Old 01-23-2010, 04:10 PM   #26
JiroGD
Member#: 234805
Great info. I'm glad I tried this before I took my car to the dealer and paid $99 for just a diagnosis.
JiroGD is offline   Reply With Quote
Old 01-31-2010, 02:14 PM   #27
yoall
Member#: 227062
This also saved my ass and money.
been only checking on the driver side seat the entire time.
Dont forget about the passenger seat. In my case, that was at fault.
yoall is offline   Reply With Quote
Old 02-07-2010, 12:49 PM   #28
markwrob
Member#: 237682
1997 Legacy OBW
Hater06, if you're still looking for airbag light answers, try searching here or on a site such as USMB or even Google for "subaru airbag light". You should find threads showing how to pull the airbag code(s) without a trip to the shop or using any reader. Hope this helps. As a new owner of a '97 OBW, I am very impressed by the huge amount of helpful info I've found here and on USMB.
markwrob is offline   Reply With Quote
Old 02-28-2010, 09:54 AM   #29
IVGottaBDreamin
Member#: 203833
2004 JBP WRX
I found this thread a while back after my light came on, I pushed the connectors together and viola! it worked, thanks!
But it is a continuing problem, every month or so it comes back on. Is there a permanent fix for this? I thought about jb welding those bitches together
It's so annoying, maybe I'll try some rubber bands first...
Any other ideas?
IVGottaBDreamin is offline   Reply With Quote
Old 03-01-2010, 11:15 PM   #30
Tbone714
Member#: 223413
Duct tape..
Tbone714 is offline   Reply With Quote
Old 06-01-2010, 03:39 AM   #31
WRX luvr
Member#: 248227
Talking Thanks bomber!
Make me another one of those who is glad that he read this thread!
Have a 04WRX with that same Airbag light...went to an independent shop...got ripped $37.50 just to tell me that it was code42 and would require another 2hours+ for $150 or more to tear the steering wheel apart and "fix" the problem. All I did was put the yellow wires under both seats pushed together and like magic saved my butt another $150!
Not sure if the mechanics out there know of this and rip us off or they don't know and are doing what they think is best, but this does seem to be a design flaw (in my case it was a full plastic water bottle that rolled around and probably rolled into the yellow wires and caused that to show the code)...
Either way, hats off to you Bomber....you saved me and quite a few others grief and lots of $$$!
WRX luvr is offline   Reply With Quote
Old 06-09-2010, 04:01 PM   #32
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
Unibomber is a beast! Thanks
yellowsubi is offline   Reply With Quote
Old 06-14-2010, 08:26 AM   #33
chompleh
Member#: 70469
those of you that had the airbag light come on, did your horn work while the light was on?
chompleh is offline   Reply With Quote
Old 06-22-2010, 10:41 AM   #34
chatcr250
Member#: 242643
Checked and pressed together both yellow connectors under the seats, airbag light still on.
Found yellow airbag connector under drivers side of dash, pressed together and airbag light turned off!
Great info thread!! Thanks Unabomber.
chatcr250 is offline   Reply With Quote
Old 07-08-2010, 11:18 PM   #35
SuperuRS
Member#: 150314
I too am enlightened by your sage wisdom oh great Unabomber. It saved me at least another days worth of my Wife nipping at my ass to get it fixed. Thank you!
SuperuRS is offline   Reply With Quote
Old 07-12-2010, 08:08 PM   #36
Esupra773
Member#: 243448
04 WRX PSM
Neva Narc'd on Nobody
Unabomber I must say you are the efffing man. I just got my 04 wrx and got a CEL the other day and was pissed so i took it to subaru figures i need a new thermostat so i bought it and now im going to do it myself but today when subaru gave me my baby back the airbag light was on and i stormed back inside and was mad and they said to bring it back tomorrow but there was no way they touched any connectors so i searched airbag light and came across this and you just made my day ten times better.
Thank you Nasioc and unabomber!
