Old 03-15-2008, 06:44 PM   #1
INTENSEdan
Member#: 164396
1999 Impreza
Default Sluggish below 2500rpm - ideas?
The car in question is a 99 Impreza 2.2. I've noticed recently that giving the car throttle at low rpm results in sluggish, uh, lugging until it gets up to 2500rpm. It's not consistent (mostly in 1st gear and when its cold), but also accelerating in 5th gear is something you need to plan ahead for.
The car has 131,000 miles so I figure it's due for a tuneup anyway, but I was wondering if there are other things I should check while I'm at it.
INTENSEdan is offline   Reply With Quote
Old 03-15-2008, 09:26 PM   #2
danmezz
Member#: 126339
2003 WRX Wagon
a good tuneup never hurts... might be worth thinking about "seafoaming" the engine to clean out any carbon deposits. That sometimes helps higher mileage engines.
Could also be a plugged catalytic converter. Plugged cats can cause a significant loss of power and higher fuel consumption.
danmezz is offline   Reply With Quote
Old 03-15-2008, 10:04 PM   #3
INTENSEdan
Member#: 164396
1999 Impreza
I think I heard an exhaust leak the other day, maybe thats the culprit? I'm still managing like 25mpg so it's really not so bad. If I do have a leak maybe its a good excuse for a new catback.
I friend recommended I check the EGR, but do 99s even have an EGR?
2500rpm startup flare when cold. Any ideas? x99percent Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-05-2007 11:16 AM
Det er kaldt: Wind chill readings 15 below to 25 below zero. Protege Menace Off-Topic 38 01-12-2007 03:22 AM
JD Powers: Subaru below average dependability, below GM Ford chimchimm5 General Community 33 01-27-2006 02:19 AM
$1000 below invoice on 05 Vs. ?$1000 below willowracer Impreza Forum 7 07-03-2005 04:51 AM
Odd engine stumble/vibration from 1900-2500rpms in neutral MaddMax Legacy Forum 13 10-12-2004 08:23 PM
