Old 02-13-2002, 02:21 AM   #1
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Default Stand alone scan tools
I know there's a coupla of OBD II scan tools out there that do not require a computer to run them. I need a scan tool, but I am not in a position to buy a lap top computer. So can anybody give me any feed back on some "stand alone" scan tools? Like quality, user friendly, price, etc...........Thanks!
LVSUBARU is offline   Reply With Quote
Old 02-13-2002, 02:24 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Buy a lap top...the Average OBD-2 Stand alone scan tool will cost you about 3-4g's....unless someone has come out with something cheaper....the Honda PGM tester is $6g's.
jeremy
Old 02-13-2002, 03:02 AM   #3
Avenger
Member#: 1234
Snap-on scanner cost about 3G CND and you have to pay for update every year!
Avenger is offline   Reply With Quote
Old 02-13-2002, 03:24 AM   #4
DPPerformance
Member#: 15299
87 Ford Turbocoupe
Sky Blue
scan tool is way overated and will manny times send you down the wrong path if you do not know how to correctly interpet the numbers. However a dvom will give you the real numbers and is alot cheaper. Now before everyone jumps on me I am assuming that anyone that is buying a scan tool is not a proffesional mechanic because they do not have access to one already. Because I know a scan tool is necessary to diagnose many problems and for a pro or someone even somewhat fluent with one it will do mant tests that will diagnose problems.
DPPerformance is offline   Reply With Quote
Old 02-13-2002, 07:42 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Check out www.autoxray.com
Around $300 depending on what options you get. This is what I carry with me, since it's a self-contained unit I can just leave it in the car so it's there anytime I need it. Reads codes with text descriptions, clears them, and gives real-time data. Very useful.
Old 02-13-2002, 11:47 AM   #6
8Complex
Member#: 922
04 FXT
Red
www.pricewatch.com for a $200 laptop, and then look around for scan programs... anywhere from $75-$125 for economical programs with cables.
Old 02-14-2002, 01:11 AM   #7
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I am a proffesional mechanic for Mercedes Benz. We do use scan tools on lap tops but they are Mercedes specific, and can not be used on my Ru, or any other make of car. I do alot of work on my car, and I'm starting to get into alot of side work at home so a scan tool for home would be very helpfull.
I looked but did not see any lap tops for $200.
Thanks.
Old 02-14-2002, 01:27 AM   #8
8Complex
Member#: 922
04 FXT
Red
Sorry, my bad... go to Pricewatch and click on 'Not Exactly New' in the top right corner. These are refurbished units. When you click on Notebooks in the middle frame, you'll see the proceessor speeds and price listings below. The Pent. 90's are $145 refurbished Dell machines. The p133, Dell machine for $195 looks pretty good too.
Old 02-14-2002, 02:07 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
LVS, that's what i like about the Honda PGM tester, it has the honda specific programming and also has the Generic OBD-II language. BMW does the same thing you guys do, can't read generic OBD-II at all. So don't feel to left out
and yes it's nice having a scanner at home
jeremy
Old 02-14-2002, 04:15 PM   #10
il96
Gone... But not forgotten
Member#: 13082
il96 is offline   Reply With Quote
Old 02-15-2002, 01:08 AM   #11
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
It's very fustrating!!! We have all these trick lap tops lying around the shop, but I can't use a single one on my Ru!!!!!!
Old 02-15-2002, 12:34 PM   #12
Skidd
Member#: 1853
GC6 Supercharged
STM
How about this one. You can get a low end PALM computer for under $100, then $29 for this software. Then you'll need a connector cable.. Looks like a decent little setup.
http://www.ghg.net/dharrison/obdscan.html
Skidd is offline   Reply With Quote
Old 02-15-2002, 10:31 PM   #13
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
That's what I think 'm gonna do. It looks like a simple and small scan tool set up! In the next couple of weeks or so I'm gonna be buying one..........I'll bring it to a meet so all the Vegas guys can check it out!
Link G4 Xtreme PnP Stand Alone ECU 06-07 Sti akeric Engine/Power/Exhaust 6 06-05-2010 05:00 PM
Best Computer Based Scan Tool/Log Tool? wirolla Engine Management & Tuning 5 01-08-2010 07:03 PM
Anybody have a free stand-alone 508 compliance test tool? Layman Off-Topic 10 02-18-2008 08:49 PM
Alex Peper OBD2 Scan Tool and Dyno-Scan Pocket Logging Tool with HandSpring Visor DeusExMachina Private 'For Sale' Classifieds 8 11-01-2004 03:27 PM
Unichip offered as a stand alone unit? Diz Factory 2.0L Turbo Powertrain 6 07-30-2001 11:12 AM
Message Board Statistics All times are GMT -4. The time now is 08:49 PM.
