Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-13-2008, 11:25 PM   #1
Harenil
Member#: 93071
1995 Impreza L EJ22G
(Hybrid EJ22T/EG20G)
Default Cam seal replacement help
Hello all.
I've been replacing/fixing a bunch of stuff on my car I should have done when I did my swap. Anyway, I'm on the passenger side cam seal (SOHC). I can't figure out how I'm supposed to get the old seal out and the new one in without damaging it. I've been searching far and wide for some sort of guide, but so far, I can only find one for the driver's side.
Any help? Links?
Thanks
Daniel
Harenil is offline   Reply With Quote
Old 03-14-2008, 09:05 AM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
easiest way to get the old seals out is to take a couple of wood screws and tap them lightly into the seal(opposite of each other) then turn them in a bit more with a screw driver. Make sure to keep the screw far enough away from the cams to avoid damaging the surface the seal rides on. Use the screws to pull/wiggle the seals out.
To put the new seals in. You can use a large socket that fits over the end of the cam to drive the seal in with a hammer. The closer the socket is to the outside diameter of the seal the better, less chance of distorting the seal. You can also use a piece of pipe if you don't have a socket deep enough.
flstffxe is offline   Reply With Quote
Need help on valve & cam seal replacement jobs Service & Maintenance 2 02-19-2010 12:30 PM
Cam seal replacement cost? gopsu Newbies & FAQs 3 01-31-2010 12:39 PM
so I need my cam seals replaced... kingtut12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-08-2007 11:33 PM
Crank/Cam seal replacement question Topshelf Service & Maintenance 2 06-24-2005 12:22 AM
CAM Seal replacement 2.5 L svx_commuter Normally Aspirated Powertrain 5 10-13-2003 07:51 PM
