Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 03-14-2008, 11:10 PM   #1
shadymilkman129
Member Sales Rating: (4)
Member#: 53651
Cert Suby tech
specialist for hire!
Exclamation Zeal function KW Variant 3 Coilovers - 04-07 STI
Selling an amazing set of coilovers here. Racecomp Engineering Tarmac 2 KW3 Coilovers
The new KW Variant 3 coilovers are state-of-the-art coilovers designed specifically for the skilled and experienced driver. These coilovers are perfect for heavy track use and are used competitively world-wide. The separate and independent compression and rebound damping options allow for suspension fine-tuning. The unique triple-adjustable components, allow for low-speed compression adjustment, while the high-speed compression has been preset by KW engineers. The end result is a high quality ride with track-ready performance.
Features
Independently adjustable damping technology -rebound and compression damping
Inox-line stainless steel technology at no extra charge
Individual height adjustment
German TUEV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
Infinitely adjustable rebound damping
14- level adjustable compression damping
Unique, independently functioning damping power adjustment
The features of the Tarmac 2:
2-way design with separate compression and rebound adjustments.
choice of 3 different linear spring rate kits: 500 lbs/400 lbs(9kg/7kg), 400 lbs/350 lbs (7kg/6kg), and 350 lbs/300 lbs (6kg/5kg). spring rate conversion
stainless steel corrosion resistant coating.
double locking perches.
unique paint scheme.
limited lifetime warranty through KW.
USA based technical support.
wide range of spring rates supported without a revalve.
-The ones I am selling are the 400 lbs/ 350lbs (7kg/6kg)
Only 1000 km on coilovers. $2000 Firm.
shadymilkman129 is offline   Reply With Quote
Old 03-14-2008, 11:11 PM   #2
shadymilkman129
Member#: 53651
Cert Suby tech
Old 03-15-2008, 12:39 AM   #3
misterwaterfallin
Member Sales Rating: (6)
Member#: 101091
pics of actual units? spring rates? any tops hats/camber plates included? do they fit an 04 or 05-07 sti?
misterwaterfallin is offline   Reply With Quote
Old 03-19-2008, 06:16 PM   #4
shadymilkman129
Member#: 53651
Cert Suby tech
Upper mounts included, and these are for 05-07 model year STI's.
I learned that these are the 400 lb/ 350lb Tarmac II KW3's
P.S coilovers have less than 1000km on them, the zeal super function R's I am selling have 4000 miles. The KW3's have 1000km.
Old 03-22-2008, 06:29 PM   #5
shadymilkman129
Member#: 53651
Cert Suby tech
Umm why arnt these sold yet? Absurdness..
KW Variant 3 Coilovers - One set only for 01-03 Impreza RS, WRX, STI - CRAZY CHEAP! Innovative Tuning Suspension/Brakes/Handling 3 03-11-2009 08:29 PM
KW Variant 3 Coilovers 05-07 STI CyborgX_CZ Suspension/Brakes/Handling 26 01-19-2009 09:00 AM
KW Variant 3 Coilovers 04 STi Egan Suspension/Brakes/Handling 8 10-29-2007 10:49 PM
WTS KW Variant 3 Coilovers For 05-07 STI [email protected] Suspension/Brakes/Handling 14 08-03-2007 08:03 PM
KW Variant 3 Coilovers 02-07 WRX 04 STI Paintballguy Suspension/Brakes/Handling 0 07-05-2007 09:20 PM
