Old 04-25-2008, 08:36 PM   #126
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Originally Posted by Homemade WRX View Post
so, you are still choking the engine? doesn't look as bad...
my guess would still be that intake manifold as its the only off the wall item in the build. The head's weren't heavily ported, were they?
I dont know now micah.. I think that the cams were the issue and the cam bolts snapping have suggested that the cams werent in perfect alignement..
By getting another 21 hp atw on the same boost suggests that this is the case. The torque also dosent seem to drop off as much.
You also have to remember that peak numbers dont mean much compared to you guys in the U.S as we do make much lower numbers in AUS. but the increase in hp to boost sounds about right to me now...
The heads werent heavily ported.
I think exhaust is the next thing to look at, but going to a 1.15 housing will cause more lag and i dont think i want to go that way at this stage..
tino is offline   Reply With Quote
Old 04-25-2008, 08:36 PM   #127
tino
Top Scoob 019
Member#: 43630
Originally Posted by Full-Race Geoff View Post
what i was saying was most people connect their downpipe to their exhaust with a 3" 2bolt flange. Unbolt the exhaust at this flange, and run only the downpipe, no muffler, cat, etc. This is to make sure that a muffler or flex section has not broken off or collapsed, causing a restriction and excessive backpressure (i have seen this happen before). By only running the downpipe, this verifies that the backpressure is before the turbine wheel, meaning turbine housing, up pipe, header or exh cam. Now you should run a pressure transducer on the exh side or a differential pressure gauge to compare exh mani pressure to intake mani pressure
Thanks geoff,
Ill reply to your pm...
Old 04-26-2008, 08:36 AM   #128
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I'd love to see you throw the stock intake manifold on and then retest.........
modaddict is offline   Reply With Quote
Old 04-27-2008, 01:20 AM   #129
SOOBE
Member#: 78977
so why did your cam bolts snap?
SOOBE is offline   Reply With Quote
Old 04-27-2008, 03:38 AM   #130
tino
Top Scoob 019
Member#: 43630
Why did the cam bolts break, well apparently they were tired from being put in and out of two engine builds..
Why werent they replaced with new ones on this current high HP build if this was the case still fathoms me...
I wish that it was that simple some mods and tuning need to go with switching the manifolds and considering im out of pocket now for the engine being pulled out again im not going to venture playing around for a bit..
Old 05-06-2008, 01:41 AM   #131
tino
Top Scoob 019
Member#: 43630
Update:
Well i was getting a race fuel tune done before i went down the 1/4 mile, as race fuel imo is much better when putting stress on an engine.
With no modifications to boost made 575 hp atw @ 1.9 bar, so it seems the engine is flowing fairly well. The car wasnt being pushed to hard at all and we were just about to put in a lil more boost when we dropped a cylinder again on the re-run at 7700 rpm.
Having a closer look, it seems we have another valve or cam related issue... There was no noise or smoke exiting the exhaust so nothing is broken, which is good. Just means more time at the workshop.
heres the graph:
Old 05-06-2008, 03:33 PM   #132
cpturbo
Member#: 49175
2004 STI
Tino,
Are you still using the Perrin Headers?
Good power to high RPMs. Not many Subarus can come close to that. I think that I have seen 1 or 2.
Good luck
cpturbo is offline   Reply With Quote
Old 05-06-2008, 05:28 PM   #133
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
hmmm... I guess those Perrin headers aren't as bad as everyone thinks..
jigga is offline   Reply With Quote
Old 05-06-2008, 08:06 PM   #134
tino
Top Scoob 019
Member#: 43630
Originally Posted by cpturbo View Post
Tino,
Good luck
Rooney, yeah im still using the same exact setup. IMO the race fuel tune would have showed up a restriction if there really was a large one?? This was also all on the same boost.
Going from the numbers there dosent really seem to be one imo??
If we didnt have this recurring valve issue then a couple of psi ~30 psi would have easily netted 600 whp.. Oh well just have to wait til its sorted out again..
Old 05-06-2008, 09:11 PM   #135
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
Originally Posted by Junior2JZ View Post
I made around 420ftlbs, which is pretty much exactly what you made. I think its that intake manifold. I would just throw a stock manifold on and watch the power come back. Also would help spool.
I dont think the headers will help much. . . IMO I have made almost 700whp with this same exact setup and found no issues with the Perrin EL header. Sinlgle scroll to boot.. I think I am pretty much maxed out in terms of power with this turbo.
Yea... Im going to say it again.. Those headers are ok..
Tino I bet your car will make good power with another few psi.. Take it to the track!!!
Junior2JZ is offline   Reply With Quote
Old 05-13-2008, 07:50 AM   #136
tino
Top Scoob 019
Member#: 43630
Junior you guessed right
Old 05-13-2008, 09:25 AM   #137
9vapors
Member#: 92582
^^^That's quite the teaser... Did you take it to the track?
