North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 03-14-2008, 07:28 PM   #1
token85
Member#: 105974
2002 02 bug eye
05 blob eye
Default suspension noob here please help
ok im having this weird noise come from my suspension as i slow down to a stop or take off from a stop, or go around corners at low speeds. the noise only happens when im under 10mph. the noise is hard to explain but it sounds something like how an old house with hard wood floors kinda creek. not really a creak but i dont know. please help any ideas would help before i go and take it into a shop, and pay 98 dollars for them to tell me that i need new springs or the bushings on top of it all.
token85 is offline   Reply With Quote
Old 03-14-2008, 07:35 PM   #2
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
01 RS-EJ205, EG33 GM6
There are several things that can make a creaking noise. Do you have upgraded sway bars with poly bushings? Dry bushing can make a noise like that.
Dyno Authority is offline   Reply With Quote
Old 03-14-2008, 08:45 PM   #3
token85
Member#: 105974
2002 02 bug eye
05 blob eye
everything is stock. so is dried bushings a bad thing, or do i have to look into buying new 1s
Old 03-14-2008, 08:49 PM   #4
misterwaterfallin
Member#: 101091
you can try to grease them up a bit, or if your feeling a bit adventurous I've heard wrapping the contact area on your sway bar with teflon tape will also eliminate the creaking noise
misterwaterfallin is offline   Reply With Quote
Old 03-14-2008, 08:56 PM   #5
selvar05WRX
Member#: 165524
2012 CTS-V Sedan
Black Diamond Tri-Coat
my car is doing the samething, and as far can tell and what i have been told its the stock struts going bad... putting coilovers on next week. Will let you know if the problem is fixed
selvar05WRX is offline   Reply With Quote
Old 03-15-2008, 01:16 AM   #6
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
1st solution. Try silicon spray at the bushings and sway bar mounting points...
I do this once a month and it takes care of the creaks of the suspension points.
NW OBS is offline   Reply With Quote
Old 03-15-2008, 08:50 AM   #7
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
They also have pressurized foaming lube in a can which has some good penetrating properties that works great. I have a can around here somewhere I'll try to find the brand. As far as worn out struts goes, they generally don't go creak, they go clunk over abrupt bumps, the handling gets bouncier and sloppy.
QuikWgn is offline   Reply With Quote
Old 03-16-2008, 11:03 PM   #8
token85
Member#: 105974
2002 02 bug eye
05 blob eye
thanks for the help i will try spraying some type of lubricant on it and see if that works, as for the noise its not a clunk, but i do seem to find out i feel everything on the road. but it has been this way for a long time now so dont know if the struts are going out.
Turbo ID help..newbie here please help stiguy0075 Newbies & FAQs 16 04-18-2009 06:49 PM
some noob questions please help vrgs AccessPort 1 11-11-2007 10:37 PM
Noob Question please help?! yournamehear119 UTEC 2 02-14-2007 12:33 AM
noob question! please help simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2006 02:00 PM
Suspension Newbie here!! need help sti2_5rs Brakes, Steering & Suspension 13 10-19-2001 08:38 PM
