Old 05-09-2010, 09:56 AM   #1301
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
The 6 pot Tarmac with sti logo are 775pounds used each! That's a good deal I think. I'm going to grab a set next season or over the winter...
waynoSTI is offline   Reply With Quote
Old 05-09-2010, 11:10 AM   #1302
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
hmm really where i didnt see that? can you copy and past it so i can see which one as thats in my range..
tino is offline   Reply With Quote
Old 05-09-2010, 11:20 AM   #1303
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Ok sorry mate my bad. the ones i was talking about are on line 33-34 but they don't have a sti logo on them. they are 6 pot tarmac though...
Old 05-09-2010, 04:39 PM   #1304
jutes85
Member#: 127232
E92 M3
98' Foz
haha i dont have them, but thinking about getting them..
If you don't I will.
jutes85 is offline   Reply With Quote
Old 05-09-2010, 07:50 PM   #1305
tino
Top Scoob 019
Member#: 43630
Damn i want STI logo even though it adds like another 1000 pounds to the price.. hahah
hahah im thinking i might
Old 05-09-2010, 08:21 PM   #1306
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
Damn those brakes are ffffing awesome!
mpsti05 is offline   Reply With Quote
Old 05-09-2010, 09:15 PM   #1307
RedRexy-SG
Member#: 152285
Its also the same on the ralli spec website.. so im sure its okay??
but i am really wondering if getting the sti Grp N ap racing 4 pots will be better than the sti 6pot street brakes??
Okay, I've just done more digging around and have convinced myself that the RA-R did indeed come with 2-pots in the rear. However, rotor sizes are nigh on impossible to come by (or I've possibly been looking in all the wrong places ).
Your call mate.
RedRexy-SG is offline   Reply With Quote
Old 05-09-2010, 09:41 PM   #1308
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
pretty sure they can be optioned in JP. So the oem ones should be the same.
scby rex is offline   Reply With Quote
Old 05-09-2010, 10:01 PM   #1309
tino
Top Scoob 019
Member#: 43630
Your call mate.
Yeh im pretty sure they did come with the 2pot rears. I think im going to use my front brembos for the rear so i will have 6pot fronts and 4 pot rears.
Can you guys explain how i can ensure that i have the correct brake bias? Do i need to change my master cyclinder etc??
The bigger rotors will still fit on the hubs correct?? ill just need maybe new brackets?? or maybe i can use the brackets off the 4pots as the 6pots have there own brackets..
Lastly the 6pots are for 5x114.3 PCD, do u guys think its an issue to drill out the correct holes through the hat to make the correct 5x100PCD?
Old 05-09-2010, 10:08 PM   #1310
scby rex
Member#: 104878
02 wrxbastardchild
sounds like too much of a headache. Id use the 6 and 2.
Old 05-09-2010, 10:46 PM   #1311
RedRexy-SG
Member#: 152285
^^ True. The front rotors on the STI are quite a bit larger than those on the rear. Brake bias issues may crop up. I'll post the specs of the stock brakes when I get back home later.
I don't know how the brake bias can be changed on the STi, or even if EBD can compensate appropriately, so I'll leave this to the gurus here to advise. The standard STi master cylinder should be adequate for what you intend to do.
The bigger rotors should simply fit directly onto the hubs. You might have to modify the stock backing plates to get the rotors to fit though.
With regards to the PCD, the bigger rotors will fit onto 5 x 100 as long as a competent machine shop drills out the holes correctly. However, you may wanna think about upgrading the hubs to the 114.3 version for stronger and longer lasting bearings and reduced pad knock-back, which might rear its ugly head even with the 6-pots.
Old 05-09-2010, 10:54 PM   #1312
tino
Top Scoob 019
Member#: 43630
hahah nothing a few brackets cant fix...
Yeh i think my front discs are around 300mm.. the 6 pot ones are 355mm i think..
But how is brake bias issue fixed; different master cylinder??
Old 05-09-2010, 10:56 PM   #1313
RedRexy-SG
Member#: 152285
^^Edited my previous post with more info.
Old 05-09-2010, 10:59 PM   #1314
tino
Top Scoob 019
Member#: 43630
Yeh im not sure either, the thing is though im increasing the front/rear by the same proportion so it should still be balanced??
backing plate not so much of an issue, alot of people remove them to keep the heat from building up??
yeh i have been thinking about the 114.3 swap but im going to have two sets of rims the enkeis and te37s which are both 5x100. So unless i can go back to a 5x100 by modifying the hubs some how i dont want to go down that path...
hahah yep heres my re-reply
Old 05-09-2010, 11:07 PM   #1315
RedRexy-SG
Member#: 152285
A quick search on Google threw up this thread started by Legacy777 on NASIOC: Brake Math/Torque Spreadsheet
The spreadsheet link in that thread still works. Hope it helps you in your application.
Old 05-09-2010, 11:44 PM   #1316
tino
Top Scoob 019
Member#: 43630
Pity theres no new 6 pot data in there.. i might try and work it out though.. as it seems the calcs are there..
Old 05-10-2010, 03:06 AM   #1317
RedRexy-SG
Member#: 152285
Seems the 6-pot data is hard to come by. I wanted to assume that the calipers are the same as those on the R35 GTR but I have no way to substantiate that. Furthermore, I think the discs on the R35 are bigger than those on the RA-R.
If I perchance upon any info, I'll keep you posted.
Old 05-10-2010, 03:13 AM   #1318
tino
Top Scoob 019
Member#: 43630
Yeh the calipers are the sane as the R35. the discs are 355 mm asfaik
Old 05-10-2010, 06:40 AM   #1319
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
Tino, Tino, Tino - top stuff !!!!
And70 is offline   Reply With Quote
Old 05-11-2010, 10:06 AM   #1320
tino
Top Scoob 019
Member#: 43630
hahaah Andy i saw ur ninja edit.... Im trying to stop but i just cant.. grrr this is sending me broke
Anyway So this is the new turbo sump dougie bathroom spec styles.. It will be mounted on the chasis underneath the radiator fans hence the shape.
Not bad effort including Russes orignal work..
Old 05-11-2010, 11:27 AM   #1321
9vapors
Member#: 92582
Lol, so does the water go the opposite way when you flush?
Anyway, looks pretty great...
9vapors is offline   Reply With Quote
Old 05-11-2010, 03:33 PM   #1322
25rsti
Member#: 166324
at least the toilet was flushed
Old 05-11-2010, 08:26 PM   #1323
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
You could make one of those and replace the Toilet Tank Totally..
Lol, braided lines on the ****ter!! ftw
dudley123 is offline   Reply With Quote
Old 05-11-2010, 10:59 PM   #1324
tino
Top Scoob 019
Member#: 43630
hahaha not my toilet this is my workshops guys on... My pics will still be bathroom spec not toilet spec
Old 05-12-2010, 12:22 AM   #1325
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Its midnight and i just woke up everyone including my cat Integra, because I almost pit my shants in laughter!!!!
That toilet picture is Classic!!! You really have started a new trend Tino
Looks great!
cribbie is offline   Reply With Quote
WORKS TUNING AT EDO 8/23 and 8/24 Edo Performance SCIC Vendor Classifieds 0 08-15-2008 02:52 PM
STi clutch slipping at 26 psi of boost DJIMPREZA Transmission (AT/MT) & Driveline 8 03-04-2008 10:04 PM
18g boost creep at 8 psi AlboWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 01-06-2007 05:19 AM
Only 8 PSI boost Uncle Scotty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-28-2003 09:09 PM
only 8 psi boost stock? solomrus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-16-2001 02:15 PM
