Old 02-13-2002, 01:11 PM   #1
bliu
Member#: 5268
03 Honda Blue Egg
Toyota Silver Shoe
Unhappy P0457
(please ref this thread and this thread)
I have been blessed with the wonderful circumstance of having a semi-troublesome car without a dealer w/in 1 hour of where I live. So I've been resorting to having my car looked at when I travel to towns that have a Subaru dealership. In November, I had 3 CELs - the 3rd one currently still lit. I had the code pulled twice at dealership #1 - P0457. They said that I needed to have the fuel pressure sensor replaced, but were unable to do it for me since they didn't have the part in stock at the time. Next weekend, I will be in another town with dealer #2. I called them up to see if they could get the part in so as to fix the problem when I'm there. They said no can do for a couple of reasons. They don't know which pressure sensor it is exactly and their books indicate that P0457 is only for the Legacy. I had dealer #2 call dealer #1, and they still don't believe in P0457 for the WRX. I called 1800SUBARU3 only to find out (as I'm sure a lot of you already know) that they don't have any technical info. They also told me that since each dealer is independently owned and operated, there's no real communication between dealers unless they choose to do so. They also told me that it's up to the dealer to look into getting technical info from Subaru, not owners like me.
So.
Is there anything I can do (having read the above 2 threads to know that there -is- info 'in the books') to let the dealer knows there -is- a P0457 for the WRX and a possible fix for it?
Does anybody know more about P0457 and what there is to keep it from coming up after each reset?
Sorry it's so long, but hopefully this will help others with the same problem.
Thanks for listening!
bliu is offline   Reply With Quote
Old 02-13-2002, 03:13 PM   #2
nimbels
Member#: 12827
2002 Impreza WRX
You do have a code for the WRX. The P0457 means that you need to get your ECM reprogrammed. Your Subaru dealer should already know this.
nimbels is offline   Reply With Quote
Old 02-13-2002, 03:42 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
P0457 means "Evaporative Emissions Control System - [Gross] Leak Detected." It generally means a loose or cross-threaded gas cap. Although the WRX does issue this code (all new cars have to be able to detect and issue this code), it is mysteriously missing from the WRX Service Manual. However, the Subaru Select Monitor does correctly provide the meaning of this code to the service technician. This explains why the second dealer didn't believe you had the correct code - he looked it up in his Impreza Service Manual and it wasn't there, although he found it in his Legacy Service Manual. If you get this code and you're quite certain the gas cap has been properly tightened, then you should schedule service because this is, in fact, one of the trouble codes for which the ECU will receive a re-flash. If your service center hasn't heard of this, ask them to call the Subaru Tech Help Line.
Jon [in CT] is offline   Reply With Quote
Old 02-13-2002, 04:22 PM   #4
bliu
Member#: 5268
03 Honda Blue Egg
Toyota Silver Shoe
Well, hopefully next week when I take the car in, they -will- pull P0457. And hopefully they'll believe it's real... I'll make sure to tell them to contact the Subaru Tech Help Line if they suggest anything other than an ECU reflash ... like dropping the fuel tank. Thanks again for the help!
Old 02-13-2002, 06:43 PM   #5
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
Guys,
P0457 can be due to many things... a loose Gas Cap is the main one SOA's manuals attribute it to.
Other causes from fellow I-clubbers are often loose hoses at the rear of the car (on the charcoal canister box/drain valve??) or in the engine compartment (can't remember where though)
I have been getting P0457s for 3 months and have had all these things checked and had my ECM re-flashed but still no good.
My problem appears to be dirt in the hoses/filter at the rear of the car which is blocking fuel ventilation (or something like that.)
So P0457 does NOT mean you have to have your ECM reflashed, first have a Tech do a FULL inspection of the car and check the fuel system in it's entirity for leaks, loose hoses, blockages etc. This is time consuming and probably not something they want to do. Unfortunately for me this took many many visits to the dealership and calls to SOA for them to actually find my problem and is still not fixed (waiting on parts.)
