Old 03-15-2008, 10:19 PM   #1
gsxbusar1300
Member#: 161982
04 WRX
Default 1998 2.5RS Overheating Question
Hey Guys,
Car info:
I'm having overheating problems with my car. It's got about 113,xxx miles on it and it had the timing belt and water pump changed at about 105,xxx miles. I just recently bought a new radiator for the car and is on it as well. We made sure that the radiator, fans and water pump were working, and they are.
"Diagnosis":
My car was taken into a radiator shop and the mechanic there thinks that I have a blown head gasket. ALL of my fluids were changed by my friend and he said that the oil and fluids were not contaminated with water so he doesn't think that it is a blown head gasket.
Problem:
The car seems to be fine when it is in motion, however, if the car idles (i.e. at a stop light/traffic jam) it begins to heat up. The car is running with no thermostat right now because when we put a new one in, the temp gauges on my dash indicates that it is overheating even when the car has just been running for only 3 mins.
If you guys could help me with any suggestions or possibly identify/solve the problem, I would greatly appreciate it. Thanks for the help, and have a good one!
gsxbusar1300 is offline   Reply With Quote
Old 03-15-2008, 10:45 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
if you are overheating with no thermostat thats a pretty good sign of a leaking headgasket.
98's are a pain to bleed the air out of though, you should follow the instructions in the owners manual.
Old 03-15-2008, 10:57 PM   #3
Subaruski
Member#: 39905
had to do the headgaskets around the same mileage on my 98rs. Its something that has to be taken care of on the dohc motor at that high of mileage. I replaced the water pump, thermostat, and timing belt when i did mine but it sounds like you just recently took care of that. When you change the gaskets check the heads and see if they are warped. Machine them down if they have any warping what so ever.
Subaruski is offline   Reply With Quote
Old 03-16-2008, 04:02 AM   #4
gsxbusar1300
Member#: 161982
04 WRX
Okay I'll try and check on that next week when I have time. Thank you guys very much for your help =D
Old 03-16-2008, 03:48 PM   #5
gsxbusar1300
Member#: 161982
04 WRX
I have a friend who can swap a brand new '06 2.5i into my RS so hopefully that'll just solve everything. The only problem that I might run into is passing visual smog test because of the EGR valve will be in a different location....I hate CA emission regulations T_T lol
Old 03-16-2008, 11:27 PM   #6
Illsti
Member#: 131183
05 STI
CGM
pressure check the coolant system....
Illsti is offline   Reply With Quote
Old 03-17-2008, 12:10 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
sure sounds like HG failure to me as you are describing it
exact same symptoms I had in my 99 Legacy which suffered HG failure.
IMHO, the thing to do is go and have a hydra-carbon sniffer test done
rather than guessing, at get the proper diagnosis so you will know for sure.
Old 03-17-2008, 12:11 AM   #8
gsxbusar1300
Member#: 161982
04 WRX
we have verified that the system does have pressure...we checked the components of the system and they are working properly. as of this point, i'm convinced that the problem is internal and is cheaper for me to swap the motor since my friend can do it, rather than to R&R my existing head/motor.
Old 03-17-2008, 12:30 AM   #9
gsxbusar1300
Member#: 161982
04 WRX
thanks Subie Gal! i checked out some other forum sites and other helpful sites on hydrocarbon sniffer tests and the symptoms they listed there are exactly identical to the problems that i am experiencing. the procedures and self tests that they listed were the exact checks my friend and i did and the results were similar.
also, when the mechanic at the radiator shop took a look at it, he had me take off the radiator cap (after the car had cooled for a bit) and had me start the car up and immediately, exhaust smoke came from the radiator...so i guess i should make sure to see whether or not my heads are still fine so i can just replace the gaskets.
Old 03-17-2008, 12:34 AM   #10
gsxbusar1300
Member#: 161982
04 WRX
^^ although, i think the previous owners had been running the car for a while with the HGs blown (and didnt bother telling me) so i believe that it is too optimistic to think that my heads are still fine
1998 2.5rs To 1999 2.5rs gc8v6 Subaru Conversions 2 11-02-2009 12:59 PM
Wiring question. 1998 2.5RS turboed22 Normally Aspirated with bolt-on Forced Induction Powertrain 3 05-24-2009 03:29 AM
gauging interest: 1998 2.5RS-t with Axis stage 2 motor (new)... Keith Private Vehicle 'For Sale' Classifieds 28 02-18-2009 02:40 PM
FT: 1998 2.5rs Black 2 door GOLDIES! loudbay Private Vehicle 'For Sale' Classifieds 2 03-03-2005 06:49 PM
2000 2.5RS' limited slip diff -> 1998 2.5RS ? grue Transmission (AT/MT) & Driveline 3 04-13-2004 02:59 PM
