Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 03-12-2008, 08:34 PM   #1
PERRIN_JOHNL
Member#: 125283
Default PERRIN BugEye Project $15k - HEADER
FINALLY TIME FOR SOME GOOD POWER UPGRADES!
After talking with my good friend and Subi "know it all" Jeff Perrin I have decided to make room in the budget for the PERRIN Equal length header we make. He swears it'll spool the turbo sooner and have decent gains even on the stock turbo, and it'll even be more of a benefit for the UPGRADED snail we have planned.
The header is NOT a simple bolt on for the WRX as it needs a few OEM Subi parts to go with it (the header is designed for the STI). I needed to get the STI Oil Pan, Oil Pick-up tube and decided to get NEW OEM gaskets for the head flanges and up-pipe flange.
To accommodate for the different pan shape the oil pick-up is moved, notice the different shape of the support bracket. (sorry for the blurry picture) The old WRX Oil Pick-up is the darker and dirty looking one.
Here is another angle of the Oil Pick-up tubes. The WRX one has a large open mesh pick-up area, the STI has a smaller opening before the mesh (more vacuum?) Again sorry for the blurry picture
Here is a picture of the oil pans. The WRX is the dirty one, I am holding them so they are clocked the same, notice the differences?
Picture from under the car with the oil pan and oil pick-up removed. To install new pan, make sure you clean the mating surface.
Picture from under the car again with the STI Oil Pick-up tube installed.
Header installation almost done.
Sound clips are coming but opposite of popular belief you can still tell its a Subi Boxer Engine, its just a little mellower.
Yes, a little loss down low but good gains up top. Stock turbo, Stock down pipe.
Click here for results with bigger turbo and 3" down pipe.
PERRIN_JOHNL is offline   Reply With Quote
Old 03-13-2008, 02:14 PM   #2
wrxhard
Member#: 108091
WOOOHOOOOOO!!!!
Finally some power!!!
wrxhard is offline   Reply With Quote
Old 03-14-2008, 02:01 PM   #3
wrxhard
Member#: 108091
Or maybe not so much power? How bout some numbers guys??
Old 03-14-2008, 02:10 PM   #4
tydawg2
Member#: 160432
2008 STI
^tool.
tydawg2 is offline   Reply With Quote
Old 03-14-2008, 07:59 PM   #5
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
Looks good my next mod is a Mad Dads exhaust manifold.
Dstretch33 is offline   Reply With Quote
Old 03-15-2008, 11:19 AM   #6
wrxhard
Member#: 108091
Originally Posted by tydawg2 View Post
^tool.
Please elaborate?
Old 03-15-2008, 03:55 PM   #7
PERRIN_JOHNL
Member#: 125283
numbers are coming, customers come first on the dyno so I have to wait for free time.
Old 03-30-2008, 02:42 PM   #8
carnz-pj-410
Member#: 110994
1993 Legacy Turbo
sweet, i"ve always loved the EL headers, i've never heard a Perrin set, im excited
carnz-pj-410 is offline   Reply With Quote
Old 04-01-2008, 09:26 AM   #9
Precision Tuning
Member#: 38696
Did you change the dipstick too? The wrx dipstick and the Sti dipstick are different lengths.
Rich
Precision Tuning is offline   Reply With Quote
Old 04-02-2008, 09:33 AM   #10
SQC120
Member#: 39677
2008 Land Rover
02 WRX
Rich
I would like to know this as well.
Is changing the oilpan a difficult process? I can only assume you drain the oil, then just take off couple of bolts for the pan?
Also, on the Perrin Header, do you have to change the O2 sensor? or is that on the uppipe only? Does the Perrin header match up to aftermarket uppipes?
post up dynos! keep up the great work
SQC120 is offline   Reply With Quote
Old 04-21-2008, 09:42 PM   #11
ACRTrexguy
Member#: 145576
04 wrx sdn
BUMP for dyno results (ive been waiting a month now paitently)
IMO, its allot easyier to get at the back 6 bolts on the pan if you unbolt the lower engine mounts and jack up the engine. then use two screwdriver handles as extra spacers under the motor mounts to hold it in position while you work.
yes it bolts up to other up-pipes, you can even use it with some rotated turbo kits
ACRTrexguy is offline   Reply With Quote
Old 04-22-2008, 12:22 PM   #12
Texas Money
Member#: 175512
94 Wagon-DailyD
04 biturbo audi A6
good job! i was thinking about getting some headers and i may have the brand i want now
Texas Money is offline   Reply With Quote
Old 05-19-2008, 11:22 PM   #13
sean1.8t
Member#: 152260
looks sweet!
sean1.8t is offline   Reply With Quote
Old 05-23-2008, 10:08 PM   #14
collegescooby25r
Member#: 180154
ive always wanted a set ^^^
collegescooby25r is offline   Reply With Quote
Old 07-10-2008, 09:08 PM   #15
PERRIN_JOHNL
Member#: 125283
Added dyno chart to the original post.
Old 02-24-2009, 01:18 AM   #16
black&whiteday&night
Member#: 202006
whats up with the sound clip...??
i am going to swap my headers regardless but i dont want to loose the boxer rumble
black&whiteday&night is offline   Reply With Quote
Old 02-24-2009, 05:51 PM   #17
I<3Boost722
Member#: 203965
Impressive.
Keep it up
I<3Boost722 is offline   Reply With Quote
Old 07-07-2009, 02:48 PM   #18
dwardle
Member#: 216432
ooooo shiney
dwardle is offline   Reply With Quote
Old 09-06-2009, 08:52 PM   #19
redzfit
Member#: 191518
2010 EvoX<--H8Mitsu
2011 Mini S<-- Now
JohnL how would this header do on a stage 2+ 09 Wrx which has the VF52 turbo???
redzfit is offline   Reply With Quote
Old 10-08-2009, 03:14 AM   #20
kurtdaniel
Member#: 156150
im so excited to have one,,it would bring so much additional power to my jeep parts..
kurtdaniel is offline   Reply With Quote
Old 10-09-2009, 01:43 AM   #21
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Heres the writeup
http://perrinperformance.com/product...ory=6&model=23
08EJ25 is offline   Reply With Quote
Old 11-16-2009, 05:39 PM   #22
quazimoto
Member#: 70395
Blast from the past here but why does the chart say "stage 2 " if your using the stock downpipe?
quazimoto is offline   Reply With Quote
Perrin BugEye 15K Stealth Exhaust DIY PERRIN_Ken NASIOC Project Cars 58 04-21-2009 04:19 PM
wrbwrx86's bugeye project wrbwrx86 Member's Car Gallery 29 01-21-2009 12:11 AM
Widebody WRC ish bugeye project fateo66 Member's Car Gallery 323 12-18-2008 08:00 PM
V2 STI Type RA...Bye Bye Bugeye project JeffrWRX Member's Car Gallery 96 10-13-2008 11:51 PM
TX: perrin crank pulley 15k WRXout Private 'For Sale' Classifieds 8 08-26-2004 03:02 PM