- Richard.
Bugsie1 is offline   Reply With Quote
Old 02-25-2002, 11:00 AM   #6
bliu
Member#: 5268
03 Honda Blue Egg
Toyota Silver Shoe
well, i took my car on saturday for them to take a looksie. they said they pulled p0457 ... surprise surprise! then they said 'we don't have that in our impreza service manual' (like jon said), and that the tech line isn't open on saturdays. they said they'll call for me today and relay the info to me. (we'll see about that) so basically, nothing happened. and they didn't reset my CEL, even ... which isn't a bad thing, because now that i'm so used to it, i'd probably think there was something wrong if it -wasn't- there.
Old 03-08-2002, 03:44 PM   #7
bliu
Member#: 5268
03 Honda Blue Egg
Toyota Silver Shoe
Angry bump ... again
i just called the dealer ... having given them 2 weeks to call the subaru tech line to figure out what to do about a "P0457" for the impreza ... they said that the they haven't been able to get hold of the tech line/the tech line doesn't know still. i say baloney (sounded like 'doh, we forgot to call, better make up an answer') ... i know that some have said ECU reflash, some say change this or that sensor ... does anybody have the official tech line answer?
and does calling 1800subaru3 to report my frustrations really help? the last time i called them they said they can't help with anything technical and blah blah blah ... i'm starting to get quite ... tired, perhaps is the word, dealing with subaru. i'm not sure it's a good thing that i've gotten used to the CEL being on (4 months now) ... there's the thought in the back of my head that if something new goes wrong, i won't even know it.
anyway, just venting a little ... and bored with the little orange light.
Old 03-13-2002, 01:22 PM   #8
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
Dude - go to a different dealer! They are BSing you, they can quite easily find out what a P0457 is, if they had Technicians that were anything close to knowledgeable they would know a P0457 off the top of their head.
- Richard.
Old 02-18-2009, 08:33 PM   #9
KW_Scoob
Member#: 173348
World Rally Blue
Smile
I guess I'm bringing this back from the dead but I just dealt with this issue after a Perrin turbo inlet install (only threw it tonight... a few days after the install!).
I made a quick blog post with pictures of the problem here:
http://drewstechnotes.blogspot.com/2...oblem-fix.html
Essentially the purge control host got disconnected and thus there was a "gross leak". Super easy fix, tricky little item to see and scary as hell when the code isn't in the repair manual.
KW_Scoob is offline   Reply With Quote
Old 02-21-2009, 12:56 AM   #10
lugee
Member#: 86604
08 C6 Corvette Z51
WRX 18G WFC 034 (sold)
^^^ thats actually really helpful dude - thanks. I just threw this tonight, I'll check the car later.
lugee is offline   Reply With Quote
Old 02-26-2009, 10:24 AM   #11
Buster05
Member#: 107323
2005 Impreza WRX 16g
Crystal Gray Metallic
if it wasnt totally gay.. I would kiss you. I've been looking everywhere trying to figure out where this stupid leak was coming from and sure as **** I go in and look any the blue nipple has no hose on in. Thanks so much, I wansnt going to be able to pass inspection because of it!!! Ive been in there I dont know how many times before and missed it. Thanks again!
Buster05 is offline   Reply With Quote
Old 05-10-2009, 03:13 PM   #12
05wrx09
Member#: 204111
2005 WRX
Another culprit could be the rubber gasket seal thing on the fuel pump assembly housing, especially if you or someone has recently put a new fuel filter or fuel pump on and didn't replace the gasket.... not that I would know anything about that or anything
05wrx09 is offline   Reply With Quote
Old 06-17-2009, 07:40 PM   #13
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
This was the same thing that happen to me.Found it and fix the problem
Needles is offline   Reply With Quote
Old 06-09-2010, 12:40 PM   #14
graphicsman
Member#: 245176
02 WRX
Midnight Black
i put a new hose on mine that was longer than the original, can that maybe be throwing the code? (new, longer hose where the blue t is)
graphicsman is offline   Reply With Quote
Old 06-09-2010, 02:38 PM   #15
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
shouldnt have any affect on it, as long as you used vacuum hose.
