Old 03-15-2008, 02:52 PM   #1
poison
Member#: 37678
Default Oil on spark plug boots - WTF?
I just went to change my spark plugs. I pulled my first boot off, and it had oil around the inside of the top seal, and around the opening into the engine.
What is THAT, and what do I need to do to fix it? WRX swap?
poison is online now   Reply With Quote
Old 03-15-2008, 03:05 PM   #2
grimble
Member#: 157541
2004 2.5 rs
psm
If you want a wrx so bad then just sell your car and buy one..........
haha sorry couldnt help myself
grimble is offline   Reply With Quote
Old 03-15-2008, 03:19 PM   #3
poison
Member#: 37678
Why, so I can pull all my suspension modifications then put em on the new car, plus have car payments? No way.
How about some real help here?
Old 03-15-2008, 04:55 PM   #4
Sharky NRK
Member#: 29549
2003 WRX
does the valvecover gasket set have the little o-rings for the spark plug bosses - common issues on other cars when those o-ring get old is seepage around the plug boot
Sharky NRK is offline   Reply With Quote
Old 03-15-2008, 05:04 PM   #5
lvngded
Member#: 170177
02 WRX Wagon
^^^+1. valve cover gaskets. replace them.
lvngded is offline   Reply With Quote
Old 03-15-2008, 05:09 PM   #6
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
My VC gaskets last 3 years. Your's perfect timing. They are relatively inexpensive from the dealer and easy to change DIY. I have a note on this board years ago on how to.
Jerry
Jerry Xu is offline   Reply With Quote
Old 03-15-2008, 05:30 PM   #7
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
we (my shop for aircraft maintenance) uses Dow Corning O-ring grease when installing new orings and it substantially increases o-ring longevity in engine/hydraulic oil applications. It causes the o-rings to expand slightly while protecting them for a good while. we have actually been able to get 400 hrs out of o-rings that had been routinely being replaced @ every annual inspection (150-200 hrs) (doesnt work in fuel o-ring applications) I dont know how much it costs but its probably atleast $20-30 a tube. (which will last you the rest of your life) just a suggestion and future idea for anyone doing o-rings in high temp/corrosive environments.
Old 03-15-2008, 05:46 PM   #8
Jerry Xu
Member#: 36629
07 2.5i
Subaru specifically says no lubrication when changing VC gaskets. So i didn't use any. I guess it might get into crank?
Old 03-15-2008, 06:13 PM   #9
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
hmmm, well guess you better not use any type of grease then. i didnt know they said thath in the MM, just some knowledge i picked up from my day job.
Old 03-15-2008, 06:16 PM   #10
poison
Member#: 37678
Awesome, guys, thanks. Anyone got a link to instructions? I couldn't find anything here or on scoobymods.
Old 03-15-2008, 09:51 PM   #11
tankd0g
Member#: 170241
1993 Celica GTS
Red
That's kind of retarded, they live in a bath of hot oil. Might as well lube both sides. I just use motor oil.
tankd0g is offline   Reply With Quote
Old 03-15-2008, 10:51 PM   #12
poison
Member#: 37678
So anyone have a blow-by-blow on pulling this off DIY? I'm a mechanical n00b, never seen a valve cover gasket.
Old 03-15-2008, 11:30 PM   #13
Jerry Xu
Member#: 36629
07 2.5i
Some newbie calling people retarded.
http://forums.nasioc.com/forums/show...=711521&page=2
Old 03-16-2008, 03:50 PM   #14
tankd0g
Member#: 170241
1993 Celica GTS
Red
Someone is confused about the difference between sealant and lubricant.
Old 03-16-2008, 03:54 PM   #15
Jerry Xu
Member#: 36629
07 2.5i
No nothing ok? You don't want the silicon based stuff into the engine oil,dude. No, it is not all bathed in oil, except when it becomes bad. If you really want to use something, use some natural air.
Found oil on spark plug wires rubberman Service & Maintenance 6 10-25-2011 02:38 PM
STi, small amount of oil on spark plug BrandonWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-26-2005 02:31 AM
Oil on spark plug boots (even after new valve cover gaskets) FujiHeavyFreak Service & Maintenance 2 08-14-2005 12:30 PM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 10:27 PM
Oil on spark plug wires normal HighTachPrez Normally Aspirated Powertrain 1 05-21-2003 02:36 AM
