Old 03-13-2008, 08:24 PM   #1
buccilli15
Member#: 109369
08 2.5i
Default All my rear brake lights are out
Just noticed it late yesterday...Not sure what's going on? I'm looking for suggestions.
So far I have checked the bulbs, they're OK.
I checked the obvious fuses, OK.
I messed around trying to add a "jumper" wire into the brake switch sensor, hoping "something" would happen, nothing did....Any suggestions to test the sensor??
Is there a relay that could cause this? Which one?
All help is very appreciated!!! I've hit a dead end
buccilli15 is offline   Reply With Quote
Old 03-13-2008, 08:39 PM   #2
Illsti
Member#: 131183
05 STI
CGM
get a test light and check the sockets for the bulbs with the lights on or someone steppin on the brake to see if theres any power, Could be bad a connection...
Illsti is offline   Reply With Quote
Old 03-13-2008, 08:41 PM   #3
buccilli15
Member#: 109369
08 2.5i
I should be able to use a multimeter to test, correct? I tried regardless and didn't read any volts w/ somebody stepping on the brake pedal, while the car was started.
Old 03-13-2008, 08:43 PM   #4
gusto
Member#: 58323
id check the switch if, you KNOW the bulbs and fuses are ok.
not just a visual, but try known good ones.
shoot me an email ill send ya the test/pinout info
gusto is offline   Reply With Quote
Old 03-15-2008, 02:50 PM   #5
buccilli15
Member#: 109369
08 2.5i
So here's the deal-
The switch is fine, checked it w/ a meter...plus the cruse control shuts off when the brake is applied..
Any more suggestions? Possible relay?
Old 03-16-2008, 02:16 PM   #6
buccilli15
Member#: 109369
08 2.5i
I fixed it
There was a short in the wiring going that connects to the light in the wing.
All of my brake lights are out MF-DIF Electrical & Lighting 5 10-14-2008 12:24 AM
My rear lights are out. wtf mate^ Help plz. Jeenyus Mid West Subaru Owners Club Forum -- MWSOC 3 07-17-2008 02:01 PM
Rear circle brake light is out cbbwrx Interior & Exterior Modification 4 06-29-2008 12:13 AM
My Brake Lights are OUT! DragoonFly Newbies & FAQs 5 10-14-2007 11:20 PM
"Sir your brake lights are out!" chrislehr New England Impreza Club Forum -- NESIC 31 05-23-2004 08:15 PM
