Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 03-13-2008, 08:31 PM   #1
leeswrx
Member#: 118295
05 STI
Unhappy Put the wrong oil weight in...HELP!!
Today I changed my oil and I put 5w20 in when it should have been 5w30. The oil is royal purple. Should I change the oil ASAP or will it be ok til the next oil change. Its a stock 2005 STI. Any and all help will be appreciated.
leeswrx is offline   Reply With Quote
Old 03-13-2008, 08:39 PM   #2
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
You'll be fine as long as temperatures don't get into the 100's outside for the next 3k miles... The difference in 20 and 30 weight isn't that big of a deal to be freaking out about it unless you have a climate that calls for a 30 weight.
Read in your manual on the temps in which 30 weight oil is good for.. it should also show a 20w too..
I believe it's just a tad thinner oil... But I'm sure an oil guru will come in here and give you the low-down on the technical details.
rhinotech is offline   Reply With Quote
Old 03-13-2008, 09:31 PM   #3
Badler
Member#: 133597
I would change it. That's just me though.
Badler is online now   Reply With Quote
Old 03-13-2008, 09:33 PM   #4
bdpAKAknox
Member#: 121248
agree
bdpAKAknox is offline   Reply With Quote
Old 03-13-2008, 09:54 PM   #5
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
It doesnt even matter like that..Its not a huge deal at all..Plus Royal Purple is almost 7.00 a quart here in The Seattle area so deffinently not worth changing it..
wrxwagon253 is offline   Reply With Quote
Old 03-13-2008, 10:53 PM   #6
bluesubie
Member#: 767
04 FXT
Probably doesn't matter.
Royal Purple 5W30 is known for shearing to a 20 grade anyway. I wouldn't run RP xw30 in an STi, but that's just me. You're probably fine in AK as long as you don't drive too agressively.
-Dennis
Old 03-13-2008, 11:03 PM   #7
leeswrx
Member#: 118295
05 STI
I went ahead and changed it anyway to be on the safe side. Id rather spend 40 bucks in oil than 1300 on a new block. Thanks for the support.
Old 03-14-2008, 02:18 AM   #8
03Bugeye
Member#: 169588
2003 WRX
You should run for President.
03Bugeye is offline   Reply With Quote
Old 03-14-2008, 10:25 AM   #9
McGuillicuddy
Member#: 168047
2003 WRX Wagon
Good lord. Completely unnecessary.
McGuillicuddy is offline   Reply With Quote
Old 03-14-2008, 11:11 AM   #10
WRXLTD
Member#: 136314
2014 Grand Cherokee
I agree.
The OP just wasted $30 or so in oil (even more if he changed the oil filter too). Last time I checked it's still Winter, so the possiblity of 100 degree weather in the next 3 months is slim to none in his area.
WRXLTD is offline   Reply With Quote
Old 03-14-2008, 11:43 AM   #11
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Funny. Yeah if you were that worried about it then you did what made you feel best by changing it. Should have saved the drained oil and used it in your old chevy that burns oil! LOL!
nottofast is offline   Reply With Quote
Old 03-14-2008, 01:12 PM   #12
bluesubie
Member#: 767
04 FXT
Personally, I probably would've drained a quart and added 5W40. But what does it still being winter have to do with running the minimum specified viscosity of 5W30?
-Dennis
Old 03-14-2008, 02:13 PM   #13
WRXLTD
Member#: 136314
2014 Grand Cherokee
-Dennis
Because the temperature in Winter in lower than in the Summer, and that oil shears faster when the temperature goes up...
He would have been fine in the Winter months running that 5w20 this one time until his next oil change (within 3000 miles). Show me proof otherwise.
Old 03-14-2008, 02:56 PM   #14
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
40 bucks for piece of mind? good investment in my opinion
Doc Holiday is offline   Reply With Quote
Old 03-14-2008, 03:24 PM   #15
strohausii
Member#: 26770
'02 WRX
midnight black
He's in Alaska... He could have just used that oil, and when (...most likely) burned off, add some higher weight make up oil.
strohausii is offline   Reply With Quote
Old 03-14-2008, 04:04 PM   #16
Nuke209
Member#: 108089
2003 WRX
NF Performance
I would think, if a 20 weight, just don't run it too hard, just casual daily driving should be fine. But do keep an eye on the oil level.
Nuke209 is offline   Reply With Quote
Old 03-14-2008, 04:30 PM   #17
bluesubie
Member#: 767
04 FXT
Because the temperature in Winter in lower than in the Summer, and that oil shears faster when the temperature goes up... He would have been fine in the Winter months running that 5w20 this one time until his next oil change (within 3000 miles). Show me proof otherwise.
Read your owner's manual and tell me what the thinnest oil allowed by Subaru is. Regardless of outside temperature, the oil inside of an engine still gets very hot.
Like I said in my first post, he probably would have been fine since Royal Purple 5W30 shears to a 20 grade pretty easily anyway.
Check this thread for an example and this one as well (post #6).
Now show me proof of RP 5w20 showing good results in an STi. Heck, only I've only seen one good RP uoa posted on here.
strohausii actually hit the nail on the head. The 5W20 would probably burn off and he could have added some 5W40.
-Dennis
Old 03-14-2008, 05:00 PM   #18
sama lama
Member#: 136231
95 LX Impreza
blue
I can say I put Motul e tec 100 in my zx12r it dropped my oil temps an made the transmission shift better an the second oil change it got even better it cost $8.99 quart. If the price of a new engine is not important to you put in autovalue recycled oils. In my impreza an tohoe I use mobil one. Subaru rally team uses Motul brand oil.
sama lama is offline   Reply With Quote
Clutch Lasted 5k?! Did my mechanic put the wrong clutch in? jsavage Transmission (AT/MT) & Driveline 11 10-16-2009 01:04 PM
HELP!! put the wrong oil for track day application!! maramaralula Newbies & FAQs 7 01-22-2009 07:41 PM
So ive never put the wrong URL into YTMND kaisersouse Off-Topic 0 07-18-2006 03:08 PM
Did express oil change place put the wrong type of fluid (instead of engine oil)? ImportVenom Off-Topic 26 07-05-2005 04:53 AM
so the dealer put the wrong oil in my car WRX4me Service & Maintenance 14 04-25-2003 07:52 PM
