAP! Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-05-2002 11:59 AM