Old 06-13-2010, 12:10 AM   #16
Supraru
Member#: 23313
99' 2.5Rs
black
Yeah this code blows. I just had this code on an H6. A tech previously diagnosed a fuel pressure sensor and changed it. Somehow I magically got the come back. Well the tank had two pressure style sensors so I changed the other one.
Honestly it's a huge pain in the ass. The job paid .7 hours and I had at least an hour going over a few basic things. The problem is all the readings I was getting were correct and everything was functioning properly. It's not easy trying to locate the problem. I had two Sr master techs working with me on it who've been with subaru for a long time and have seen pretty much everything they have to offer. Unfortunately while in the shop the older lady that owned it died. Kind of sucks because I most likely will never know if that fixed the problem or not.
Supraru is offline   Reply With Quote
Old 06-16-2010, 09:27 PM   #17
graphicsman
Member#: 245176
02 WRX
Midnight Black
I'm still badling this code, it sucks
Old 06-17-2010, 10:15 AM   #18
TFBHTMFSNE
Member#: 156086
Almost as much as your spelling.
TFBHTMFSNE is offline   Reply With Quote
Old 06-17-2010, 08:39 PM   #19
Rex935
Member#: 205077
2010 WRX STI SE
Originally Posted by 05wrx09 View Post
Another culprit could be the rubber gasket seal thing on the fuel pump assembly housing...
I think that's the code that my WRX started throwing shortly after I bought it and the gasket was the problem. The dealer did inform me that it was possibly the fuel cap though.
Rex935 is offline   Reply With Quote
Old 06-23-2010, 08:02 PM   #20
graphicsman
Member#: 245176
02 WRX
Midnight Black
thats what you get when always on an iphone
Old 07-17-2010, 12:40 AM   #21
code72chase
Member#: 178909
+1 to another successful diagnosis. This was my issue too. Thank you!
code72chase is offline   Reply With Quote
Old 08-03-2010, 01:38 PM   #22
ed10
Member#: 198026
2002 Impreza WRX
Nulla Tenaci Invia EstVia
Ok I'm having the same issue and I see the blue nozzle but I noticed that it is T shaped....my question is should it have a hose plugged to all three ends???
ed10 is offline   Reply With Quote
Old 08-05-2010, 06:24 PM   #23
ed10
Member#: 198026
2002 Impreza WRX
bump this...I need an answer!!!!
Old 08-16-2010, 10:09 PM   #24
vsboxerboy
Member#: 38534
2002 WRX Sedan
Yeah, I have the same problem as well. I have no idea how to go about diagnosing this because the suggestions seem to be all over the car and in hard to reach areas.
I checked the blue nipple thing and that seemed to be hooked up okay (from what I can see, at least)
vsboxerboy is offline   Reply With Quote
Old 10-11-2010, 04:55 PM   #25
YinUCSD
Member#: 44945
06 LGT wag
i got this code on my Fxt today, so i checked out the blog, and the blue connector is indeed a T-connector, there was a loose hose right next to it that came out of the intake manifold, so i connected it to the T-connector (the one mentioned above was already connected). we'll see if it throws another CEL. but YES, the blue connector is a T-connector.
YinUCSD is offline   Reply With Quote
FYI: WRX Trouble Codes P0340, P0457, P1443 Jon [in CT] Warranty Issues & SOA Problems 13 09-23-2006 02:13 AM
Please Help CEL P0457 senna Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-03-2002 08:31 PM
Help with CEL P0457 EVAP Sparks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-15-2002 10:35 AM
Code P0457 - ?? Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-15-2001 12:17 PM
What is Trouble Code P0457? tdman77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2001 09:01 PM