9vapors is offline   Reply With Quote
Old 05-13-2008, 09:31 AM   #138
tino
Top Scoob 019
Member#: 43630
im sure u posted in my other thread, but here it is for ya if you didnt remember
http://forums.nasioc.com/forums/show...1511354&page=3
Old 05-13-2008, 09:34 AM   #139
9vapors
Member#: 92582
Ah, I thought you ran it again with more boost...
Old 05-13-2008, 09:37 AM   #140
tino
Top Scoob 019
Member#: 43630
hahah nah not yet, its winter time in australia, so the track wasnt open tonight. However i need to get a few things organised (i.e smaller brakes, smaller wheels, grippy typres, suspension, launch control, anti-lag, tune) to make the ultimate pass before i get banned from the track..
Old 07-25-2008, 03:57 AM   #141
tino
Top Scoob 019
Member#: 43630
Well my bad luck continues it seems.. Drove the car on saturday parked it for about an hr or so. Jumped back in and turned the ignition which was followed by a massive explosion, smoke was then pouring out of the engine.
Opened the bonnent to see that the back of my manifold had blown off from the welds and the bottom of the manifold had done the same..
Im unsure what has happened and why? Can anyone shed any light on it? Looks as if there was fuel trapped somewhere??
I also not sure if ill switch to a stocky cast manifold, fix this one or go with another design..
Also finding it very hard for someone to make me a new one.. Any offers??
here some pics:
Old 07-25-2008, 05:56 AM   #142
robertowrxsti
Member#: 133902
2006 STI
Grey
Was anything else damaged in the engine?
robertowrxsti is offline   Reply With Quote
Old 07-25-2008, 06:01 AM   #143
tino
Top Scoob 019
Member#: 43630
^^^ No everything looks fine.. i think that the mani was very thin so gave way fairly easily...
Now just need a replacement mani...
something like this would work well imo..
Old 07-25-2008, 07:19 AM   #144
r8r4life
Member#: 101464
Maybe if you get ahold of him he will make you one.
r8r4life is offline   Reply With Quote
Old 07-25-2008, 09:07 AM   #145
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I have had that before... I think it is caused when your ecu primed your engine before starting. i find that if I go to prime a hot engine, I sometimes hear a little "pop" in the intake manifold, and if the car is in gear, the gear will jerk forward... I think that is what happened to you, but your manifold gave way...I would switch to a stock manifold if I were you. Sure it might not do as well as at the top end, but it is reliable...
That polished manifold you posted was a custom job, and last time I asked him, he wasn't all that interested in selling his work.
Either that, or try the Forsa unit... or the Corsa Veloce unit if it has been released yet.. I thought that was a CNC machined piece, so no worries about welds blowing out.
Old 07-25-2008, 09:28 AM   #146
silverwrx666
Member#: 86514
07 swp sti,86 k10
96 legacy,91 lexus LS400
I think xxtuning makes a manifold like the one you posted above. Its a modified N/A one I think.
silverwrx666 is offline   Reply With Quote
Old 07-25-2008, 09:32 AM   #147
tino
Top Scoob 019
Member#: 43630
The bang happened once before a week earlier, but there was no carnage. Maybe it weakend the welds for the final bang.. haha
Yeah ive sent him a msg, hopefully he replies
As for the other manis- im not a fan of the forsa and its plenum design.. The corsa veloce looks good but yet to see how it performs.. or if its worth the 2.5g price tag...
Old 07-25-2008, 09:33 AM   #148
tino
Top Scoob 019
Member#: 43630
The xxtuning one is a 2.5 N/A manifold which cant be reversed asfaik..
Old 07-25-2008, 11:41 AM   #149
dug-e-fresh
Member#: 4568
10.7 @ 136, 1.72 C16
11.9 @ 120, 1.89 93
Damn!
def
dug-e-fresh is offline   Reply With Quote
Old 07-25-2008, 01:21 PM   #150
gold rush
Member#: 90110
2004 wrx wagon
If you've got coin you could get this one from RCM:
http://www.rogerclarkmotorsport.co.u...800x533%5D.JPG
gold rush is offline   Reply With Quote
WORKS TUNING AT EDO 8/23 and 8/24 Edo Performance SCIC Vendor Classifieds 0 08-15-2008 02:52 PM
STi clutch slipping at 26 psi of boost DJIMPREZA Transmission (AT/MT) & Driveline 8 03-04-2008 10:04 PM
18g boost creep at 8 psi AlboWRX Factory 2.0L Turbo Powertrain 26 01-06-2007 05:19 AM
Only 8 PSI boost Uncle Scotty Factory 2.0L Turbo Powertrain 17 02-28-2003 09:09 PM
only 8 psi boost stock? solomrus Factory 2.0L Turbo Powertrain 8 09-16-2001 02:15 PM
Message Board Statistics All times are GMT -4. The time now is 08:35 AM.
