Old 02-13-2002, 10:58 AM   #1
everbruin
Member#: 15175
95 talon awd
stu 95 m3
Question High-pitched squeak during upshifting
Hi, I've a stock MY00 rs sedan that occasionally exhibits a high-pitched squeak/squeal during *normal* upshifting (in all gears). It seems to occur more often when the car/engine is "cold" and/or when it's cold outside. I've taken it to the dealer during the day but by the time I drive the 3 mi there the squeaking either "vanishes" or is barely audible to me (and not audible to the mechanic sitting next to me). It's been happening for a few months now. Any ideas?? Thanks!
everbruin is offline   Reply With Quote
Old 02-13-2002, 01:15 PM   #2
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
Check your belts. The symptoms you mention perfectly describe loose/worn belts. Noise or no noise your dealer should have checked them simply based on your complaint. This is basic highschool autoshop stuff.
-Pete
Chunky_Chicken is offline   Reply With Quote
Old 02-13-2002, 03:58 PM   #3
everbruin
Member#: 15175
95 talon awd
stu 95 m3
Timing belt or other belt? Recently the dealer fixed the timing belt "tensioner" so that there is no longer a rattling. Actually I had let the rattling go on for like a year cuz I didn't think anything of it (duh). Could that have been really bad?
Thanks again!
Old 02-13-2002, 04:27 PM   #4
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Silverthorne Metallic
Is it directly related to upshifting??
I have a noise that happens when I upshift with a decent amount of throttle and is directly proportionate to how much slippage there is before it(the clutch) fully grabs. If I gently apply gas and release the clutch it doesn't happen. If I accelerate a little harder and there's more slipping before the clutch graps it will make the noise.
Sound like your problem?
Not that I can offer any answers or solutions.. but just be there with you in the same boat..
RigdenZW is offline   Reply With Quote
Old 02-13-2002, 10:13 PM   #5
everbruin
Member#: 15175
95 talon awd
stu 95 m3
Yep, it's only a problem upshifting and the squeaking does turn into a longer squealing if I upshift "harder" (ie. w/ more throttle).
I'll have the dealer check the belts (as recommended in this thread) and hopefully I'll be able to post a happy resolution!
High Pitched Squeaking noise JLude7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-29-2009 12:36 AM
High pitched squeak from aftermarket intake? BrysImpreza Normally Aspirated Powertrain 11 06-30-2004 03:58 PM
Heat "ON" = high pitched squeaks JayGold Normally Aspirated Powertrain 2 12-08-2003 03:27 PM
High-pitched squeak during upshifting everbruin Transmission (AT/MT) & Driveline 1 02-13-2002 12:55 PM
annoying, high pitch squeaking driving me nutz! olie General Forum Archive 2 01-11-2001 08:04 AM