Eric
Esupra773 is offline   Reply With Quote
Old 09-17-2010, 06:48 PM   #37
hater06
Member#: 139699
2011 WRX STi Limited
just some more info related to my issue earlier this year... if you try the under the seat connector and it does not work, it could be your passenger seatbelt assembly... apparently that was my issue, i got it replaced by subaru and the airbag light went off.
hater06 is offline   Reply With Quote
Old 09-18-2010, 09:23 AM   #38
vwbugpilot
Member#: 254120
2004 sti
black
Subaru came out with a fix awhile back the part# is 98219SA500 It contains new plugs for both front air bags in the seats and will cure future problems
vwbugpilot is offline   Reply With Quote
Old 12-21-2010, 03:29 PM   #39
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
Lets give this a bump. Worked for me today!
Rudywrx04 is offline   Reply With Quote
Old 12-31-2010, 09:45 AM   #40
iluvdrt
Member#: 46248
82 Brat
Tan
Ill be giving it a try as well. My light just came on too.
iluvdrt is offline   Reply With Quote
Old 02-14-2011, 02:45 PM   #41
moneymaker1984
Member#: 270877
Worked for me too! Thanks
moneymaker1984 is offline   Reply With Quote
Old 04-04-2011, 11:34 AM   #42
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
mine isn't on when I start the car, but I drive for about 10 minutes and it comes on. I can pull oer turn the car off and on again and it goes away for another 10 minutes. I have tried to reconnect the connectors under the seat and the dash and nothing.
2006 sti.
I installed 3 gauges and a new radio. I am wondering if I am drawing to much current. I am going to rewire everything and split the gauges off 2 different sources of 12v constant and 12v switched and see if it makes a difference.
medamullet is offline   Reply With Quote
Old 04-05-2011, 04:33 PM   #43
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Had my wife in the passanger seat all day and the light never came on. Today driving to work it came back on. I checked all the connections under the passanger seat. It stays off for about 10 minutes then pops on. something is funny.
Old 04-24-2011, 08:34 PM   #44
w are ex
Member#: 171153
2003 wrx
blue
Default 2004 wrx airbag light
I just got in my car today and the airbaglight ws on and i messed with the yellow connecters on it went right off
w are ex is offline   Reply With Quote
Old 04-26-2011, 10:52 PM   #45
Zakira
Member#: 150686
Well hot damn this worked for me, too!!! Thanks Unabomber!!!
Zakira is offline   Reply With Quote
Old 05-01-2011, 04:37 PM   #46
meebs
Member#: 3251
2009 WRX Hatch
Another bump. 04 wagon here. 87000 miles. Suddenly came on today. Found this thread, unplugged and plugged in the yellow connectors under the seats. Light's off!
They do seem sloppy though. Thinking of just replacing them with some Tamiya connectors.
meebs is offline   Reply With Quote
Old 05-01-2011, 06:06 PM   #47
plbull
Member#: 281247
Have a Nice Day? air bag
Originally Posted by Unabomber View Post
Just check the yellow connectors under your seats. Grab each one and smoosh the two sides of the connectors toward each other on the passenger and driver's seats and I'm placing 2:1 odds the light will go off and you will mentally thank someone from VA Beach with the username Unabomber.
Oh and this should go in the Electrical Forum...
i have a problem with my subaru wrx 2005 i changed the seat then air bag light came on.. can someone help me...
plbull is offline   Reply With Quote
Old 05-01-2011, 06:17 PM   #48
plbull
Member#: 281247
i have a problem with my wrx2005 i changed passanger seat then air bag light came on.. can someone help me please....
Old 05-02-2011, 06:37 PM   #49
plbull
Member#: 281247
can you help me unabomber..i bought a wrx 2005 salvage 111k. i changed passenger seat but the air bar light did not shut off.. can someone help me please..... my tail light stays on and after i turn off the car the light would not shut off.. and i have to take the car to the state police for inspection... i really need help... again can someonehelp me pleasee????
Old 05-02-2011, 08:14 PM   #50
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
You changed the passenger seat to what? A seat with no air bag?
z is offline   Reply With Quote
Airbag light is on, aftermarket seats, 4 airbag cords? subierider Interior & Exterior Modification 7 10-26-2008 05:00 PM
Replacing airbag OE seats - airbag light on? fpan Interior & Exterior Modification 4 10-19-2008 10:06 PM
Airbag light having nothing to do with airbags? coloradosti Interior & Exterior Modification 2 06-27-2004 05:02 PM
('93-'01) airbag light on? ferretboy Impreza Forum 3 05-29-2001 10:39 PM
